Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > e90 vs e92 gas pedal - need help
      06-03-2011, 04:49 PM   #1
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
Hello,
Ok i have e92 335i 2007 AT with jb4.. and today i was driven my mother car e90 335i 2007 AT stock and i feel that e90 pedal is aggressive.. you little press down it and feel power...
So after that i back to my e92 and tried play with my car pedal .. amm what can i say: it is not aggressive - pedal need time to react ... kinda some lag..
So my question is: How can i do aggressive pedal? Or this is something broken on e90? Or on my e92? Or maybe i need gear box reset ?
Thanks!
      06-03-2011, 05:43 PM   #2
Syndicategt
Syndicategt's Avatar
Drives: 335i
Maybe your mother has a heavier foot? Reset the adaptation on both cars and it should be equal unless you are running 2 very different DME versions.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
      06-04-2011, 03:15 PM   #3
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
haha no...
I have done gear box reset.. but still not same as e90...
Any info how can i do my gas pedal JERKY ?
      06-04-2011, 07:49 PM   #4
Sparky66
Sparky66's Avatar
Australia
58
Drives: 335 E92 Coupe. Jet Black.
Your mum installed the V5 Procede tune without telling you.......
Sticky is an Idiot
      06-05-2011, 01:14 AM   #5
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
Really? noo topic is about jerky gas pedal... So no one with AT and jerky pedal?
      06-05-2011, 03:28 AM   #6
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
I think u answered ur own question..
Originally Posted by GodLy View Post
Hello,Ok i have e92 335i 2007 AT with jb4
      06-05-2011, 03:30 AM   #7
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
in which part ? (I want jerky pedal, but i dont have it)
      06-05-2011, 03:37 AM   #8
tibra1
127
i have e92 335i 2007 AT with jb4.. !
Piggys arent exactly known to retain the smooth like character of stock including throttle response
      06-05-2011, 03:40 AM   #9
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
Men, i dont understand what you trying to say!
      06-05-2011, 03:44 AM   #10
tibra1
127
U said that the e90 has a more "jerky" pedal whatever that means...i think u mean the throttle response is better..u step on the gas and something happens faster than on ur e92 w piggy..and i am telling u that piggy cars dont retain that same smooth charcter of stock car..
Is this clearer?
      06-05-2011, 03:51 AM   #11
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
ok i see... "jerky" means fast response... no lag..
But when my car was stock there was same response like with jb4... So problem or what ever this is.. is not in piggy...
It feels like e90 have shorter gas cable...
Is this clearer?
      06-05-2011, 03:55 AM   #12
tibra1
127
these cars dont use cables its an elecronic throttle control.called "fly by wire".
upgrade the software from the dealer that may help
      06-05-2011, 04:02 AM   #13
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
yes i know... it must be in "shorter gas cable"
And about, software upgrade i have newest one... and e90 i think have older... maybe there is some option how i can check software version ?
p.s tibra1 do you have AT or MT? If AT is your pedal fast response?
      06-05-2011, 04:22 AM   #14
tibra1
127
No i have MT..it feels fine both stock and tuned
      06-05-2011, 04:24 AM   #15
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
ok thank you!
So i understand that i dont get answer..
      06-05-2011, 08:34 AM   #16
bv1
Drives: 335i Coupe AT
I understand what you are saying as i am experiencing it myself. It feels like you need to press the pedal quite a bit to get the car going. Like a mushy feeling. It's almost like the transmission is in the wrong gear.
However my experience is not consistent sometimes it is ok and really responsive "jerky" as you describe.
I have full BMW diagnostic software and there are no issues or codes... I've reset the transmission adaptations which seems to correct it for a bit but then it goes back.
I'll try resetting the throttle adaptation and see if it helps me. I'll let you know. I have JB4 as well.
Try running Map 0 and / or try manual mode, see if the issue persists.
I do a lot of city driving and have been having some issues with my auto trans. This could be my problem
Good luck.
      06-05-2011, 11:46 AM   #17
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
Thanks for advice...
Amm i'am all most always on manual mode And problem isnt in JB4...
And yes please let me know about: throttle adaptation reset... i am holding fingers!
      06-05-2011, 11:59 AM   #18
XDEEDUBBX
XDEEDUBBX's Avatar
64
Drives: 535I
just learn how to do the jerk
      06-05-2011, 12:02 PM   #19
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
You are wrong!
Here you go:
      06-05-2011, 04:14 PM   #20
**335i**
**335i**'s Avatar
Switzerland
184
Drives: TOYOTA & 2008 E92 335i 6MT
2008 335i  [9.00]
i think its cos of u are AT i am MT
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
      06-06-2011, 01:40 AM   #21
GodLy
DSC OFF!
GodLy's Avatar
34
Drives: 991 Turbo S
I think there is no life on the moon.
      06-06-2011, 08:52 AM   #22
Syndicategt
Drives: 335i
PROcede is smooth as a baby's bottom.
aggressive, gas, pedal
