Hertz Ener 4in. Installed no sound. Help!
12-30-2011, 10:14 AM | #1 |
Rep 6
I just received 2 sets of hertz energy speakers, tried to install them last night. I got the front drivers door done and the rear behind that, but there is NO sound what so ever coming from them. So now i have the stock speakers on the passengers side and Hertz on the drivers side. Did i install them wrong? I simply did like i would do with any other speaker cut the wires striped them and added connecters to them, so they would connect to the the hetz and NO SOUND. I need Help!!
I also have an after market double Din JVC receiver which is all installed and worked with all four speakers before i even tried the hertz. Please help thanks |
12-30-2011, 10:56 AM | #2 |
Rep 3,969
Check the wiring.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
12-30-2011, 11:32 AM | #3 |
Rep 6
what you do you mean, the regular wiring from the original speakers was working before. I just striped the wires and used a plug and clamped them down with pliers and made sure no connection was loose. What other wiring should I check? do you think i need to connect the original wires to a better speaker wire and then plug them into the speakers? would that work?
12-30-2011, 11:36 AM | #4 | |
Rep 3,969
12-30-2011, 11:58 AM | #5 |
Rep 6
is it easy to check all the wires? i might just take it to an audio place to see if they can figure out what the problem is, just was hoping not to put any more money in than i already have. I know it should of just been as simple as cutting and plugging the new speakers in but for some reason thats not the case.
12-30-2011, 11:59 AM | #6 |
Rep 13,101
Can you use a Volt/ohm meter
I would suggest you get a cheap one at an electronics store and learn
how to use it. Last edited by ctuna; 12-30-2011 at 05:12 PM.. |
12-30-2011, 03:51 PM | #7 |
Rep 6
cheap on? whatever that is doesn't matter i solved the problem and the speakers are a huge upgrade from the stock. Definitely would suggest this upgrade for someone looking for better sound than stock, in all only cost me $220.00.
12-31-2011, 10:10 AM | #8 | |
Rep 12,996
I'm not that sure that in our cars this configuration is really a "huge upgrade". Is this the mid that you used? |
01-06-2012, 11:43 AM | #9 |
Rep 6
Yeah that is the mid I used to replace all four along with hetz tweeters, I wasn't looking so much for loudness but better quality. I think there really is a big difference between the stock and the hertz quaintly wise and it is defiantly louder. Now all i have to do for some bass is wait for my earthquake shallow subs for under the seats, bvauto has the on back order for a lil while but its an improvement and im sure adding the subs will make it another step better. I wasnt looking to get anything crazy just an upgrade from what i had.
audio, help needed, hertz, install |
