2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Wheels with differnt size front/rear on a XDrive
      02-24-2013, 11:47 AM   #1
Zaman
Zaman's Avatar
39
Drives: 2012 BMW (F10) 528i Xdrive
Question Wheels with differnt size front/rear on a XDrive
I want to change the wheels on my 528i XDrive. I love wheels wider on the rear. But my tire specialist said that for AWDs it is not good to have wider tires on the rear.She also said that don't go with R19, go either R18 or R20.
Any thoughts, facts, referenced reasons?
my plan:
Front: 245/35/R19 or R20
Rear: 275/30/R19 or R20
BMW F10: A formula to captivate the senses.
2012 528i XDrive Alpine white
      02-24-2013, 01:45 PM   #2
Lee
Germany
64
Drives: '17 X5 50i/'01 Z3
my plan:
Interested in the outcome, but I question the reasoning on not putting on 19s -- they are part of the M-package.
      02-24-2013, 06:07 PM   #3
Juiced46
Drives: 03 Turbo Cobra, 2011 335xi
You can go wider on the rear. There is nothing wrong with that even on AWD. The main factor is the tire diameter has to match front and rear. If the diameters are different this will affect the AWD system. Also you can run 19s there is no reason not to. Factory M sport BMWs come with 19s with wider rear wheels/tires
      02-24-2013, 10:32 PM   #4
Zaman
Zaman's Avatar
39
Thanks, So I'll go for it. I'll share the photos after installing the wheels.
      02-26-2013, 10:27 AM   #5
hyperboost
hyperboost's Avatar
66
Drives: M3 Boxster Corvette M5C
The size you should run is 245/40/R19 , 275/35/r19. Don't do 35 and 30 profils
      02-26-2013, 11:18 AM   #6
Zaman
Zaman's Avatar
39
Ye, You are right. That's the way I should go. I saw many options with these profiles.
      02-26-2013, 09:43 PM   #7
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
does putting same size tires all around alter any suspension dynamics? I am also looking to get 19s or 20s, but I have staggered M sport wheels and was adviced by local tire shop that it would be better to put same size tires/wheels so I can rotate them and give me a longer tire life.
      03-01-2013, 01:04 PM   #8
jfiore13
jfiore13's Avatar
71
Drives: black 2018 M5
I have a 535 x drive with a staggered set up.... "They say its not good to go staggered on FWD" but I have had no issues and no difference in ride quality. I'd definitely recommend it
      03-01-2013, 03:21 PM   #9
Lee
Germany
64
What do exactly have?
      03-13-2013, 01:31 AM   #10
sexy_ninja_goat
sexy_ninja_goat's Avatar
Drives: '07 E90, '10 RR Sport
I too have a staggered set up and xDrive and have had no issues at all. Just a couple of things to consider.
You will go through tires faster because you will not be able to rotate them front to rear.
IF you don't ensure diameter is the same front to rear your AWD will go nuts and you will get error codes.
There is actually no practical reason to have a staggered set up with AWD because you will never have oversteer issues (which is why RWD vehicles used staggered set ups sometimes).
However, I do like the look of the staggered setup which is why I have it!!
"Never use a preposition to end a sentence with."
2007 E90 - Black Sapphire/Terra - SP - Xenon - CA -L7A - 19" CSL Reps - KW V3 - SGLD
      03-13-2013, 11:53 AM   #11
Lee
Germany
64
Photos?
      03-13-2013, 01:48 PM   #12
sexy_ninja_goat
Originally Posted by Lee View Post
Photos?
/i realize these pics suck, but they are all I have access to right now as my car is in the states and I am currently not.
      03-13-2013, 03:32 PM   #13
snj1013
Drives: 2011 528i
+1, I did 285/35/19 for the rears, not an x-drive though
      03-14-2013, 11:21 AM   #14
Zaman
Zaman's Avatar
39
Thanks for the complete info. Similarly, My only reason is the look too.
      03-16-2013, 03:46 PM   #15
BMWMB
BMWMB's Avatar
Belgium
36
Drives: Mercedes C450 AMG Sport
Here in Europe, xDrives are delivered from factory with staggered wheels, so i'm sure it's ok.
My F10 530d xDrive has staggered 20" styling 356.
2018 991.2 GT3 MT Clubsport - 2016 Mercedes C450 AMG Sport break - 2015 Range Rover Sport SDV6 HSE Dynamic - 1993 BMW E36 M3 tracktoy - 1990 Porsche 964 Carrera 4 convertible
      03-31-2013, 10:31 AM   #16
doneo
Drives: 2013 550i Xdrive
Michelin PSS
I'm hoping to put on a set of Michelin PSS on my 550 xdrive. I live in the NYC metro area so I'm going to stick with 19's.
I'd like to put 265/40/19 on front which have an outside diameter of 27.4 inches and use 295/35/19 on back which have a 27.1 outside diameter. Are these diameters close enough for the xdrive system not to malfunction?
Any feedback or suggestions would be greatly appreciated. I'm obviously concerned about rubbing but hoping that if I get the correct off-sets i'll be good.
      03-31-2013, 12:59 PM   #17
sexy_ninja_goat
I can't see any reason you'd have any issues with those sizes. 3/10 of an inch shouldn't cause issues. Also if you don't have your car dropped at all, you shouldn't be concerned with rubbing as long as your offset is less than 40 I'd say on the rear and less than 37 on the front. You may have more room on that though, I'm not an F10 expert. I think most of the F10 owners on here stick to somewhere between 30 and 40 for the rear and 22 - 35 on the front. (The smaller the number, the further away from the inside of your wheel well). It depends on the width of wheel you are running.
      01-05-2014, 12:04 AM   #18
JerimiahLee
Drives: 2014 528xi MSport Alpine White
I have a similar question. What is the proper wheel and tire measurements for 19 and 20" respectively on the F10 XDrives?
      01-05-2014, 06:37 AM   #19
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Other than the OEM size?
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      08-02-2018, 04:59 AM   #20
keeyu
Drives: 528i
What is the ideal offset for the xDrive on 19x8.5
      08-02-2018, 02:09 PM   #21
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
~25
f10 5 series, tire, wheels
5post
