"Best" Intake: Injen, aFe or BMS DCI?
09-20-2011, 06:34 PM | #1 |
13
Rep 43
Which one of these intakes sounds the best and has proven HP gains?
I dont want my engine to look like crap with the BMS dci, so i was thinking of aFe or injen, unless there is some crazy benifits of it (other than price). Thx! |
09-20-2011, 06:42 PM | #3 |
Rep 660
Without meth and I will say aFe..
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
09-20-2011, 06:43 PM | #4 |
28
Rep 300
Not on your list but a very popular one around here is the Mr5 DIY intake.
__________________________________________________ ________
09-20-2011, 07:05 PM | #6 |
Rep 575
stock box with drop in filter unless your fully modded,
09-20-2011, 07:07 PM | #7 |
Rep 783
2021 M3 6MT Brooklyn Grey/Silverstone
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red |
09-20-2011, 08:28 PM | #8 |
Mad Linux Guru On The Loose
1112
Rep 5,389
Drives: 2008 335i Sedan, 2023 M3
Dinan if you have money!
Stock airbox + Mr.5 mod if you don't! The rest is junk.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
09-20-2011, 08:37 PM | #9 |
Rep 3,730
True that. Check out my DIY for the custom Mr 5 style intake.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-20-2011, 08:55 PM | #10 | |
Rep 1,020
Linky: http://www.e90post.com/forums/showthread.php?t=549965 |
09-20-2011, 08:56 PM | #11 |
My X5d tows my spec miata to the track.
74
Rep 1,254
Mr. 5 or stock
Dci vs stock: http://www.e90post.com/forums/showthread.php?t=491005 Stock vs mr. 5: http://www.e90post.com/forums/showthread.php?t=580412 |
09-20-2011, 09:31 PM | #14 | |
Rep 828
The bumper ??? In the end Jeff is right,choose one that suits your needs ..I think the m5 is a waste .All the fastest cars and best drag times is from the dci.It's proven and sounds great spoiling up. |
09-20-2011, 09:34 PM | #15 | |
Rep 1,625
The AFE intake on my car complements my FBO capability.. and since there's really no evidence to quantify whether the **arguably** marginally higher IAT's are enough to negate the improvement in ease of airflow calling something junk is silly. Again, this is also not considering the improved cooling capabilites of an intercooled car, let alone an aftermarket intercooler and meth kits. Also, at all speeds, above traffic or dead motionless on a dyno there's air being directed into the engine bay. In my mind this diminishes the amount of time the car is sucking in hot air.. and the effects of this heated air is up for debate on our platform. I KNOW there is a difference in performance on my car when going from a stock box with drop in to a DCI with FBO's. I believe there are still gains with anything above stock boost levels. There are dyno's demonstrating gains.. their accuracy I cannot comment upon, but nonetheless.
2014 Individual /// M5 Competition AW/AB || Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge || |
09-20-2011, 09:36 PM | #16 | |
3441
Rep 79,212
Drives: C6 Z06, 09 335i, 10 335xi
After that your just breathing in hot air. Those fastest guys all run meth making the difference negligible at that point. Without meth the best is one that breathes cold air With meth getting the most air is best albeit cooler air would be better. |
09-20-2011, 09:43 PM | #17 |
Rep 828
Every turbo car I ever had I always ran come style intakes ..The more air it breathes the better it runs and more power is made..The stock box is very restricted.Jeff is the new afe any good??
09-20-2011, 10:06 PM | #19 |
3441
Rep 79,212
Honestly you mine as well just get a regular DCI.... I'd be more then happy to see 3rd party dynos that show otherwise.
09-20-2011, 10:20 PM | #20 | |
Rep 660
Uploaded with ImageShack.us[/QUOTE]
09-21-2011, 12:47 AM | #21 | |
371
Rep 2,839
Drives: e92 335i, e34 525i & e60 530i
Check out my cardomain http://www.cardomain.com/ride/390878...oupe-2d/page-4
09-21-2011, 07:06 AM | #22 | |
Rep 708
OP - If you do not want to learn from what has been discovered on this thread, then don't go with any of the above and get the Injen or ETS. They have metal pipes and big filters. I rocked the aFe for a short while, and liked the way it looked. The build quality was what bothered me and led me to switch to a Mr.5 setup (combined with Mr.5's test results ). The aFe uses thin crappy sheetmetal as a heatshield, and the hood gasket they supplied me did not fit properly nor did it work very well. The plastic pipes also concerned me, and there has been at least one instance on here where the pipes melted. Do your research and go with what you feel is right. |
afe, cold air intake, dci, injen, intake |
