TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Did I blow my sub?
      12-28-2009, 07:35 PM   #1
Gyuri87
Drives: 2006 BMW 325XI
Did I blow my sub?
I was driving my car earlier and I noticed a great loss of bass. All speakers work the same so I don't think it is any of them but perhaps the sub. Would anyone have an idea? Where's the sub in an e90 BMW 325XI Sedan anyway? I must admit I've just recently got it.
Thanks
      12-28-2009, 08:08 PM   #2
Heinzftw
Heinzftw's Avatar
295
Drives: 2000 Civic+2008 Accord
Wrong section
Originally Posted by Javi335 View Post
saw you comment and i'd lay on my bed and cry, then i put some Yulio Iglesias music, no more problem.
      12-28-2009, 08:13 PM   #3
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
Did you check if you had the bass turned down all the way by accident?
      12-28-2009, 08:39 PM   #4
Gyuri87
I did... I was hoping myself that it was only bad configuration but no... I might have listened to music a little too loud.
      12-28-2009, 10:22 PM   #5
Gyuri87
Anyone? I really need to get this cleared. I want to know exactly what it is so I can get it fixed asap.
      12-28-2009, 11:12 PM   #6
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
You have one sub under each front seat. Put your head down there to make sure absolutely no bass is being produced. If you hear nothing at a moderate volume level, the respective amp channels may be blown (a blown speaker would still produce "sound" so you would definitely hear that).
      12-29-2009, 01:38 AM   #7
Gyuri87
Is there anyway I can get a fully detailed description of the sound system? I'm not even sure how many speakers there are in it. I counted seven if that pod in the middle dash is covering up a speaker. By the way, thanks for the tip, I'll check out those subs later.
      12-29-2009, 02:01 AM   #8
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
This should help
Take a look at this as well
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      12-29-2009, 11:41 AM   #9
Spec 1
Faster in the Corners
Spec 1's Avatar
Drives: '91 E30, '05 ZX6-R, '06 300C
Sounds more like a shortage of your amp, not your sub. Blown speakers (subs included) still work and produce noise, they just don't produce quality noise and become static-y. I would check the connections and fuse of your amp.
'91 M42 E30 - All sorts of goodies.
      12-29-2009, 09:14 PM   #10
JayKay335i
Egypt
189
Drives: ///M323 DCT
Most likely the amp.
      12-30-2009, 07:45 PM   #11
Gyuri87
Originally Posted by JayKay335i View Post
+1
Really, I think it's that speaker in the dash. It feels very weak. Is it possible? If so, how hard is to take that out? Does the dash need to be removed? Honestly I don't know much when it comes to car audio and it's driving me nuts. Where's that amp anyway?
Thanks
      12-31-2009, 12:16 AM   #12
Gavin@MMW
Gavin@MMW's Avatar
Drives: MMW Supercharged E90 328i
Thanks
the dash speaker is a center channel that wouldn't produce bass...
      01-13-2010, 02:08 AM   #13
Gyuri87
Well, I still haven't figured it out. I went to BMW and they said it sounds fine although I know it does not. I'm guessing it's the subs. Would anyone know what brand and model they are?
Where's that fuse?
      01-15-2010, 09:36 PM   #14
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Where's that fuse?
I'm interested as well, actually. Noticed a distinct loss of bass in my car today as well...it made me sad.
      01-16-2010, 09:02 AM   #15
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
READ MY LIPS: IT IS NOT THE SUBS!
      01-16-2010, 08:25 PM   #16
amlebede
Guest
amlebede's Avatar
Drives: 2006 BMW 330i
It might be a lot of things: fuse, subwoofer, amp, preamp, your ear adapting to bass so you don't hear it too loud anymore, etc..
Difficult to answer.
2006 Black BMW 330i, Black interior, ZSP, ZPP, Logic 7, Xenon, Ipod, Satellite Radio Preparation, Moonroof, 12'' 2 P2 subwoofers running on KAC-7204 amplifier, Hardwired Escort Passport 8500, Hardwired Garmin Nuvi 650 on Kuda Mount.
tutor,math tutoring,math tutoring,test prep,tutoring jobs,tutoring blog
      01-20-2010, 08:55 AM   #17
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
So far, all you suggested is to shove your head down there. Let's say the respective amp chans are blown...what do you do then?
Try posting a bit more information than a simple statement, if you intend to be helpful.
      01-20-2010, 10:27 AM   #18
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
It has been stated at least twice that speakers still produce sound after they are blown. This distorted and/or mechanical sound of a blown speaker is quite obvious. So if the subs were blown, the OP would still hear SOMETHING coming from under the seats.
This leaves us with two possibilities:
1. The OP is deaf in the frequencies below 150Hz
2. The respective amp channels are blown
I can't believe I have to point this out but the obvious proof of the amp not working would be to remove one of the grilles, crank up the volume and the bass setting, and see if there is any movement of the cone. If it moves, the OP has a problem with his hearing, and if it doesn't, the amp is blown.
      01-20-2010, 10:43 AM   #19
vladster
vladster's Avatar
Slovenia
Drives: BMW 335 ci
It happened to me once. By accident I had may fader to Front all the way and it also reduces bass.
1st check your settings.
2nd check fuses for the amp
3rd check your sub
That is how I would do it.
      01-20-2010, 10:58 AM   #20
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Fair enough.
Let's assume it's the amp fuse. Do you happen to know where that resides in an E90 LCI? Is it in the fuse box? If so, are you aware of which fuse it is?
      01-20-2010, 11:51 AM   #21
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
Fair enough.
I would expect the L7 amp to have only one power supply so there can be only one main fuse. Doesn't really matter where the fuse is located though, since a blown fuse would mean ZERO music, from any of the speakers.
      01-20-2010, 11:55 AM   #22
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
Not in my car and I have Logic 7, like the OP.
