E92 Rough Idle
01-24-2014, 08:52 AM | #1 |
Rep 12
E92 Rough Idle
I just bought a 2007 328i Coupe with around 90k on it. I don't know any maintenance history, but it seems like it was cared for pretty well, so I'm guessing all the standard regular maintenance has been performed.
I've recently noticed in the extremely cold temperatures we've been having (0-10F) that when I start the car after letting it sit over night it has a rough idle. Not right away though. If I start the car and let it warm up in the driveway, it's completely fine with no idle issues. But, if I start the car and drive it immediately that's when the problem occurs. I can start it, back out of the driveway with no idle issues, but when I get to the first stop sign after leaving my house the car idles very rough sitting there. When i go to accelerate, it has a delayed acceleration and then all the power will kick in after about 3-4 seconds. After that, the car is pretty much back to normal. The next couple of the lights the car may idle a little rough, but barely noticeable and no delayed acceleration. If I let the car sit for 6 hours or so during the day when it's only 5 degrees out, even at a cold start I don't have any issues. It seems to only be an issue when the car sits over night for a good 12 hours or so. The car isn't giving me any codes, check engine light or anything, so I'm not sure where to start. I've read a number of posts and it seems like it could be anything from a bad fuel injector, coil, spark plugs, the list goes on. Anyone have a similar issue? |
01-24-2014, 09:10 AM | #2 |
13
Rep 260
If I'm hearing you correctly, you're only having the issue when you start it and drive it immediately in very cold temps, but don't have the issue if you let it warm up first. Correct?
Not trying to state the obvious, but in temps that low why wouldn't you let it warm up first? I honestly never start and immediately go, it's not good for your car (or any car IMO) when below freezing. Even in warmer temps, I always let the idle drop to the normal 600+/- rpms before I take off.
B o s t o n S t r o n g |
01-24-2014, 09:19 AM | #3 |
295
Rep 2,202
You are right it could be few reasons. When this situation happened with me it was a misfire caused by the exhaust vanos solenoid. You could swap them to see if it makes any difference. Start troubleshoot from the coils though.
01-24-2014, 09:14 PM | #4 | |
Rep 12
P0012 - "A" Camshaft Position - Timing Over - Retarded (Bank 1) Still have to research exactly what's causing that code to come up though. |
01-24-2014, 09:46 PM | #5 |
Rep 679
I now tend to let the car at the very least drop down to normal idle after starting...I do like to let it idle for 5 minutes or so if I can during the winter...its just happier that way!
JP |
01-24-2014, 10:44 PM | #6 |
Rep 447
My 328 had the same issue you described, rough idle with cold engine either in D or R. If simply left idling in P, no issues.
Took it to the dealership, they updated the DME, and that fixed it, no more issues. Luckily it was covered by warranty so I did no have to pay anything. |
01-25-2014, 12:15 PM | #7 | |
Rep 58
01-25-2014, 12:18 PM | #8 |
Rep 58
Also, this may help... doesn't say anything about the cam bearing ledge though. So, you might avert a costly repair.
http://www.obd-codes.com/p0012 |
01-25-2014, 08:29 PM | #10 |
Rep 68
Drives: 335i Coupe, Swagger Wagon
I have always done a "driven warm-up"..
http://porsche356registry.org/resour...rocedures.html I know it's a Porsche article however it applies to all internal combustion engines. |
02-02-2014, 09:35 PM | #11 |
Rep 12
Yes, I just tried it today. Although today the issue was a little different. It was fine driving around, but when I got home and put it in park it started idling pretty rough. If I put it back in drive it was fine.
After I restarted the car the rough idle was gone. |
02-02-2014, 09:54 PM | #12 | |
1851
Rep 2,554
328i, e92, n52, rough idle |
