Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > E93 subwoofer install.
      10-06-2014, 07:08 AM   #1
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Anyone know a box that fits in trunk?
Anyone know about this install?
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/
      10-06-2014, 03:27 PM   #2
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
Looks good but in reality that setup will not sound very good. Bass will get trapped in the trunk. Either do infinite baffle through ski-pass or build an enclosure where the sub fires through ski - pass.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
      10-06-2014, 05:37 PM   #3
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
"Looks good but in reality that setup will not sound very good. Bass will get trapped in the trunk."
On what grounds do you have to support that claim?
I had a similar setup in my 235i and it sounded great, the bass does not get trapped in the trunk.
"Most trunk mounted subwoofers produce bass lines that easily travel through most materials that separate the trunk from the passenger compartment. The only scenario that precludes bass lines from penetrating trunk and seat materials is if a vehicle has been sealed and soundproofed."
      10-06-2014, 05:56 PM   #4
Wongway
Drives: 328i xdrive
I'm no audio expert, so it's mostly conjecture here and some anecdotal observations...
1) The corner loading benefit "I believe" is dependent on how high they are crossed over. If, for example, they had the sub crossed at 100hz, it's possible that the energy reflected off the front and back sides of the car create a standing wave that's beneficial to your output. Depending on the skill of whoever is designing the sound system, I've heard of people picking up 6-12db via just the standing wave.
2) This is also dependent on the vehicle, but in mine, I have no fold down seats and no ski pass through. So, the effect would be the same as if I put a subwoofer in another room with the door closed.
edit:
Also, (this is easily reproduce-able too) I've seen many vehicles who's subs sounded louder with the ski pass down, or the split folding seats down, so it's obvious that there is some drop off.
That drop off comes from backwaves cancelling your output. As subs fire back, you'll get output bounced back forward into the cabin. With corner loading, you'll have less backwaves to cancel your output.
edit:
It's because of the possibility of backwaves cancelling out sound that I think is why kaigoss69 loves his Infinite Baffle setup.
The theory is that the frontal cone is actually in the cabin of the car (through ski pass), using the entire trunk as one big giant box. The theoretical backwave would be sealed off from penetrating forward. So all you'd have is the frontal wave with no cancellations.
      10-06-2014, 07:37 PM   #5
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
I don't doubt that a front firing sub might be better, I just don't have the pass through, and I want something I can easily remove quickly in case I need the space. I felt that my last setup sounded pretty good:
https://plus.google.com/photos/11444...20718490276001
      10-06-2014, 09:09 PM   #6
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
You can do what you want, I'm just telling you how it is. Your trunk panels will rattle like a mofo, and the bass that you hear will be a fraction of what the subs put out.
      10-06-2014, 09:33 PM   #7
snaimpally
Drives: 2011 335i MT
2011 BMW 335i  [0.00]
You might consider the JL Audio Stealthbox for the 3 series which uses 2 of their slim line subwoofers in a rear firing configuration:
http://creativecaraudio.net/c/jl-aud...s_bmw_3-series
On the other hand, I have a Dynaudio Esotar 2 1200 mounted infinite baffle in the trunk firing through the ski pass and love it.
MusicarNW has some corner loaded enclosures that fit over the battery compartment. One of those with a Morel Ultimo 12 would sound great.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200
      10-06-2014, 09:34 PM   #8
SirHoward
SirHoward's Avatar
82
Drives: Da Car I Wanted
I like this setup right here. May look into this soon.. (go to #13)
http://www.e90post.com/forums/showthread.php?t=110075
      10-06-2014, 09:35 PM   #9
snaimpally
Says I don't have permission to view your album
      10-06-2014, 09:47 PM   #10
Wongway
Drives: 328i xdrive
Your best option.
Corner loaded would be second best (if possible)
Back firing is your worst option. The science is there to support it, so do what you wish from there.
I'm sure there's people that think I'm crazy for cutting up my doors with a subwooferless audio system, but I don't have to rationalize to anyone but myself.
edit:
Personally, if I were in your shoes with the convertible, and having done it already with my E90, I'd do this:
http://www.jehnert.de/en/shop/e92e93...y-soundsystem/
      12-24-2014, 06:41 AM   #11
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Since I already have a 12" sub, an amp and a box that fits, will try the install and see how well it works. I may have to remove the fake partition for my non-cold weather pass through to improve sound.
      12-24-2014, 07:40 AM   #12
Isaiah5411
Isaiah5411's Avatar
Drives: 2008 Montego Blue 328i E93
I just built my own for a single 10" and it sounds great, even though the internal volume is a little under spec at 0.68 cu ft (with 0.75 being the min recommended volume for a Diamond D3 10"). But...I like tight, accurate bass.
Just remember: You have a maximun clearance of about 13" (closer to 13.75" but...) for the height of a sub box in the trunk of an E93 when it's up against the back seat like mine in order to get the roof in the trunk (which I found out the hard way). !
http://www.e90post.com/forums/showthread.php?t=1071029
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11)
bass, subwoofer
