Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > FULL REVIEW -- white LED side markers -- GP Thunder 7500k V2 Fog lights --
      04-09-2011, 04:30 AM   #1
gaifaun
gaifaun's Avatar
207
Drives: E90 335i LCI
Thumbs up FULL REVIEW -- white LED side markers -- GP Thunder 7500k V2 Fog lights --
Service and packaging:
Derrick provides great service time and time again which is why I am a repeated customer of his. Shipping may take a while but I'm totally fine with waiting; it could be I live in Canada and First Class Mail International (USPS) is slow. He packs his stuff filled with peanuts so the bulbs are nice and safe.
Products:
Theres 2 things in which I will be reviewing today: White LED side marker bulb replacements and GP Thunder 7500k V2 Fog lights.
White LED side marker bulb replacement:
I don't understand why people would waste $40 or $50 to buy a set of LED sidemarkers with aftermarket lens unless it is smoked. This is why I chose to keep things as OEM as possible and just bought replacement bulbs for $5.99 from Derrick. Very economical and error free!
The bulb is clear in color which is a plus because the stock ones are orange and they show through the lens. This LED bulb is cleaner and more "stealth" if you will.
Many will choose to upgrade to LED's because they are crisper and have faster "on and off" speeds compared to the "glow" a traditional bulb offers. My car is a E90 LCI and all indicators are LED except for the sidemarkers hence this upgrade.
Its hard to find on E92-Lighting's website so i have the link here.
http://www.e92-lighting.com/products/194_1DW-89-0.html
At this price there really isn't anything to complain about, and there isn't.
Install
it is as easy as swapping your drop-in air filter for your OEM intake box.
1) grasp the lens and push BACK towards the rear of the car
2) wedge your fingernail at the front of the lens and pry up to free the lens from its locked position.
3) wiggle the assembly out
4) lift the white tab with a small flathead screwdriver.
5) twist clockwise. the lens will be removed after this step.
6) pull stock bulb up and out with fingers
7) insert new LED bulb in (it is polarity sensitve and it can only work 1 way, so when you insert the LED bulb, turn on your hazard lights to see if the LED turns on. If not flip the bulb around and retest.
8) reverse the previous steps to reinstall
All in all this is a piece of cake and literally took me 1 minute to do per side.
Results
BEFORE
AFTER
Brightness is about the same stock vs LED. I have no regrets for this upgrade and there are many colors to choose from, I just so happen to have chosen white. Next time I will try Amber.
And there are NO ERRORS!
watch the youtube link to see the blinking in action!
__________________________________________________ _______________
I have reviewed the GP thunders in the past for Angel Lights and these are absolutely a bargain for the performance and looks it can offer.
Now however, I will be putting these H8 bulbs in as fog lights. (E90 LCI models use H8 for fogs, same as AE's). Granted it is not as bright as stock bulbs because of the higher color temperature but there is barely any fog in my area and I did it mainly for looks and to color match my AE's and Xenons. the GP's emit a bright white color with a very slight bluish, greenish tinge to it compared to stock which is bright yellow white. the output is still the same as stock at 35w. for the record the stock units are Osram branded.
If your area always has poor weather conditions, maybe get HID's or a 3000k temperature replacement bulb. But these do the job in my side of town and I love the color match.
Stock (left) GP Thunder (right)
Install
This install in my opinion is similar to the AE's, not as tricky but it involves you getting down on your knees and taking out 6 screws per side, from your bumper.
I followed this guide to remove the screws from my bumper. (thanks zzzbullseye)
tools needed: 8mm socket wrench or ratchet
my instructions:
1) turn the wheel all the way to one side
2) remove 4 screws from underneath the front bumper (refer to guide)
3) remove 2 screws from fender lining
4)depress small black tab underneath the bumper while pulling at the fender lining to reveal the fog light
5) locate foglight (its dark in there) and pinch the base of the fog light connector HARD to unclip the tabs.
6) pull down while pinching to remove the fog light connector
7) twist counter clockwise and remove bulb
8) replace bulb and reverse steps to complete install
This is the connector I'm talking about. PINCH at the base of the clip HARD and PULL or else you can never unplug it from the bulb. I learnt the hard way...
this is what the connector looks like.
It took me about 20 minutes to do 1 side after i figured out the way to unplug the connector from the bulb. its not a hard install at all.
Results:
Both sides installed GP thunder
Note the color difference is visible between the LED angels and the GP thunder fogs
I'm very satisfied with these fogs! Color match is around 85% and the color appears to match more or less depending on lighting conditions. Its hard to capture the color differences and it is more noticeable in person. When it is dark, LED's are more blue and the fogs are more white. During the day the color match is spot on and difference is negligible as you seen in the day time pic. Granted no halogen bulb will match LED bulbs 100% because they behave differently in different settings. In conclusion, a solid product and is definately a good buy.
I'm not sure how these will stack up to Mtec's 4300k bulbs so I cannot comment. however, performance wise I am sure they are the same. The reason I didn't go with GP thunders 8500k is because I didn't want to suffer too much from a decrease of light output. It will be too blue. this is perfect, nice and white, no more ugly yellow.
I can help with Coding in Vancouver. PM me
      04-09-2011, 12:42 PM   #2
lpphreakx06
Professional Moose Racer
lpphreakx06's Avatar
Vietnam
316
Drives: SG 335i E92 RIP + 2015 SS M3
Wowo, I really like the fog lights.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1
|HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM
      04-09-2011, 01:26 PM   #3
KC335
Drives: E93 335i
Great review as always. The fog lights look great!
      04-09-2011, 03:36 PM   #4
qclik
qclik's Avatar
Hong Kong
23
Drives: e92
weird my fog light looks more blueish than yours. yours looks really great
      04-09-2011, 04:44 PM   #5
natelam
Drives: 08 e92 335i SG MT
nice i love the gp thunders
      04-09-2011, 11:16 PM   #6
JTO24
never could compete with Lloyd Braun
JTO24's Avatar
Drives: 2022 G80 M3 6MT
Awesome write-up! Your lights look great.. all of them lol
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold)
2016 981 Cayman 6MT | Jet Black (sold)
2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold)
2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold)
      04-10-2011, 01:25 AM   #7
gaifaun
gaifaun's Avatar
207
thanks! you should change to this set when you get bored of your yellow fogs
thanks for liking all my reviews! there will be more no doubt.
really? this is my second set of GP thunders 7500k and they produce the same color. talk to your vendor and see what he can do.
word. best bang for the buck. quality is great too!
thanks! I rmb you read my thread about City Visions and got a set in the end now go get GP thunder fogs!
I'm pretty happy with the color match. wait for a LUX review next
      04-10-2011, 08:36 PM   #8
Hasek9339
Hasek9339's Avatar
48
Drives: 2009 328i Montego Blue
I can't wait for the new H8 review!
I just ordered the Amber version of the side marker lights that you ordered along with the same fog lights!
I also ordered a color matched reflector as well!
I can't wait!!!
      04-10-2011, 11:42 PM   #9
Dr. G
Dr. G's Avatar
278
Drives: Black e92 335i
e92 BMW 335i  [8.84]
Another great review from gaifun!
I will definitely buy the sidemarkers ASAP! haha, I never knew this cheap option was available.
I have the 7500k fogs, I will be installing them with an 8500k and seeing if I can capture the colour diff on cam.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
      04-11-2011, 08:26 PM   #10
gaifaun
gaifaun's Avatar
207
I can't wait!!!
I will keep you guys posted
yeah, i'm curious to see how the amber version is too! it be awesome if you took some pics.
thanks man! I was surprised too! this has to be one of the cheapest mods to do. Albeit it may not be as bright as the $70 Weisslicht ones because those have 3 LEDs compared to just 1 LED replacement bulb, you can't really argue with $5.99 list price...
I've been driving around during the day and I see that the stock amber bulb is more visible in sunlight because the LED is white. I may have to try the amber ones later on!
as for the 7500k fogs, its a very good match with the Xenons but it matches the LUX less because the LUX is a bit more blue. I think the 8500k would match the LUX nicely. Do the review and comment about the light output of the 8500k! I'm concerned with the loss of light output the higher in color temperature you go.
      04-11-2011, 11:00 PM   #11
sky~
Drives: 328i
waiting for lux h8 review.
      04-14-2011, 02:02 AM   #12
qclik
qclik's Avatar
Hong Kong
23
Drives: e92
just check the box of mine gp thunder and it said 8500 color temp, maybe thats way its looks blueish, and didn't match with my oss
      04-14-2011, 02:19 AM   #13
Dr. G
Dr. G's Avatar
278
e92 BMW 335i  [8.84]
Hey, I just got the OSS too, what fogs have you tried so far? Any good matches?
      04-14-2011, 03:01 AM   #14
qclik
qclik's Avatar
Hong Kong
23
Drives: e92
Only tried the gp thunder that i replaced with oss from AE. I think there is a post here discuss about foglight that match oss, too lazy to search it for u lol
      04-19-2011, 02:44 AM   #15
johnsonz1122
19
Drives: f30 335xi
gp thunder looks nice. but mine blew out today , suckss
13' F30 335xi mods are on their way
09' E90 LCI 328xi (GONE, BUT NOT FORGOTTEN) 19" m310,quad conversion perf exhaust, full mtech conversion, m3 sides, kwv1,etc
PICS:http://www.e90post.com/forums/showthread.php?t=757811
PM me if you need coding for f30s in GVR
      04-19-2011, 12:14 PM   #16
Ferg
Master of my own domain!!
Ferg's Avatar
153
Drives: F82 M4/F15 X5
Do the side marker lights flash upon startup?
      04-19-2011, 09:34 PM   #17
gaifaun
gaifaun's Avatar
207
after uni finals
that explains it. yeah 8500k will result in even more loss of light output. bluer and slightly dimmer than 7500k.
really? i have 2 sets and they haven't failed me yet. anyways if it did, just get a new set lol. they're dirt cheap. General rule of thumb. turn on the bulbs and leave them on. don't turn them on for a minute and shut it off after. you'll increase the chance of a halogen bulb's failure.
nope. not flickering if thats what you're asking. they do flash twice when i unlock. flash once when i lock, just like OEM.
i can't wait to test amber versions, hope they will be more visible during the day since its amber in color!
      04-20-2011, 12:06 AM   #18
Mr_PharmD
Drives: 335i coupe
I was looking online for the GP thunder and ppl are selling it with a different box.
Is this the same ones?
      04-20-2011, 03:19 AM   #19
gaifaun
gaifaun's Avatar
207
those are not quite the same. the ones you posted are Version 1.
the one i reviewed is Version 2. supposedly to be a bit brighter, and made with new materials, or so it claims.
      04-20-2011, 08:51 AM   #20
Mr_PharmD
Drives: 335i coupe
can u pm me the price u paid for them and where?
      04-20-2011, 01:50 PM   #21
gaifaun
gaifaun's Avatar
207
PM'd.
sorry guys i forgot to mention i got it from E92-Lighting.
      04-20-2011, 09:33 PM   #22
johnsonz1122
19
Drives: f30 335xi
ya they r pretty cheap .. but it's a pain in the ass to buy them from the vendor. it's gonna take a while. neways. i guess i will try mtec 4350k this time. see how it works
fog, gp thunders, led, review, sidemarker
