BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Throttle delay
proTUNING Freaks
      09-18-2014, 01:51 PM   #1
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
Exclamation Throttle delay
Hi ,I'm having throttle delay after coming back from 5weeks vacation as you can see with the attached logs..
sometimes it happens sometimes it doesn't...
so to explain what really is going on :
1- i go WOT...-its like i didn't-.... after 3-4second it starts to believe that i really pressed it, After shifting ( sometimes it happens sometimes it doesn't...) it also waits 3-4seconds to go again
happens in map6 and map0 in jb4 so i think its not JB4 related.
i had thoughts that my IPE exhaust that has a wire connected to the throttle somehow i'm not sure how it was and i thought it was from it because it was my last mod and happened after installing it , so i removed the throttle sensor from my car and the problem still occur now i'm left to the help you guys can offer me excluding dealership, which will be my last resort as i need to remove my exhaust and jb4 to go in ( CBA to remove chargepipe/intercooler :S).
thanks, Mohammad.
Docrace 6266
      09-19-2014, 12:51 PM   #2
M-terkait
M-terkait's Avatar
Kuwait
209
bump , with a video of the issue
[u2b]
[/u2b]
Docrace 6266
      09-21-2014, 02:43 AM   #3
M-terkait
M-terkait's Avatar
Kuwait
209
i removed my ipe exhaust so i can take it to my dealership peacefully and it never happened again, it seems to be it was from the vacuum source pipe that was attached to ( orginally closed before installing it it was closed with a plug ) vacuum source which is located near the wastegate.
now i'm waiting for IPE to help me fix this issue that wasn't expected from high quality and expensive exhaust.
Docrace 6266
      09-21-2014, 11:25 AM   #4
betlion
81
Drives: bmw
i have the same issue when i changed out my exhaust
      09-21-2014, 01:05 PM   #5
M-terkait
M-terkait's Avatar
Kuwait
209
IPE exhaust?
Docrace 6266
      09-21-2014, 01:07 PM   #6
betlion
81
Drives: bmw
no magnaflow
      09-21-2014, 01:09 PM   #7
M-terkait
M-terkait's Avatar
Kuwait
209
no magnaflow
weird have you contacted BMW ?
because mine is driving really great even without jb4 now just using my stock mppk map and it drives great and even when i removed jb4 it wasn't gone..
Docrace 6266
      09-21-2014, 01:15 PM   #8
betlion
81
Drives: bmw
i have jb4 stage 2 on map 1
i also just installed the awron gauge, love it
everything works except boost display isn't accurate due to the jb4
      09-23-2014, 02:06 PM   #9
M-terkait
M-terkait's Avatar
Kuwait
209
happened again with stock exhaust and without jb4 , and again with jb4 the same day time to take it to the dealership...
Docrace 6266
335i, delay, f30, jb4, throttle
Search this Thread:
