TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Manual Window Roll up
      10-31-2013, 02:33 PM   #1
mikolo-n54
Drives: 07 e90 335i
Look like my rear passenger side window regulator has stopped working and now the window is stuck down. Can I take off the door panel and manually roll it up until my regulator comes in the mail?
      10-31-2013, 03:25 PM   #2
jhcao1472
Drives: E90
keep trying to roll up the window. It happened to me, too.
      10-31-2013, 03:30 PM   #3
mikolo-n54
Drives: 07 e90 335i
I've held the button for like 30 sec and got the window anti trap error... Seems like the only way to get it up is to replace the regulator. I've heard slamming the door might help. Did you end up just replacing the regulator? The motors is making a sound like it tries for a second but it dosent go anywhere..
COBB||VRSF||BMS
      11-01-2013, 02:36 AM   #4
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
If you're gonna take the panel off to try to manually roll up the window, might as well just replace the window regulator when you're in there?
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      11-01-2013, 05:44 AM   #5
ssmith96
Drives: 07 328xi
Mine is like that and I just gently flick the control upwards every few seconds and it eventually goes.
      11-01-2013, 11:32 AM   #6
mikolo-n54
Drives: 07 e90 335i
Waiting on regulator, just don't like my window down, especially on the freeway. I was able to jimmy some tap on the regulator and holder to stay up until I get the regulator.
COBB||VRSF||BMS
      11-01-2013, 06:41 PM   #7
jhcao1472
Drives: E90
Once you get the window trap symbol, just roll up the window slowly.
      11-03-2013, 07:33 PM   #8
thakid22
Drives: 2021 Bmw M340i M-Sport w/ VDC
Do you have a tuning cable?
I have found that INPA can electronically reinitialize and then roll up the window from within the software.
If you let the window all the way down again, you'll have the same problem again.
To prevent this, stop the window about an inch before it goes all the way down. It won't get stuck.
If your window is down and you need it up NOW...
Take a pair of needle nose pliers and grab the window in the door. Pick a point close toward the b-pillar end
of the door. Pull the window upward gently and then use the switch to get it to raise up at the same time.
#works like a charm
      11-03-2013, 08:31 PM   #9
paddy335
Drives: M140i;X5 40d
It seems there is nothing that you can't find advice on in these forums
      11-03-2013, 11:01 PM   #10
fedorE90
Drives: 2007 335i
If the regulator broke you might need to take the panel off and force the window up. If the wire snapped you'll have to take the regulator off to roll the window up. Its a pain. Both happened to me even after replacing the regulator. Now I just don't mess with the rear windows. I don't know whats wrong. Maybe tint.
      02-16-2014, 05:37 PM   #11
tman
tman's Avatar
44
Drives: 2014 i3 BEV
2014 i3 BEV  [0.00]
Mine got stuck in the down position today. Might of been cold related But anyway, doing the continuous flicking did it. Got it all the way up. Will have to keep an eye on it now. Thanks!!!!
OMG! Born Electric 10/17/2018!
2014 I01 i3 BEV
2011 E91 328i xDRIVE TOURING
| 2010 F83 X3 3.0i xDRIVE | 2006 E90 330i 6MT (Ret)
335i, e90, window regulator
