PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Wheel Spacer Question - Please Help
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
12-02-2013, 05:07 PM | #1 |
Rep 548
Ok guys, so im new to the whole wheel and tire world and I really don't understand much when it comes to it. I'm currently on stock style 339's 17" I believe, with xdrive on my e92 coupe. I want to purchase wheel spacers to give my car that more aggressive "fatter" look however I'm worried about the effects on the car. So I have a few questions -
1) With my stock suspension and wheels and RFT's would it be safe to run 10/12mm spacers on the front and 15mm spacers on the rear? I'm completley guessing on this so that brings me to my next question 2) Is there a way to measure what size spacers I should get ? 3) After installing the spacers would I need to get an alignment or anything ? 4) Would i need to worry about rubbing when going over bumps or dips or worry about shaking at highway speeds? Btw I am looking at the Renn Motorsports Lightweight Spacers. Please help me out guys, I'm lost on the topic and the more I read the more I get confused. Thanks for any help |
12-02-2013, 07:46 PM | #2 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
1. yes it is safe. I would try to stay away from anything over 20mm though. Your setup is fine.
2. Measure the distance between your tire and fender and see how much space you have. Remember if your fenders are not rolled, then measure to the inner fender lip. 3. No alignment needed. Only after suspension mods. 4. Nope not at all. As long as your do not get over sized spacer. No shaking as long as the spacers are hubcentric. |
12-02-2013, 09:16 PM | #3 | |
Rep 548
12-03-2013, 03:14 PM | #4 | |
2037
Rep 25,989
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
12-03-2013, 04:51 PM | #5 |
Rep 241
great info on spacers here.
12-04-2013, 11:41 AM | #7 |
60
Rep 341
Thanks to the op for posting this, now I know what to do with my oem wheels this winter to make it look a little better. Will hold off on my aftermarket install till it gets warmer.
My only question is does it matter what brand of spacers to put on? |
12-04-2013, 11:55 AM | #8 |
Rep 548
From what I have learned from reading on these forums , as long as they are hubcentric and wheel-centric any brand would work, of course higher quality spacers will probably be better in the long run
12-04-2013, 05:32 PM | #9 |
60
Rep 341
Thanks this option will save me alot of money on buying all season tires for the aftermarket wheels I bought a few weeks ago that had summer tires.
12-04-2013, 05:42 PM | #10 |
U.S. Marine
Rep 55
The spacers from Burger motor sports come with extended lugs bt dubbs..
06' Alpine White 325i | 18x8.5 Malloy 5's | H&R Sports | BMS 12,18MM | M3 Front Bumper |
12-04-2013, 06:12 PM | #11 |
60
Rep 341
12-16-2013, 09:04 PM | #12 | |
310
Rep 3,572
Here is a good video you can use as reference: No need for alignment, since your camber/toe spec is the same. Always use hub-centric spacers to avoid wobble and shaking, and always leave a bit of space so you wont rub. Also, we have a good promo on the Renn Spacers. So definitely take advantage of it. |
12-26-2013, 02:37 AM | #13 |
Rep 4
i am also new in to the tire and spacers but i am running stock rims and tires on my 07 335 e90 and i'm trying to achieve that flush with the fender look when i measure the back tire i have 31mm distance and 12.7 mm front to make them flush but i'm worried about rubbing on the fender and i wanna know how close i can get before i have any rubbing issues any help?
spacers, wheel spacers, wheels |
