BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > jb4 g5 iso logs
      05-23-2013, 12:19 AM   #1
iturbo_bmw
iturbo_bmw's Avatar
Drives: 335i, 530i
jb4 g5 iso logs
So i finally got a chance to do some logs. This is the first time since I've done it so I have no idea what that means and I'm hoping some one nice here will help me out with some questions.
My car:
2009 335i e92 43k miles
JB4 G5 ISO 20d Map 1
BMS DCI
Alpina flash was done earlier today
Had a quarter tank of 35% e85 before filling up with 91 so I'm running less than 10% e85 on these logs
1. First off, how do my logs look? Any cause for concern? I have no idea how to read this and can't really find any info on where to learn
2. Did i log the right information (trims, afr, pre-boost...those things)? What information should I be logging? Am i basically looking for any knocking? if so, how?
3. I was told my fuel looks pretty bad. this is 91 mixed with 10% e85 so i guess a little better than 91. since 91 is all we get in cali and I cant run e85 any time should i look to get the cps wires installed? Also I ordered the cps wires a long time ago and all i got was 2 small green wires..Is that really all i need to activate the cps?? Will cps even help? Are there any other solutions?
I'm trying to get my car running the best it can on 91 and map 1 cause i do not want to run e85 all the time. When i do get e85 i put 35% on map 5 and my car is much faster but I'll worry about those logs after i deal with these.
I did two runs. Here are the pictures and i've attached the csv files (nvm guess i cant upload csv files.
Thanks in advance for your help!
      05-23-2013, 12:27 AM   #2
enrita
enrita's Avatar
Sweden
159
Drives: 335i - Big turbos
Timings looks not so good . Use map 5 instead. U have pretty shitty gas. Try running 20-30% e85 mix .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      05-23-2013, 11:13 AM   #3
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
+1
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      05-24-2013, 03:56 AM   #4
iturbo_bmw
iturbo_bmw's Avatar
Drives: 335i, 530i
Thanks for your help!
cps, jb4, jb4 g5 iso, logs
Search this Thread:
