Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil around my spark plug cylinder #2
      12-04-2012, 11:38 PM   #1
N54King
King of the road
N54King's Avatar
18
Drives: E90 335i
Exclamation Oil around my spark plug cylinder #2
Hey guys few days ago my car started to cut out and hesitate eventually misfiring on WOT... scanned it and it said missfire on cylinder 2. I had this happen when i first bought the car but on #6 it ended up being a coil pack. I figured it was the same thing so decided to change the coil pack on #2, once i took the old coil pack out i noticed there was oil on the end rubber tip of the coil pack and some oil deep down around the plug? What could be the cause of this ? im assuming valve cover gasket ? is there a possibility oil could have creeped through from a spill while filling it from an oil change ? Already checked all other cylinders and only #2 had the bit of oil in it... Anyone else have this happen ??
      12-04-2012, 11:55 PM   #2
deluxe 247
Shake and Bake
deluxe 247's Avatar
32
Drives: 2016 M4
most likely valve cover gasket
      12-05-2012, 12:03 AM   #3
Amini77
Drives: Alpine White '13 550i
2013 BMW 550i  [0.00]
+1
      12-05-2012, 12:04 AM   #4
benzy89
Drives: '08 E90 335i
2008 BMW 335i  [7.50]
Valve cover gasket -- Just another component in the N54 that doesn't last. Not as bad as the HPFP, but the gasket, fuel injectors & waste gates are bigger headaches then they should be
      12-05-2012, 12:07 AM   #5
deluxe 247
Shake and Bake
deluxe 247's Avatar
32
Drives: 2016 M4
Lucky for you someone just posted a diy, http://www.e90post.com/forums/showthread.php?t=775317
      12-05-2012, 12:13 AM   #6
N54King
King of the road
N54King's Avatar
18
Drives: E90 335i
Thanks for the input everyone! I also assumed valve cover gasket right away to... seems to be a common problem on all the bmw's I've owned with a straight 6 actually haha. Just thought id check with the community . I cleaned all the oil around the plug on cylinder #2 and the car isn't misfiring anymore... if it obviously is the valve cover the oil will build up again in there shortly and i'll be back to square one, Then i'll be replacing the valve cover gasket... Surprised the valve cover went this quick considering my old E46 330i's went around 180Km im only at 130Km on my n54
      12-06-2012, 07:34 AM   #7
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
Clean it well and run the engine while watching the area of the leak to see where it is coming from. A lot of valve covers develop cracks by cylinder #2 from the inside out. Right where the front edge of the crankcase vent valve is. The valve covers aren't that difficult, but you don't want to do it twice of you don't have to.
      09-27-2014, 10:06 AM   #8
R0oster
Drives: 2007 335i coupe
hate to revive a old thread but did you ever get the the cause of this im having this exact issue now
      09-27-2014, 10:23 AM   #9
135Pats
135Pats's Avatar
Drives: A few BMWs
Oil around the threads, but not on the business end = VCG. 99% of the time.
F30 N55 XDrive EBII
      09-27-2014, 10:29 AM   #10
N8N
N8N's Avatar
Drives: 2009 E92 335i 6MT
not just sixes, seen it on V-8s too... e.g. range rover w/ BMW 4.4
      09-27-2014, 10:48 AM   #11
135Pats
135Pats's Avatar
Drives: A few BMWs
The only thing that sucks more than our VCGs are our PS Reservoirs.
If yours isn't leaking, you aren't driving a BM. Lol.
F30 N55 XDrive EBII
      09-27-2014, 11:56 AM   #12
Julian2485
Drives: Black lci e90 335 xdrive
Lol so true
      09-28-2014, 03:00 AM   #13
Scrippy
Lord Scrip
Scrippy's Avatar
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
Make sure you didn't spill any oil when adding to your car. I simply got a lil shaky and it ran down my engine cover down into the plug recess. Found it doing my plugs. I was all worried and I ran through my motor like a tweeker and nothing was wrong. It's common for #3& 4 to be dirty. I would clean everything real good and check back.
      09-28-2014, 09:38 AM   #14
Miller335
291
Drives: 2007 E92
From the looks of it, its the same one they've used for years.
I swear I even saw a thread where they just put a CHF 11 sticker on the top of it and below that sticker the mold of the PS res still says ATF.
Thankfully these reservoirs are easy to swap out, just probably a bit messy.
      09-28-2014, 10:29 AM   #15
135Pats
135Pats's Avatar
Drives: A few BMWs
I think i'm gunna get the 3D design one
F30 N55 XDrive EBII
      09-30-2014, 12:58 PM   #16
6MTF80
Drives: 2007 335i
Valve cover gasket. Had mine done by Ivan @ Strassesport & walnut blasting since he was already working on it. Made a huge difference.
      09-30-2014, 01:39 PM   #17
C.Pop
65
Drives: 335i
Wipe the plug next time. If the oil is brand-new type of clean, you just spilled some. If it's not clean, it's like everyone else has said, valve cover gasket.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
335i, bmw, n54, oil
