TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Lowering Springs Suggestion
      04-28-2014, 02:25 PM   #1
dapogiman
Drives: 2009 BMW 328i xDrive Sedan
I have this wheel/tires set up
18x8.5" STR 601, Falken ZE612 225/40ZR18 square
Will it rub if I put lowering springs? What brand can you suggest?
Thank you.
      04-28-2014, 10:47 PM   #2
techietaichi
techietaichi's Avatar
Drives: 2006 325i Pre-LCI & 2010 X3
What's your wheel offsets and how much you looking to drop?
      04-28-2014, 11:23 PM   #3
ErzenE92
ErzenE92's Avatar
Drives: 2009 E92 335i
if you put the H&R sport springs on you will have enough room
      04-29-2014, 05:02 AM   #4
dapogiman
offset 17, looking to drop 1.2" but not sure if that drop will rub. My wheels/tires are sticking out a little bit so I's afraid it will rub.
      04-29-2014, 08:46 PM   #5
techietaichi
With H&R Sport Springs I achieved a drop of 1.3 in the rear and 1.4 up front and this is with stock shocks. Since you mention your wheels stick out a bit, it might pose a problem but not so sure, you'll have to try it. From what I see of the pic you provided, it looks borderline. A practice that some take up and you've likely seen it before is "stretching" your tires. Mine are slightly stretched on my rears, but not enough to look ridiculous. I'm not a fan of tires extending beyond the fender, but the stretch for me assures no rub at all, totally precautionary. I've got 19 x 8.5 35mm offset in front and 19 x 9.5R 30mm(35mm rim w/5mm spacer) in the rear.
lowering springs, wheels
