Golf Tee Mod - Dyno Request
12-17-2012, 02:36 PM | #1 |
52
Rep 393
I know there are tons of threads out here already regarding the golf tee mod and the effects it has on performance. I don't want to start an opinionated debate here. Rather, I was wondering if anyone has dyno results of the same vehicle with as well as without the mod.
In many of the threads I have seen, people claim that they have seen dyno results or have done them themselves. Some people believe that this reduction of back pressure reduces torque and I wanted to see actual results to back this up. However, others have said that this has no effect on torque and the flap is only used to reduce exhaust noise. Can someone chime in with their results? Thanks |
12-17-2012, 03:01 PM | #2 | |
Rep 5,538
flap is there to warm up the cats and it has no effect on any performace so doing dynos is pointless. |
12-17-2012, 03:11 PM | #4 |
Daily Driven!
186
Rep 2,516
Drives: BMW 335i
Is this a serious thread? Wtf?
12-17-2012, 03:13 PM | #6 |
Daily Driven!
186
Rep 2,516
Drives: BMW 335i
No it'll only provide a large surplus of power!! Probably a good 70+hp |
12-17-2012, 03:21 PM | #7 | |
52
Rep 393
Thanks |
12-17-2012, 03:55 PM | #9 |
124
Rep 2,554
12-17-2012, 04:32 PM | #10 | |
Gateropode
329
Rep 2,848
If you tell me that the Tee mod prevents the cat from reaching operating temperature, that has the potential to clog it, and fail the emission test later down the road (or not, hence the question). |
12-17-2012, 04:41 PM | #12 |
Daily Driven!
186
Rep 2,516
Drives: BMW 335i
So I just removed my rear seats and was wondering if anyone has a before and after dyno sheet...
Also will this harm my cats? |
12-17-2012, 04:59 PM | #13 | |
Rep 5,538
thats also one of the reasons all manuals will tell you NOT to warm up the car and instead just start driving. they dont want you siting in the parking lot polluting the air |
12-17-2012, 05:58 PM | #15 |
Rep 80
So to add on to the noob questions. It's easy and I'm lazy, so is there any harm in just unplugging the plug in the driver side taillight? Or do I have to crawl under my car and shove a golf tee into the line?
12-17-2012, 07:02 PM | #16 | |
Rep 1,014
Tubing clamps are a better solution. http://www.grainger.com/Grainger/tub...071&sst=subset |
12-17-2012, 07:16 PM | #17 |
Rep 5,448
It has nothing at all to do with emissions or it could not be legally disabled - PE exhaust would need to say for off road use only if disabling the flap messed up emissions and a non functional flapper would need to set the check engine light if it was part of the emissions requirements.
It is purely to pass the noise tests at certain RPM's that sound levels are measured at, then can open to allow more flow and better sound at higher RPM's. Torque - no difference, that is controller by how quick boost is built and how high boost pressure is, that is controlled by the wastegates.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
12-17-2012, 07:34 PM | #18 | |
Rep 450
06 330i 6mt Spt- Eibach Springs, BMW Perf Susp, Supersprint Exhaust, BSW Audio
RIP-94 325i 5mt 4d- M3 springs/susp, Z3 wheels, Chipped, Intake, Exhaust= FUN! |
12-17-2012, 07:51 PM | #19 | |
Rep 5,538
PS. BMW tech told me its to heat up cats. Everyone who done gold tee mod done it for abit more noise that's why everyone is saying its to reduce noise. I know some cars use butterflies to control noise, others to regulate back pressure, it just might not be the case with 335i Last edited by Kolyan2k; 12-17-2012 at 08:07 PM.. |
12-17-2012, 09:08 PM | #20 |
Rep 5,448
Thank you for your email to BMW Customer Information.
We can advise that the exhaust flaps adjust at differing engine speeds in order to make the most effective use of the exhaust silencer. When the vehicle is running at idle or at low RPM, the flap ensures that the exhaust gases use as much of the silencer's volume as possible, keeping exhaust noise down, e.g. when you're in slow traffic or driving in high gear. Whereas when the vehicle is running at high RPM, the exhaust flow characteristics are adjusted by the flap to give the exhaust gases a more direct route through the silencer, thus using less of its volume. This also has the effect of allowing the engine to rev more freely as there is less restriction on the exhaust flow. The primary reason for the flap is to make the most effective use of the exhaust silencer volume at differing engine speeds. We trust this information is of some assistance to you but if we can help you further at any time, please do contact a member of the BMW Customer Information Team. Yours sincerely BMW Group
12-17-2012, 09:36 PM | #21 | |
Rep 1,014
Not saying it couldn't have more emissions than without a flap, but it is legal and fully warranted and if I cared I'd own a Prius anyway. |
12-17-2012, 10:03 PM | #22 |
Rep 5,538
Why wouldn't it pass emission... its just a flap, even if you remove cat completely it will still pass. It has nothing to do with passing state inspections. Every car manufacture is trying to make their cars greener
dyno, exhaust, flap, golf tee mod |
