aFe Performance Air Filter worth it?
02-16-2012, 09:02 AM | #1 |
18
Rep 58
Drives: 2008 328xi
Thoughts on aFe performance air filters? I like the fact that it doesn't need to be replaced, just cleaned. Is it worth it or should I just stick with the OEM filter?
02-16-2012, 11:11 AM | #3 |
18
Rep 58
Drives: 2008 328xi
Thanks for the advice. You're not the only one to recommend that. I think I'll save the money and stick with OEM.
02-16-2012, 07:18 PM | #4 |
20
Rep 171
Yes! if you can get it for $460. You will love this new intake, especially when you have AA tune and exhaust! It's by far the best intake out there, performance and sound!!!!
04-24-2012, 01:36 PM | #5 |
26
Rep 179
Drives: 2006 BMW 330i
Is the sound any better with this drop in filter?
04-24-2012, 02:59 PM | #6 |
Rep 148
From reading lots of threads on here, it sounds like the only difference with drop-in filters is the media, of which it may or may not be worse. Performance gains seem to be slim-to-none, sound isn't likely to change with the same closed airbox configuration, and you run the risk of damaging your engine with a non-oem filter. Now, most people say "pshaw, it's not going to damage my engine!" and I 98% agree with that, but if you don't get a performance increase, maybe probably not a noise increase, and it costs money, why even bother?
The short-arm intakes make more noise, but may give negligible-to-negative performance improvement, they're just for sound, and they're expensive. I can't believe how expensive intake systems are. They're so friggin easy to make a tube and point it in a direction that doesn't hit something. The difficulty comes in knowing/finding an injection molding company I suppose?
2009 328i Jet Black with Dakota Brown interior - Nav, heated seats, Premium Package
04-24-2012, 03:38 PM | #7 | |
26
Rep 179
04-25-2012, 09:46 PM | #8 |
Rep 223
I use it, makes for a much better intake sound, but not until I also modded the intake to add a second intake tube to the airbox and routed it to the brake duct behind the bumper. A lot of work but the nice intake sound is worth it for me, yet probably not worth the trouble for many others.
The intake remains enclosed, with better throttle response and rev as a result. I know it is better because I had driven two same model loaners already, both nearly new but no comparison to mine. The filter has been washed three times already, good as new. |
afe air filter, air filter, performance, performance air filter, replacement |
