Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Problems with Surging/non-smooth feeling when cold
      08-07-2013, 02:56 AM   #1
Ryan335i
Drives: 2007 e92 335i
Lightbulb Problems with Surging/non-smooth feeling when cold
My problem is when I am in any map (JB4 ISO G5) apart from stock it is not smooth like stock.. very lurchy in first and when changing into 2nd it hesitates briefly like a missfire or stall ?? very weird.. I think I need to change the plugs at minimum and possibly coilpack #1 because it had thrown a Service Engine Soon light while I was WOT but then the light went off as I was crusing. I did not stop when the light came on. i just put it back in drive and went the speed limit (45) then after about 3-5 miles it went off and drove normally.
Also at part/low throttle in D or DS (when JB4 Active, I only ever run Map 1 or 5 all I have is DCI) the car has a very uneven surge type feeling compared to when in stock Map 0.
I'm think my solutions could be to change to coil pack one bank 1 (Cyl 1) as well as ALL of the spark plugs
because I went into my mech so he could diagnose the codes because i did have the JB4 check for codes and it did find them.. I didn't know at the time that I could read them without a computer myself..
I was also considering an intake valve clean via walnut shell blasting.
My final thing I can think of to resolve the surging uneven feeling on wot is to update the firmware of the JB4. I purchased mine off the forum so i'm not sure what version it currently has on it. I have the bms cable to be able to connect and update firmware, I just dont have a pc or have the cable connected. Do you think these fixes could resolve the problems I'm having?
any help would be much appreciated... short of sending a log to terry@BMS.
Kind Regards.
Update:
I Just put in Lucas Oil "Deep Clean fuel system cleaner" to my tank. I thought I was noticing a bit a difference, but while racing a Supra today (I Won, JB4 Map5 + BMS DCI) I, probably got up to about 80mph before hitting traffic up ahead at the lights.. I experienced a ServiceEngineSoon (SES) light right after the run. I put trans back into D continued to drive down the road and when I came to the next set of traffic lights my car was idling rough (like what I would call a missfire).
I then, against my better judgement, continued to drive to my intended destination. and then about 2 miles later, 4mins with traffic, the light went off and the car ran normally.
I have since been timid to go WOT until I get a better idea of what is happening, but I have gone about 50% throttle with no problems.. Car seems to start fine as well.. Just rattles like a sumunabitch! (Not turbo/wastegate related as far as I Know as the rattle goes away after a short period of time and it does not resonate with the engine when revving slightly (3k max).
Please Brainstorm with me people!
      08-07-2013, 03:57 AM   #2
ashmostro
Drives: 2020 M4cs | 2022 M550i
What firmware version are you running on the jb4? Certain recent versions had surging issues that have since been addressed in the latest updates.
      08-07-2013, 10:03 AM   #3
n54door
Drives: 09' 135i 6AT FBO - MHD Tuned
Pull the codes - it sounds like you're misfiring.
      08-07-2013, 01:13 PM   #4
gzim335
gzim335's Avatar
Drives: e92 m3
2007/1 e90 335i  [2.00]
how many miles on ur plugs?I used to get that on my old plugs,when tuned u should change them every 15-20k
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth
kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery
      08-07-2013, 01:14 PM   #5
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
http://www.e90post.com/forums/showthread.php?t=631829
coil, injectors, jb4, spark plug
