Pre-lci Halogen to Pre-lci Xenon Conversion
03-26-2014, 01:29 PM | #1 |
Rep 98
Hi
Apologies if this has already been answered but planning a Pre-lci Halogen to Pre-lci Xenon. Plugged the lights in and the angel eyes light up but not the xenons. Question is does it just need coding or is the wiring different too? Read something about needing FRM3 which I don't believe my car has. My car is a 57 plate E90 Pre-lci btw. Many Thanks in advance. Last edited by ben.bell1987; 03-27-2014 at 08:41 AM.. |
03-27-2014, 11:49 AM | #3 |
529
Rep 2,505
Your car will need to be coded. In short you need to tell the cars Vehicle Order that it now has Xenon Headlights. Then tell disable auto levelling (unless you have done a complete retrofit).
You can do the coding very easily with NCS-Expert and a DCAN cable. |
03-28-2014, 06:16 AM | #4 | |
Rep 98
Just need confirmation that I didn't need need additional wiring for the xenons to work? I am ok with with disabling the auto levelling. |
03-28-2014, 06:40 AM | #5 |
Rep 62
Hi Ben, What are you thinking of fitting as I'm considering this ?
E90 Alpina D3 MT :No 566 Titan Silver
E36 328i sport E34 525i sport E28 528i (86) |
03-28-2014, 06:47 AM | #6 |
Rep 39
03-28-2014, 07:23 AM | #7 | |
Rep 98
I am just planning on a straight swap but changing the angel eyes to Lux or something similar to match 6000k bulbs. Probably going to chance it with no washers or self levelling. |
03-28-2014, 11:37 AM | #8 | ||
529
Rep 2,505
04-02-2014, 03:21 PM | #10 |
Rep 98
I have added $522 to the VO for both the CAS, FRM and the NFRM, plugged the headlight in to test and only the angel eyes light up, nothing from the xenon. High beams work when flashing.
Is there anything else I need to code or does it need rewiring? |
04-03-2014, 04:00 AM | #11 |
Rep 1,991
Drives: F30 335d
I did a pre-lci halogen to pre-lci xenon conversion.
Full details can be found here http://www.e90post.com/forums/showthread.php?t=912413 Your xenons aren't lighting up because you need an extra earth wire. The genuine BMW aftermarket wiring harness has this. Or you could bridge pins 2 and 4 in the headlight socket. Cheers |
04-03-2014, 09:42 AM | #12 | |
Rep 98
Also what do you mean by bridge pins 2 and 4? |
04-04-2014, 04:27 AM | #13 |
529
Rep 2,505
http://www.online-parts.co.uk/bmw/ad...7#.Uz56Cni9LCQ
Double check it's the correct one as I'm not sure of the differences between LCI and pre LCI wiring. The term 'bridge' just means connect those two pins together. It's an easy fix, but I'd personally go for the full retrofit. |
04-04-2014, 03:47 PM | #14 | |
Rep 98
Bit gutted though, I ordered the cable earlier today from BMW so not sure whether to return it and save myself £30 + VAT or just sell it on here. Fitting them tomorrow and coding out the bulb errors |
04-07-2014, 02:06 AM | #15 |
Rep 1,991
Drives: F30 335d
IMO the BMW cable is the better solution.
1. It's part of the official retrofit. 2. You will have proper full beam and flash to pass function. One the wires in the BMW cable runs to the FRM (footwell module) which enables the bixenon full beam function. You don't need to have this wire but if not you must bridge pins 5 + 6 (I think). However your flash to pass lights (the halogen ones) come on with the full beam. It's not as clean a solution really. The loom also includes the connectors to work with the levelling sensors as you'll see in my thread. If you don't have the levelling sensors the headlight beam angle will always be set to their lowest position so the light output won't be spread further down the road. This is so you are unlikely to blind oncoming traffic. Cheers |
04-07-2014, 04:37 AM | #16 |
Rep 61
So have you replaced halogens with xenons by just changing headlights, adding $522 to the VO for both the CAS, FRM and the NFRM and finally bridge pins 2 and 4 in the headlight socket.
If thats all thats required that is relatively simple, however, theres no auto levelling and washers; is this okay for MOT? |
04-07-2014, 04:52 AM | #17 | |
Rep 98
I have not fitted levelling sensors or washers which make it completely legit but by default it points towards the road so no dazzling anyone (thanks bishbosh) It depends where you go for an MOT, some are more lenient than others. I have passed with a HID kit in Halogen headlights so should be fine. |
04-07-2014, 04:52 AM | #18 |
Rep 1,991
Drives: F30 335d
Me? No, I used the loom and sourced levelling sensors. Oh and a new light switch as I don't need the dial for headlamp beam adjustment. It's all in my thread I linked to earlier.
Regarding the MOT, levelling sensors and headlight washers are NOT required for the MOT. I don't have washers and my car passed it's MOT last month. |
04-07-2014, 10:44 AM | #19 | |
529
Rep 2,505
Re MOT and washers / levellers. I was under the understanding they had to be working for MOT, IF fitted. If they aren't fitted, MOT rules do not apply to them. |
04-07-2014, 03:32 PM | #20 | |
Rep 1,991
Drives: F30 335d
Yes, that's my understanding too from reading the MOT wording. |
04-08-2014, 03:29 AM | #21 |
Rep 39
Bish Bosh,
Thanks for your full thread link, I'm seriously considering this as the next step for my D3, If I'm going to do this I'm going to do it correctly. Will look in to it more and see what I'm up against, although the coding side of things is beyond what I can do. Might need to source someone who can help with that. Cheers Deeg |
coding, halogen, retrofit, xenon |
