Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Review: Dinan Stage 2 Suspension (E90 335xi)
      05-03-2010, 10:29 PM   #23
808AWD325xi
Ballin' out of control.
808AWD325xi's Avatar
520
Drives: 2009 335i
Originally Posted by ska325xi View Post
I didn't see stage packages for the xi but do see some individual parts for suspension
Maybe dinan hasn't update their site
ska325xi, here are direct links to the 2006 E90 325xi suspension packages. Hope this helps.
Stage 1:
http://www.dinancars.com/store/produ...cat=311&page=1
Stage 2:
Stage 3:
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
      05-03-2010, 10:33 PM   #24
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
But it states...Special Notes Not applicable for xi models.
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      05-04-2010, 12:06 AM   #25
808AWD325xi
520
Drives: 2009 335i
Gotcha, that's confusing as the page/category is for i, xi. It might be worth calling Dinan directly. It's hard to believe that an '06 E90 xi has a radically different suspension from an '06 E90 i or a '07 xi.
      05-04-2010, 07:57 PM   #26
Garth
Garth's Avatar
Drives: 08 e92xi/02 Z3 3.0i Roadster
My 08 335xi with Dinan stage 1
http://www.e90post.com/forums/showthread.php?t=288980
      05-04-2010, 08:04 PM   #27
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Garth, very nice...this is the type of stance I'm looking for
can you tell us more details...spec, price, short review?
2006 325xi (Sold)
      05-05-2010, 10:41 AM   #28
Garth
Garth's Avatar
http://www.e90post.com/forums/showthread.php?t=372292
      05-06-2010, 02:44 PM   #29
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
Local Dinan rep confirmed that Dinan hasn't, and probably never will, release front strut replacements on xi cars or any of their xi suspension pkg's. The reasoning is the demand isn't high enough for Koni to design a shorter strut just for the xi models.
      08-06-2010, 10:20 AM   #30
cshawkeye
cshawkeye's Avatar
Drives: 2020 X3M
About to throw on the stage 3 suspension onto my 335XI, I will let everyone know how that goes next weekend once it is done.
      08-07-2010, 03:33 PM   #31
808AWD325xi
520
Drives: 2009 335i
Sweet. Good luck.
E90?
      08-07-2010, 03:48 PM   #32
cshawkeye
cshawkeye's Avatar
Drives: 2020 X3M
Yup 2007 335XI.
      08-18-2010, 11:43 AM   #33
gobrigavitch
22
Drives: '09 E90 M3 JZB
Any update on the stage 3
I'm really curious to find out your thoughts
      02-11-2011, 04:03 PM   #34
Eric335xi
Eric335xi's Avatar
Drives: '10 335i xDrive
Any update on the Stage 3 install?
Is the bigger rear sway bar worth the extra $370 over the stage 1 kit? Just looking to get rid of the lifted look and tighten up the handling a smidgen. Wouldn't mind getting rid of the bone jarring when hitting bumps either, do the Dinan springs really give it a smoother ride?
      02-12-2011, 07:50 PM   #35
sterz85
sterz85's Avatar
Drives: '07 328xi
so if the struts are the oem ones, can we piece together the rest of the kit? or which other springs will give a similar drop?
      02-25-2011, 04:10 PM   #36
DashboardDave
Drives: 335i X-Drive
Love the Dinan Stage 3
It has been a couple of months since I did the upgrade, but wanted to update everyone.
Bottom line: it has been fantasic. The suspension seems to have "settled in" a bit and the car handles beautifully.
The Blizzaks were fantastic, and got me home fine during the recent snow disaster here in DC.
You can read about the stage 3 process here:
http://www.e90post.com/forums/showthread.php?t=429402
      02-25-2011, 04:23 PM   #37
Malapropism
Book Worm
Malapropism's Avatar
Drives: F82 M4
Wow, loving the looks with the Dinan suspensions - 808AWD325xi, Garth and DashboardDave's cars all look stunning.
Just order my '11 335i coupe with xdrive arriving in June. To get the front the lowest using the Dinan suspensions, which stage should I go for? I've heard rumours that the Stage 3 camber plates add a bit of height? I'm thinking about stage 2 atm...
      02-26-2011, 08:40 PM   #38
rbeck
Drives: 328xiT
Dinan 335xi suspension and Koni struts
I have been following this thread for a while, as I'm hoping Dinan will come up with a kit for the Touring. Anyway, as far as the Koni Yellows for the front of our xi's, there is a strut listed on the Koni International site. They've been available since late fall.
      03-01-2011, 07:59 PM   #39
Killer
Killer's Avatar
Drives: 2002 Porsche Boxster S
True, the part numbers are 8741 1535LSport and 8741 1535RSport.
Now find me an online retailer that sells them in North America...
      03-05-2011, 06:21 PM   #40
rbeck
Drives: 328xiT
Well, they are showing up on the Koni NA site now. No price though.
      04-06-2011, 01:59 PM   #41
335xidave
Drives: Dinan3/335xi
I had the Dinan Stage 2 put on last year,,fricking great in the mountains! Lowerd about 3/4' all around. can't wait to get rid of the run-flats!
      04-07-2011, 12:26 AM   #42
Eric335xi
Eric335xi's Avatar
Can you put up some pics? Would like to see more cars with the Dinan suspension.
      04-07-2011, 04:07 PM   #43
335xidave
Eric,,I'll see what I can do,,,kind of a geek about that stuff
      04-16-2011, 09:42 PM   #44
kdiggz
kdiggz's Avatar
20
Drives: e92 ///M3
so what kind of springs does the dinan kit use? sounds like you could potentially piece together the kit yourself for much cheaper yourself
edit: so it uses the "bmw performance springs"? so why spend 1300 if you can piece this togehter yourself for so much cheaper? also, the part numbers for the front koni shocks r still listed on the website without a price. hopefully that means they are coming soon
dinan, suspension, xdrive
