TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Storage Compartment Removal
      12-12-2013, 05:26 PM   #1
Pino Carnovale
Drives: Sideways
Hey guys, I'm looking to get a custom exhaust installed on my e90 lci. It currently has the stock 328i exhaust and what i want the custom shop to do is install an exhaust that looks like the 335i with a Magnaflow muffler. The shop is saying that the storage compartment that drops down in the trunk is going to get in the way of what i want done and may not be possible. Has anyone had experience with this problem? If so, what was your solution? Is there a replacement part for this storage compartment that does not drop down as deep or at all? All of your comments/suggestions are appreciated greatly. Thanks in advance!
      12-12-2013, 07:30 PM   #2
Pino Carnovale
Drives: Sideways
bump
      12-12-2013, 07:34 PM   #3
Casca
Drives: E90 6MT
Why not just glue or bolt on a fake tip on the other side to look like the 335i?
      12-12-2013, 07:41 PM   #4
Pino Carnovale
Drives: Sideways
Ah i don't want to have a dummie pipe, id rather have both of them function
      12-12-2013, 08:20 PM   #5
sy2767
sy2767's Avatar
145
Drives: 2013 x5
If i'm not mistaken that compartment can very easily be removed without harming anything, it has no other purpose other than storage. I'm not sure if it's sealed with a simple gasket or seal or a permanent type, it's just screwed in place so remove it and check things out! Then just get a very nice peice of metal cut to the exact size and shape of the hole (paint it to prevent rust) and seal it up! Voila!! Lots of room now!
      12-12-2013, 09:39 PM   #6
Pino Carnovale
Drives: Sideways
So do you suggest getting a custom piece made to fit in place of that?
      12-12-2013, 09:59 PM   #7
sy2767
sy2767's Avatar
145
Drives: 2013 x5
Yes......
      12-12-2013, 10:04 PM   #8
Pino Carnovale
Drives: Sideways
Yes......
Okay thanks for your help!
      12-12-2013, 11:23 PM   #9
JYohay
Drives: 2011 X5
I know someone who just T piped it off the drivers side, and it fit behind the compartment
      12-13-2013, 10:02 AM   #10
JaysBlueE92
Mr. Monaco
JaysBlueE92's Avatar
Drives: Slow..
2007 E92  [5.00]
you need the m3 storage bin. It doesnt sit as deep as the 328 one does. Gives a few inches more for clearance for those doing custom exhausts like i did.
      12-13-2013, 10:13 AM   #11
sy2767
sy2767's Avatar
145
Drives: 2013 x5
Actually this is what I would do instead of a piece of metal,that way it still has the factory appearance
      12-13-2013, 10:33 AM   #12
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
Or the 335 storage bin look for both their identical
      12-13-2013, 10:36 AM   #13
StevenY.
///M
StevenY.'s Avatar
Drives: 10' SG e92 335i
Not sure if this will help you but check it out even though I do see that you want a factory appearance.
http://www.e90post.com/forums/showthread.php?t=902372
      12-13-2013, 09:47 PM   #14
sy2767
sy2767's Avatar
145
Drives: 2013 x5
Thats an amazing job!!
      12-14-2013, 06:53 AM   #15
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
I'm going to throw in here, just because I like digging into realOEM.com. I'm not real familiar with the 335i, but I've looked at them and they have two rear mufflers, which calls for a different trunk floor storage bin. Per realOEM.com the bin you need is P/N 41147120020, which is the more shallow bin as someone mentioned.
I'm not sure what changing to a custom exhaust using a magnaflow muffler entails (or the cost), but I would think, if you want to go with an OEM appearance you could convert over to the 335i exhaust from the downpipes back (maybe). I'm not sure if the downpipe exhaust flanges on the 328i are in the same location relative to the undercarriage that the flanges are on the 335i, since the exhaust system from the head back is totally different (i.e. turbos). But it seems to me, from a manufacturing perspective, BMW would keep the location of the downpipe ends for both exhaust systems in the same place. Just a thought.
Good luck with the conversion.
      12-15-2013, 02:55 AM   #16
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
Theres plenty of space between the bin and the bumper to run a pipe. Plenty of N52 guys have done dual/quad exhausts that way (me included).
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      12-15-2013, 08:47 AM   #17
rbtamms
rbtamms's Avatar
Philippines
63
Drives: 2011 E90 and 2013 F25
2011 328i  [0.00]
Great job...If I have seen this before I did mine. I would have done the same thing because I prefer to leave the stock muffler.
328i, 335i, custom, exhaust, magnaflow
Search this Thread:
