      03-21-2013, 03:18 AM   #23
kaitan
kaitan's Avatar
73
Drives: The Dark Side VAG TDI Biturbo
Loving it stu!! I saw it on dyno day!! haha you finally done the DP you bit the bullet !
      03-21-2013, 04:20 AM   #24
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Originally Posted by Stuart@BMRAutowerkes View Post
Not 100% satisfied with the sound just yet... needs just a little extra something.
It's definitely deeper, but I haven't heard it from outside the car yet (if you know what I mean - so it's hard to tell!)
The OEM 1M axle back that Stu installed on his 135i (120d) has been modified.
It has had the baffles removed and the canister internals redirected.
I installed this unit on my 1M some time ago, hooked up to the N55 mids.
It was actually quieter than my OEM unmodified axle back.. I removed it after a couple of hours, so I can understand why Stu is not 100% happy with the exhaust tone.
The quad install and mod on the other hand is awesome and if I had a 135i, would do this in a heart beat as it looks awesome and OEM.
      03-21-2013, 04:41 AM   #25
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
160
Drives: E92 M3 2012 Edition 500
The 135i charcoal canister bolts up to the 1M battery box, but you do need to disassemble the pipes and fittings, relocate and shorten them then reassemble the pipe work to the canister and reinstall.
It all looks OEM when done.
      03-21-2013, 04:44 AM   #26
Gumball
Gumball's Avatar
Australia
Drives: A45
Looks incredible - congrats!
      03-21-2013, 05:39 AM   #27
PeteA
PeteA's Avatar
Australia
127
Drives: E30, E82
If this was available in Melbourne I'd gladly give up my N55 135i and my wallet to have it done. If the exhaust note is as aggressive as the BMW 135i performance exhaust, I'd be all over it.
      03-21-2013, 06:11 AM   #28
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
Looks awesome!!!!!!!
      03-21-2013, 07:50 AM   #29
oystero
Australia
17
Drives: AW 1M, E90 320d
Nicely done. Great work stu + Pete + chris
      03-21-2013, 08:12 AM   #30
chrisN
chrisN's Avatar
Australia
30
Drives: bmw 125i coupe
2010 125i  [8.66]
good shit stu!
i like the choice of outer quads rather than inner quads too. accentuates the cars width much better.
      03-21-2013, 10:44 AM   #31
ilikebmxbikes
Drives: S65 1M Clone & E92 M3 4.6L
No I don't think those parts were used or required
Not sure if OEM support bar and hangers would be easier or cheaper, it seemed easy enough for chris to weld a piece of metal onto the exhaust and then insert it into some sort of rubber hanger.
hm fair enough - if it's easier, cheaper and just as good, obvious choice lol
the other big thread on it and the people doing it WERE mostly in the US (LHD) and weren't sure if it was needed for RHD
Originally Posted by ilikebmxbikes View Post
Wow- exhaust looks rad.
I put a 1M exhaust on my 135i about 3 weeks ago. I did it will all OEM 1M parts. It came out to a little over $600 for the OEM parts (heat shielding, battery tray, battery cables, new exhaust hangar bushings and rear bumper support bar.) of course you have to factor in the cost of the exhaust unit and have a custom diffuser fabricated.
Your exhaust looks great and that is a good idea to cut the pipes to fit an exhausting quad diffuser.
did it need any of the 'fuel system' stuff? or just the tray/cables/mounting and other 'obvious' stuff?
Hey
The Evap canister itself is the same on the 1M and 135i. We needed 1M Evap canister hoses to connect to the relocated position of the canister.
The hoses are more like tubes which do not flex much and you risk cracking or pinching off the flow if you bend them.
Do you guys even have to have the Evap canister in Australia? I know a lot of regions do not.
Everyone should try to get slek or some small CF manufacturer to make a diffuser that can accommodate the 1m exhaust and bolt up to an MSport bumper.
      03-21-2013, 01:40 PM   #32
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
I'm amazed... Nice work. But for the parts can you tell how much $$$ you have spent for parts?
      03-21-2013, 03:14 PM   #33
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Germany
561
Drives: VO 1M #739/740
Sweet...thanks for having the gonads to do this mod...gives us all encouragement to do our own special things that may not make sense.
      03-21-2013, 03:44 PM   #34
jozeff
20
Drives: BMW 130i
M135i 😃
      03-21-2013, 05:37 PM   #35
Smiley1175
Smiley1175's Avatar
Australia
281
Drives: M2
I like this ... there's finally going to be a market for my used exhaust!
      03-21-2013, 06:16 PM   #36
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
Originally Posted by racer_x View Post
Looks awesome.
Any extra hp over the stock setup?
I doubt it - can't feel any difference
Originally Posted by Alpine* View Post
What? How does this have anything to do with M3s, different user name same stuff.
I think he means he prefers outer quads than inner... but then again who knows what pavo is on about
I'm sure there are places in Melb who could do this!!
Being in Europe I'm sure you could get the parts much cheaper, here it's a little over $1k AUD for the parts excluding the 1M exhaust and excluding labour.
If you can find a cheaper diffuser it'll be cheaper again.
      03-21-2013, 06:29 PM   #37
Alpine*
Alpine*'s Avatar
Australia
1281
Drives: M2 G87
I reckon this would look good too, yeh I know it's a truck AND its a Chrysler, but I like the big centre pipe look.
      03-21-2013, 06:42 PM   #38
PeteA
PeteA's Avatar
Australia
127
Drives: E30, E82
There's another thread like this over in the main section of this forum:
http://www.1addicts.com/forums/showthread.php?t=818330
Looks pretty similar setup to yours Stu. It goes into some detail about battery leads and steam pipes as well.
      03-21-2013, 07:31 PM   #39
808
Drives: a black car
THAT could be interesting... maybe when I get bored of this look!
      03-21-2013, 07:34 PM   #40
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
But why 2, when you could get 3!!!
Regardless, whether 2 or 3, you would need someone to fabricate some kind of custom rear diffuser and I don't think they make centre exhaust diffusers yet.
      03-23-2013, 12:08 AM   #41
135i2
Drives:
Nice work!
      03-23-2013, 05:00 AM   #42
MMorbo
MMorbo's Avatar
Australia
Drives: BMW 135i, 08', Sedona Red
Only two little pipes for that big 8...
Must be the sepo's attempt at fuel efficiency...
" if it can't get out... Means less needs to go in"...
2008 BMW 135i Sedona Red | AT | JB4 | Autowerke DP | AMS FMIC
      03-29-2013, 01:36 AM   #43
flinchy
Drives: E82 135i
any chance you (or someone) could post a pic of the drivers side underneath battery tray bit? just want to see what's attached to it on that side (the non exhaust pipe side)
      03-29-2013, 04:07 AM   #44
1SER135
Australia
22
Drives: '08 135i M SPORT 6M
Ill have mine on by Friday. Mine is going to have Hartge diffuser and the two outside tips with be unmuffled ALA Akrapovic 1M exhaust. Will post a sounds clip as well if I get the chance
135, conversion, exhaust, quads
