Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > PBX and oil changes
      04-17-2010, 10:40 AM   #1
AlanAZ
AlanAZ's Avatar
40
Drives: E90 325i sport manual
PBX and oil changes
I'm just changing my oil, and I'm remembering that the PBX spikes the RPMs higher at cold start, up to 1,400 rpm, I'm using map 3. [Until the filter is full, air is pumped out of passages, and everything fully lubricated, you want to keep rpms at a minimum.]
So I'm going to turn it off altogether for the first start, map 0. And go back to map 2 or 3 on the second start.
For those of you taking it into a shop, this is even more important, since you don't know how through they are on the filter pre-oil (I use about 1/5 of a qt on mine, until it's dripping into the catch pan - I know, it's OC, but think of the wear as the filter has to fill before the oil gets to the engine.)
Just a thought (first oil change on PBX, and first since switching to Mobil 1 0W40, the old still looked good.)
burger, engine wear, maps, oil change, pbx
