TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      01-22-2013, 02:38 PM   #1
lowell_b
lowell_b's Avatar
Drives: 2007 E70 X5
Question Need TPM reset but iDrive broken
I just got all 4 tires changed and i need to reset my TPM. Only problem is that my iDrive doesn't work. Sometimes it does usually in hot weathers. (idk why) I was wondering if there's another way to reset it without using the iDrive. I have a 2007 X5. I would appreciate the help. Thank You.
(I hope the technician didn't install my TPM's the wrong way)
(let me add these new tires aren't run flat tires)
Laughter is the BEST medicine.
      02-02-2013, 08:42 PM   #2
kuyabil
Drives: 2007 328i, 2007 X5
2007 BMW X5  [0.00]
2007 BMW 328i  [0.00]
I drive, check the fuse behind unit, see video how to remove I drive then check for that fuse. I went from a potential 1500 fix to a 1.50 fix then when your I drive works you can reset tmps
      02-05-2013, 06:32 AM   #3
lowell_b
lowell_b's Avatar
Drives: 2007 E70 X5
Thanks for the help. I already got it reseted my iDrive works sometimes and then stops. I will look into taking care of the fuse when I get the time. Thank you
bmw x5 forums, idrive, tpm, tpms sensors
xbimmers
