installing dct paddles is trim on back of steering wheel removable?
10-16-2013, 09:34 PM | #1 |
26
Rep 147
I have a m3 wheel with red and blue stitching but the back of the wheel does not have the cutouts for the paddles. Can I remove this trim and install trim with the cut outs? I can find the trim for the front but not the back. thanks in advance
10-16-2013, 11:34 PM | #2 |
504
Rep 2,981
Drives: 2013 BMW F30 EBII
It cannot be removed, but there is a DIY thread I thought was on this board, but can only find it here when I searched google... http://www.bimmerboard.com/forums/posts/610491
Hope that helps
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
10-17-2013, 02:13 AM | #3 |
No 55mph
1616
Rep 8,474
There is no 'trim' on the back - it's all part of the wheel itself.
If you want paddles - you're gonna need to break down & get a wheel specifically for PS...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-17-2013, 02:28 AM | #4 |
26
Rep 147
Looks like I will have to get a new or see if I can modify this one (really don't want to) I glanced on the back side the other day and it looked like there were two screws that made it appear as if it might be detachable. I will take the wheel off tomorrow and get an in depth look at it.
10-17-2013, 04:08 AM | #5 |
No 55mph
1616
Rep 8,474
The (2) screws you see in the back go thru the wheel & fasten the front trim
I see no way that hacking up the wheel would allow you to install the paddles such as in that posted DIY. If you look at the differences in how the wheels are made - it wouldn't be a simple matter of just cutting a square hole...
10-17-2013, 07:00 AM | #6 |
40
Rep 2,431
Yeah, that DIY process won't work with the M3 or M-Tech wheels. You really need to trade that off for one with the cut outs and be done with it!
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
10-17-2013, 07:46 AM | #7 |
Rep 5,434
I originally did an M3 wheel before the DCT wheel was available and cut it out carefully and drilled the hole for the screw to hold the paddles in - it was a bid stressful hacking up a new M3 wheel at the time (as it was brand new) but worked out well - the shape of the back is a bit different, so I used some black silicone to fill the gaps from the back of the wheel to the paddle, but it all looked great and worked well. basically it is just a foam rubber you have to cut, easy to do it just hard to get it lined up correctly. In the middle of the rubber you cut is a steel bar that the paddle bolts to.
I only did it as there was no option otherwise, but it would be better to sell the M3 wheel and get the M3 DCT wheel instead.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
back, dct, rear, removable, trim |
