TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Misfires - Engine runs rough when cold, fine when warm
      12-03-2014, 11:38 AM   #1
synapse88
synapse88's Avatar
13
Drives: 2007 335i
I've been having misfires in my 2007 335i for about 6 months. 68k miles.
Symptoms - Runs rough after starting and driving cold, fine once the engine warms up. If I accelerate hard while cold, CEL comes on and the car runs very rough. I can reset the CEL by restarting the car, then I drive gingerly until engine warms up at which time I can drive like normal with minimal issues at worst.
What's been done - Replaced plugs. Fine for a day or two then same problems. Autozone codescan said misfire on Cyl 3, so I replaced that coil. No real change. My shop said it had a "fuel code plausibility"...took to dealer hoping for HPFP, but their computer said "Fuel low-pressure" sensor. Was quoted $380 and charged $500 to change the sensor, but problem is still there. BMW dealer also said *all* of my injectors need to be replaced, but they quoted $2k so I said no thanks for now (will have my shop do it if needed). Diagcode in question is D1350_00000000_01_02 - "All fuel injectors in cylinder bank 1 and cylinder bank 2"
I have a full set of coils. Should I change them all our or is that 100% not the issue?
Thanks for any advice!!!
Other fault codes identified by dealer:
DME: Combustion misfires, cylinder 3
DME: Misfire at low tank fill level (probably related to that sensor)
DME: Combustion misfires, cylinder 1
DME: Combustion misfires, cylinder 2
DME: Combustion misfires, several cylinders
      12-03-2014, 11:40 AM   #2
synapse88
synapse88's Avatar
13
Drives: 2007 335i
If the answer is: change all the injectors, is that a potential DIY job or is it pretty involved?
      12-03-2014, 01:07 PM   #3
cliffschum
16
Drives: 2006 330
What about adding a bottle, or 2, of premium fuel injector cleaner ?
Cliff
      12-03-2014, 01:15 PM   #4
synapse88
synapse88's Avatar
13
Drives: 2007 335i
^ No dice.
      12-03-2014, 02:28 PM   #5
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
I think your injectors are having a leaks my friend. It is doable for a DIY. You need to have them coded as well. DIY Section has this I believe.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      12-03-2014, 02:29 PM   #6
coriolis14
13
Drives: 2007 E92 328i
It can't hurt to change out the coils - I would do that before shelling out 2k for new injectors.
      12-03-2014, 02:32 PM   #7
coriolis14
13
Also, a cursory search turned up this on a DIY injector swap (N54):
http://www.e90post.com/forums/showthread.php?p=16958661
      12-03-2014, 04:09 PM   #8
synapse88
synapse88's Avatar
13
Drives: 2007 335i
Seems my injectors might be covered by a recall, potentially the same one concerning the HPFP.
Can anyone point me to the actual BMW bulletin or recall notice that I can show to my dealer when they inevitably tell me to get lost?
      12-10-2014, 10:36 AM   #9
vapore0n
Drives: 2010 335i
second post
http://www.bimmerfest.com/forums/sho...d.php?t=525852
      12-30-2014, 01:48 PM   #10
bavaddict
Drives: F32 435i MPerf Edit
Subscribed....OP any update on this?
I have identical issue to yours except in my case it is either cylinder 1, 2, 3 misfiring OR its ONLY cylinder 1 misfiring. Unfortunately, there is no pattern to it except that I can only reproduce it every morning after it has been standing in cold overnight.
Any insight will be appreciated. Note that in my case HPFP and all 6 injectors were replaced a while back and I have not had any issues till now. My thread is @ http://www.e90post.com/forums/showthread.php?t=1070123
Thanks.
335i, misfire, n54
