BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Baseline Dyno
      09-16-2013, 11:55 PM   #1
jeffblue
27
Drives: 2008 BMW 335xi
Baseline Dyno
i went and got a baseline dyno on my 2009 bmw 335 i xdrive 6mt. This was done at Tach Motor Works in Oceanside, NY. I don't really care about dyno numbers in general, but i do like to know the delta so i did a bunch of before and after testing/logging so i figured i'd share my results here.
There were 3 pulls done. first was a 5th gear pull with cobb stage 1 aggressive(not shown) The second pull was 4th gear cobb AP Stage 1 aggressive map and the third pull was base map 4th gear pull. No bolt ons. at the time of the dyno. I logged the runs on my cobb AP and there were a ton of AIT based timing corrections even on the stock map as expected. For this reason the Cobb stage 1 aggressive map was able to pick up 110lb/ft however only about 20whp because AIT based timing corrections seemed to kick in above 4k rpm when the car would otherwise start to make more hp.
Later that night i logged 3rd gear pulls with the cobb stage 1 on the street in order to establish a 'street' baseline before installing my FMIC and UR intake.
After installing spearco Code 3 intercooler and UR intake i logged 3rd gear pulls with the cobb stage 1+ aggressive map and plotted them in virtual dyno and overlaid it against the baseline stage 1 aggressive map pull i had done prior. The car picked up another ~23whp and ~16tq. Ambient temps were about the same approx 70 deg F in each run. As expected, fewer AIT induced timing corrections due to less heatsoak with the upgraded FMIC allowing the car to pick up more top end power.
335i xdrive, baseline dyno, cobb, dyno
