Brake wear sensors OEM vs. Aftermarket?
12-29-2013, 06:23 PM | #1 |
joseph
Rep 66
I was wondering if there was a strong quality difference between the $7 aftermarket sensor by IRO, Uro Parts, or PEX (from ecs tuning, autohausaz) and the $28 OEM sensor from ticher or BMW north. If its just a simple 2 stage contact circut is there really a need to go OEM? I would appreciate any imput. Its not that much $ difference, but i like to save $$ where I can. Thanks for reading!
2006 330i E90 N52 -
Production 10/2005 |
12-29-2013, 09:24 PM | #3 |
Rep 1,491
I say OEM all day for this. I bought some aftermarket from Amazon and the biggest mistake ever. Yeah I saved $12 for the front sensor but as I was installing the sensor the interior pins are so poor quality that they bent and snapped off. So now what??? Car is lifted and need go get this completed, we'll I found myself at the dealer and just buying the OEM sensor. The savings are not worth buying a shitty product that might fail during the install. Save yourself the hassle and get OEM.
12-30-2013, 05:50 AM | #5 |
Rep 4,087
12-30-2013, 01:09 PM | #8 |
joseph
Rep 66
how do you bypass it?, just zip tie it up somewhere and cover the contact with tape or something?
2006 330i E90 N52 -
12-30-2013, 01:12 PM | #9 |
Rep 4,087
Cut the leads and short them properly, keep the connector plugged in. If you keep it short enough you don't even have to tie it off.
01-02-2014, 07:22 AM | #11 |
No 55mph
1619
Rep 8,476
I use the PEX Sensors from FCPEuro $13.99 for Front/$16.80 for Rear
Exactly as OEM and perfect fitment...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
brake, oem, pad, replacement, wear sensor |
