where can i get this thing?
03-27-2014, 05:28 PM | #1 |
Rep 1,099
I lost this stupid little part and need to get a new one but I have no idea what its called or what part #. Its located under the windshield and above the cowl. Tried going to to the dealer and they couldn't find it either.. someone help me out please. its been raining so i wanna cover it up asap
03-27-2014, 05:58 PM | #2 |
Rep 3,850
Drives: 330i, 135i
junk yard?
03-27-2014, 06:27 PM | #4 |
Rep 7,063
BMW dealership. Probably about $4-$1,000,000
E90 Build Thread (SOLD) http://www.e90post.com/forums/showthread.php?t=809436
F15 Build Thread (SOLD) http://f15.bimmerpost.com/forums/sho....php?t=1064084 |
03-27-2014, 08:08 PM | #7 |
1645
Rep 2,494
ECS tuning has them...give me a minute I'll find the link.
EDIT: Part # was incorrect, removed to avoid confusion.
03-27-2014, 09:37 PM | #8 | |
Rep 1,099
Fasho thanks!! this doesn't look like the oem part I had but if it fits I'll use it! When i type in the same part number at bmw it shows this part # is a strut cover but i'll order it from ecs since its so cheap |
03-27-2014, 09:49 PM | #9 |
Rep 1,995
Hahaha pretty much.. I avoid the parts counter there like the plague. Wiper blades are over 100 dollars... The smallest thing like a special bolt that is only on bmw can cost you 5-10 bucks while online it is 50 cents.
When I cracked the overhead light with mic and airbag light in it.. No damage to the parts inside.. They wanted 450.00 dollars. I told them I would super glue the broken piece instead. Found it on ebay used for 45 dollars. |
03-27-2014, 10:11 PM | #11 | |
Rep 7,063
03-27-2014, 10:33 PM | #12 | |
Rep 471
-Kevin |
03-27-2014, 11:31 PM | #13 |
Rep 912
Check out my built thread of my white beauty! http://www.e90post.com/forums/showthread.php?t=1045460
Follow me on Instagram! l_gomez1215 |
03-28-2014, 12:00 AM | #14 |
Guest
Rep n/a
Drives:
You guys really need to learn to find a part diagram, that plug seals water from entering your interior so its KINDA important, there are 2 styles or sizes for pre-lci and LCI.
The pre-lci version has a small o-ring the lci version has a thick gasket, you have to make sure you order the correct one. I replaced my cowling and ordered the new version that fits the bigger plug, and I actually have a extra one if you need it brand new. That part number posted above is INCORRECT. I'll post the correct pn tommorow, too lazy tonight. |
03-28-2014, 02:16 AM | #16 | |
Rep 690
Drives: 2019 X3 M40i
03-28-2014, 12:14 PM | #18 | |
Rep 1,099
03-28-2014, 12:16 PM | #19 |
Rep 1,099
03-28-2014, 01:24 PM | #20 |
Guest
Rep n/a
Drives:
That should be the one you need
http://www.ecstuning.com/ES129080/ Notice the thick gasket The part switchover might not correspond exactly with pre-lci ---> lci, I just posted that for simplicity but a 2009 car should have the new style. |
03-28-2014, 09:28 PM | #21 |
General
17303
Rep 18,729
cover |
