1st Track Day = N54 Engine Failure :(
02-25-2013, 10:39 PM | #23 |
Rep 864
Drives: '08 E92 335i
What else could it be? I can't see him blowing the motor from lack of octane or knock @ 14psi, the DME will protect the motor in that situation. Could be oil pump failure? The white smoke could be a turbo letting go but that wouldn't explain the clutch or the lack of compression in a cylinder.
None of the theories I've heard so far really jive with everything he's said... |
02-25-2013, 10:50 PM | #24 | |
2015
Rep 2,659
People don't understand that good engineering includes r&d, experience, quality of materials, reliability, maintainability etc. |
02-25-2013, 11:43 PM | #25 | |
Midlife Crises Racing Silent but Deadly Class
1817
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Simply put, the pressure plate isn't designed to withstand the full force of a tuned engine. Say something broke coming down the straight causing the "surge" symptoms, what potentially feels like slipping clutch...then you jump off throttle for the braking zone and all hell broke loose, something catastrophic happens to the clutch and cause the spinning crank to seize up. BAM. Cylinder 4's bearing spins free and punches a hole through the block. The fact that you didn't leave fluid on track would suggest to me, that the smoke you see could possibly be the clutch going up in smokes. Whatever disintegrates in the clutch disconnects the flywheel and the transmission and no lock-up of the rear wheel. I still think that the fact he clutch pedal is to the floor is suspicious. Doesn't hurt to look at it, since when the new engine is put in, you'll get a good look at the clutch. None of the clutch hardware is anywhere near enough to cylinder 4 for any sort of damage to cause the clutch to floor out...but a nuked pressure plate might (and that makes you wonder why the pressure plate is nuked when/if the engine blew first).
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
02-26-2013, 10:32 AM | #26 | |
176
Rep 2,301
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
02-26-2013, 10:37 AM | #27 |
176
Rep 2,301
More like 420hp or so, but high quality post as usual, non the less, hack.
'07 335I w/ Mods
02-26-2013, 10:49 AM | #28 | |
Rep 864
02-26-2013, 10:51 AM | #29 |
208
Rep 1,161
Not that I think it was an issue here, but overfilling oil can cause motor failure. If it's high enough in the sump so that the crank is eggbeating it, your oil can foam, break down, and motor fails.
02-26-2013, 01:13 PM | #30 |
Rep 4,153
Drives: 1/18 Monte Carlo Blue E92 M3
I really hope it wasn't the meth.
02-26-2013, 09:19 PM | #31 | |
driver mod in progress
223
Rep 1,858
Drives: with both feet
All good posts, guys. These are all the same questions I've had running through my head for the last week.
UPDATE: New motor arrived today - hopefully mechanic will start tomorrow. May be delayed a day or so as mechanic is swamped; more updates will follow. Quote:
From N54Tech, BMS Meth Kit Thread (link)
03-05-2013, 09:51 PM | #33 |
223
Rep 1,858
UPDATE #2: 3/5 - Engine removed and root cause identified; hydrolock caused by methanol injection malfunction Today the failed engine was removed from the car and the cause was identified without even needing to tear the engine apart... excessive methanol injection caused hydrolock which resulted in a hole blown through the bottom end of the long block on the driver side. CRAZY! This is what I saw when I walked in the shop on my way home from work... I hope I never see this again... Failed engine removed from the car (below) Note the Lamborghini Gallardo in the background Hole blown through the driver side of the longblock above the oil pan, near the rear of the engine (closer to cylinder 6, farther from cylinder 1) Chunks of metal were removed from the oil pan and fragments were found in the oil filter (below). This means my ER dual oil coolers need to be flushed to ensure there's no remaining metal floating around in my oil lines. Also, still need to inspect the turbos off my failed engine to ensure they're good to re-use on the new engine. I'd prefer to keep them as they only have 12,000 miles on them, whereas the new engine and turbos have ~27,000 miles. Turbos off of replacement engine and various spare parts shown in picture below as the replacement engine is being prepped for transplant surgery (i.e. - carbon buildup being removed and major cleaning to ensure all metal fragments removed). Mechanic said there were still puddles of pink "boost juice" (pre-mixed methanol and distilled water in 49/51 ratio) inside the cylinders when he first gained access to the intake manifold. Basically, a smoking gun that the engine failure was caused by excessive methanol injection, which resulted in hydrolock. As far as what caused the methanol injection to malfunction, I have no idea. All I know is that my confidence in the BMS Methanol Injection kit is gone. I plan on ditching methanol completely and switching to a more track-friendly tune once my car is back up and running. Mechanic plans to have my car running by Friday (3/8). Of all the people using JB4 and its functionality as an integrated methanol injection controller, I guess I'm the first lucky one to have this happen.
03-05-2013, 10:38 PM | #34 |
176
Rep 2,301
Could you please read post #33?
'07 335I w/ Mods
03-05-2013, 10:41 PM | #35 | |
176
Rep 2,301
Thanks for having the nads to report all that happened to you online. Too often, folks love to brag about stuff online, but when failures occur, they want to save face.
'07 335I w/ Mods
03-05-2013, 11:00 PM | #36 |
Rep 1,005
Drives: GMC Sierra
Damn meth.
We grow food to feed the animals so we can eat the animals
03-06-2013, 04:06 AM | #37 |
Rep 1,618
Damn what a carnage
Good move to ditch that meth crap! For the track I would keep things as simple as possible. No stacking tunes, overcomplex fueling etc etc. More variables=more failures at the track. Good luck with the fix. Hopefully the turbos and oilcoolers are fine.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
03-06-2013, 11:18 AM | #39 |
2015
Rep 2,659
Nice meth test. This is great info. Fortunately the OP is fine and no catastrophic failure occurred (loss of life).
For anybody that wants a proof why quality vendors charge more this shows you what reliable engineering is and is not. OP, GL and keep the car as simple as possible while using quality parts. |
03-06-2013, 02:21 PM | #40 |
Rep 864
Don't know why you quoted me on this, I'm not sure it's possible to hydrolock the motor on a CM10 nozzle unless the nozzle broke. There's some discussion of this on the engine perf. forum also but they seem to think the meth kit just doesn't flow enough meth to hydrolock it that way?
If we're saying it's from detonation, okay maybe, although at 14psi thats unlikely. OP I'd inspect your meth hardware and see where the failure might have occurred. |
03-06-2013, 02:47 PM | #41 |
176
Rep 2,301
Cuz everyone in the other thread including myself leaned towards either the meth kit, or fuel injector, you on the other hand dismissed this entirely, and choose to blame oil starvation, or oil pump failure. You were wrong, and I was just pointing this out.
'07 335I w/ Mods
03-06-2013, 03:57 PM | #42 | |
Rep 864
03-06-2013, 04:20 PM | #44 |
Rep 864
engine failure, hydrolock, jb4, meth failure, n54 335i |
