BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > BMW Recalls 156,137 Cars for VANOS Bolts Issue (2010-2012 6 cylinder models)
ARMA SPEED
      04-11-2014, 01:22 AM   #67
Kristalov
Dr. K
Kristalov's Avatar
Drives: '23 718 GT4RS,'19 F82, '24 G87
Been there...
Already had this great experience. Scared the crap out of me when it happened in my 2010 X5. Dealer told me it happens quite a bit on the 35i engine.
      04-11-2014, 07:58 AM   #68
Jettt
Gun Slinger
28
Drives: slow and with caution
Anyone know if this affects Canadian models cars?
Just called the dealership and they said they haven't received anything regarding a recall yet.
      04-11-2014, 08:08 AM   #69
COOLZ4
Secret Agent
Drives: 2011 sdrive35is
I contacted my BMW service adviser about this and he said BMW will issue a letter when and if the recall becomes active. It will be VIN specific.
      04-11-2014, 10:57 AM   #70
hankolerd
51
Drives: '90 M3-'21 X5 x40i
1990 BMW M3  [0.00]
2011 E91 6MT ZSP  [0.00]
So what are the symptoms if this happens? My 2011 328i wagon has started a slight hesitation when I go to WOT when under ~2000 rpms and in a high gear, like 3rd at 15mph. Yesterday I was doing about 35mph in 5th and went to ~80% throttle and it had a really bad hesitation (lurching) and then suddenly my CEL came on and when I brought the car to a stop it was shaking like it was only running on 4 or 5 cylinders. My car was manufactured in 5/2010, so it could be affected, but the car is at 59k miles so out of warranty. I am planning to take it to an independent repair shop (Group 2) unless I have reason to believe it is related to the recall issue. I assume all recalls are repaired at no charge even if the car is out of warranty? Thanks!
      04-11-2014, 01:39 PM   #71
OC40
Drives: 335i MSport + MPS/MPPK
2013 MINI S  [0.00]
2013 BMW 335i  [0.00]
Originally Posted by shivaswrath
F30 n55??
I noticed that too.
      04-11-2014, 02:04 PM   #72
Gtrain
Taiwan
144
Drives: something slowwwww
You can check for recalls on your vehicle here.
http://www.bmwusa.com/standard/conte...er/recall.aspx
      04-11-2014, 02:39 PM   #73
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
Originally Posted by G2G View Post
does this also count for the N54 of the 1M?
No. N54 engines including the one we have in the 1M is not subject to this issue/recall. There is a relevant thread in the 1M section that you may like to check for confirmation as well.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      04-11-2014, 04:49 PM   #74
msh441
msh441's Avatar
17
Drives: 2007 BMW Z4 M Coupe
VANOS bolts!?!
Yet no S54 M3s, Z3Ms or Z4Ms?
WTF!?!
      04-11-2014, 05:07 PM   #75
ze_german
Autobahn Addict
ze_german's Avatar
Drives: '11 E92 N55 6MT Msport
Hmmm.... my car suddenly stalled while idling last Wednesday. Very first time that happend. N55 with 69k miles on it. Called Crevier in Santa Ana but they will not have the parts for this recall for the next couple of weeks.
Maybe the bolts should break and screw up the engine so I get a new one. I'm out of warranty.
defi boost gauge in custom 3d printed pod, jb4, bms cdv/cs, er cp, vrsf 7" ic, m3/poly diff/tranny mounts, st coilovers, cyba 3.8 tips
      04-11-2014, 09:44 PM   #76
bmwpassionate
15
Drives: BMW 535 xDrive M Sport
Recall is covered by the manufacturer even if you are out of warranty..
      04-11-2014, 09:44 PM   #77
NeoBMW
Drives: 2016 640GC M
so this is really wierd. I was in my 2013 F10 535i a month ago at a light dropping my son off at school. I have the engine start/stop engaged. so as I pressed the accelerator after the light turned green, the engine started but the car stalled. I was making a left turn on a light and it was a bit concerning. I immediately put car in park, mind to while folks beeping at me, turned the engine on and went off my way. After it happened 1 more time, I took it to the service center and they kept the car for the whole day running diagnostic with an ALL CLEAR. I was told to bring it back if it happens again. 15K miles.
hmmmm???
      04-11-2014, 10:53 PM   #78
Lucky1
647
Drives: '08 128i Coupe SGM 6MT
Originally Posted by Shon
Prolly for both NA and Turbocharged.
Fu$&er only recalling cars that are still under warranty.
Is there any evidence to suggest cars with model years prior to 2010 with the same engines have the same defect?
      04-12-2014, 09:48 AM   #79
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
Drives: 29k mi per year.
I love this forum!
Cross-reference this post http://www.e90post.com/forums/showthread.php?t=951718
I looked up my VIN and it's not on the list yet, but I expect it will be in a month or so...
It's sweet too, because this will also fix the leaky seal I was gonna have fixed anyway! In a way, we can thank GM for their FU... Some BMW owners have known about this problem for a while and letters written to BMW have for the most part been ignored.
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
      04-12-2014, 04:35 PM   #80
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
From what I understand BMW hasn't officially issued the recall right? I called my dealer and they were pretty dismissive by telling me that nothing is official yet.
      04-12-2014, 07:22 PM   #81
Marsden
Chief Petty Officer
9
Drives: E90
Yeah but BMW always issues these on a rolling basis...doubtless to prevent service centers from being completely swamped all at once.
Originally Posted by sobby View Post
SI B12 14 12 Dated July 2013 only included these specific cars and production dates..
E70 produced from 2/2010 to 12/2010
E71 produced from 2/2010 to 12/2010
E82 and E88 produced from 2/2010 to 12/2010
E90, E91, E92 and E93 produced from 2/2010 to 12/2010
F07 535i produced from 2/2010 to 12/2010
F10 535i produced from 2/2010 to12/2010
F12 and F13 produced from 2/2010 to 12/2010
F25 produced from 2/2010 to 12/2010
I wonder if the problem is more expansive than they originally thought back in July 13' or if USA Today screwed up the dates?
It's happened before (with other recalls) that the 'affected models' listing expanded over time (now including models to 2012?). Which has me interested since my E90 was produced just before the ones noted. I wonder what the change was, exactly... a new supplier for the bolts? A new fastening technique??
      04-13-2014, 07:17 AM   #82
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Wondering the same thing about 2013 models....anyone know if they changed vendors for MY2013 forward?
      04-13-2014, 08:13 AM   #83
GB-335xiCoupe
Libertarian
Not sure, but I've been searching a lot, and I haven't seen anything VANOS related on MY2013 cars yet... Might just be because they are too new still...
      04-13-2014, 09:49 AM   #84
bozola
Unloved BMW Addict
bozola's Avatar
Drives: Z3 Coupe, 3 318Ti
1999 Z3 Coupe  [10.00]
1998 318Ti  [0.00]
1998 318Ti  [10.00]
2008 128i  [9.00]
I don't buy this "this date to this date" recall. I had the airbag issue and my car was one month out of the recall notice. BMW would not honor it until I wrote a complaint letter. In fact my independent couldn't believe that they wouldn't even try it. If I was one/two months out of this recall, I'd be all over it.
      04-13-2014, 11:12 PM   #85
JcLusso
i build cool shit
JcLusso's Avatar
Drives: 2018 Individual SMB F80 M3
2018 BMW X5 M  [0.00]
2016 BMW i3  [0.00]
I think my car just started throwing the death code..... and i already had this issue once and my motor had to be rebuilt at 30k miles!
Current: 2018 Individual San Marino Blue M3 | 2022 BSM X5 MC
Previous: 2018 BSM X5 M
      04-13-2014, 11:36 PM   #86
ze_german
Autobahn Addict
ze_german's Avatar
What is the death code? Mine has 69k on it and still running strong.
      04-15-2014, 03:03 PM   #87
LACSTER
Drives: Hybrid
So did Crev BMW acknowledge the recall and parts needed? I spoke with BMWNA and they said it's not officially a recall campaign as of yet.
My 2011 535i died on the freeway today. FYI two BMW Assist tow trucks came and both of them didn't know how to get the car into N when the engine wouldn't start.
My car is at the dealer now getting diagnosed.
      04-15-2014, 03:09 PM   #88
ze_german
Autobahn Addict
ze_german's Avatar
I spoke to a service adviser who told me that the official recall has not started yet and they do not have the right parts to fix the cars. He told me that I should keep an eye on it and he expects the parts to come in in the next 3-4 weeks.
Sucks about your car man, keep us updated.
