What harness will I need
01-31-2014, 06:33 PM | #1 |
Rep 572
Hi guys,
I want to connect a JL Audio 250/1 amp to my under seat speakers, don't really want to cut/splice any wires. Is there a harness available for this? links would be appreciated Cheers |
01-31-2014, 08:29 PM | #2 | |
Rep 5,120
Or you can make a harness. You need the following from the dealer. Woofer housing: 61136901731 (2) Woofer housing pins: 61138364835 (8 for base, 4 for logic 7 or hifi) Woofer socket: 61136984750 (2) Woofer socket pins: 61138364838 (8 for base, 4 for logic 7 or hifi) You also need: Speaker wire Line output converter http://davidnavone.com/product/n-rhl...put-converter/ Wire strippers, crimpers, etc You would be extending the underseat speaker wires back to a line output converter in the trunk then running new speaker wire to the underseat woofers. |
02-10-2014, 10:25 AM | #5 | |
No 55mph
1621
Rep 8,476
The stuff he makes is hi quality, EX to install, & worth the $$
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
e92, subwoofer, under seat |
