TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > DSC Light, 4x4 Light, Brake HELP Please
      03-05-2013, 04:58 PM   #1
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
I just bought my certified pre-owned BMW 335i Xdrive back in October 2012. Everyday when i drive it to and from work, I get the following warning lights, 4x4, BRAKE and DSC warning.As well as the following messages on my iDrive, " Chassis Stabilization Malfunction", "DBC Malfucntion" and "Start-Off assistance inactive" as well as the chime. These lights do not go away til after I shut off the car and restart it. However, it literally happens to me everyday if I hit a HARD BUMP or POTHOLE. BUT its EVERYDAY this happens. I brought it to the dealer 3 times, took a ride with the shopforeman and i was told this was normal, as i had upgraded to 18"s when my car only came with 17"s However the 18s i am running are BMW style 193m wheels with 225/40/18 tires in the front and 255/35/18 tires in the rear, which comes standard on the 335m sport even with X drive. I dont think its my steering angle sensor since my signals work fine and shut off right when my steering wheel goes straight. I feel like it might be a bad DSC module or something. I highly doubt its the wheels. Any one have any insight please, its driving me crazy as this happens every single day!
      03-05-2013, 05:13 PM   #2
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
I forgot to mention, i have a friend who works at the dealership, who was able to read the codes and send them to me, however he has no location to pin point the problem. Heres what it says:
      03-05-2013, 05:56 PM   #3
LocDawgg
Drives: AW e90
Reset steering angle sensor, via dealership or local indie shop. If that doesn't work, then you need to replace the steering column (SZL). Should cost you around 7-900 at a indie shop and 1-1200 at a dealership. This is a common problem on the e9x dont worry you are not the only one.
      03-05-2013, 06:05 PM   #4
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
It's not the steering angle sensor. My local indie shop reset it yesterday and its still doing it. No problems with my turn signals or adaptive headlights
      03-05-2013, 06:18 PM   #5
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
Most importantly it only happens when I go over bumps or a pothole
      03-05-2013, 06:26 PM   #6
LocDawgg
Drives: AW e90
yes i know it happens to me all the time, like i said if the reset doesn't work then the SZL needs to be replaced.
Once you hit around 50k miles, it just stays on all the time....it wont even turn off when you shut the car on and off.
      03-05-2013, 06:33 PM   #7
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
Bought the car certified pre owned only four months ago. Still under warranty. Problem is convincing the dealer there is a problem. They just said its normal since I put bigger wheels on.
      03-05-2013, 06:36 PM   #8
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
Bought the car certified pre owned only four months ago. Still under warranty. Car only has 34,000 miles. Problem is convincing the dealer there is a problem. They just said its normal since I put bigger wheels on.
      03-06-2013, 05:48 AM   #9
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
BUMP
      03-06-2013, 06:00 AM   #10
#Tee
#Tee's Avatar
557
Drives: yes
is this under warranty type of issue? i have the extended warranty to 100k.
You can follow my builds on IG: Tee212
      03-06-2013, 09:07 AM   #11
nate5ks
Drives: 2006 BMW 330xi
Put the old wheels back in if you still have them then take it to the dealer.
      03-06-2013, 05:16 PM   #12
FLYT89
FLYT89's Avatar
37
Drives: 2021 X3 M40
I dont have the old wheels. But why should it matter going from 17s to 18s as long as i keep the tire diameter the same?
      03-07-2013, 06:18 PM   #13
nate5ks
It shouldn't I was just saying to do that so your dealer can't use some lame excuse to not service your car.
      08-10-2014, 05:50 PM   #14
new0rder
Lowlife Republic
15
Drives: 06 325XI Monaco Blue
2006 325xi  [0.00]
Interesting topic, I got the same damn issue, for me it started 2 month ago, the weather got hot above 85 degrees, and I had AC blasted, I hit a bump and all lights came on, I can still drive but when I come to a slow stop the car's system turn off ( nothing work all electrical are out ) its like a reset, everything will come back after 1-2 min, so far happen to me few times. day to day driving no issue only if I hit a hard bump. I will try to clean / Reset steering angle sensor first see how that goes.
I have a 2006 325XI. 85,000 miles on it.
06 Monaco Blue Metallic 325xi
      08-10-2014, 06:57 PM   #15
gtaccord
Drives: 2009 BMW 335xi
Take it to a different dealer or get BMW NA involved. The dealer is blowing smoke. The change in wheel size has nothing to do with it. You have warranty. Find someone that will let you use it.
      08-10-2014, 08:28 PM   #16
TrAcK TRaP
bOrN To DiE
Drives: 2011 E92 M3 ZCP
I bet its the battery
      09-10-2014, 10:43 AM   #17
new0rder
Lowlife Republic
15
2006 325xi  [0.00]
The battery I replaced last year, so its new, anyway I did try the Steering angle fix, just the optical disc part, use some air can to blow the dust away, not the soldering part. anyway wasn't that hot of day 75 degree temp, I drove around for 20 miles, the problem came back when I hit a bump so the xmas light went up and I have pull to the side, my car lost the power too dangerous
the car eventually came back with power after 1-2 min reset. what to do...
4x4 malfunction, dbc, dsc, x drive
