Help, my car is continually throwing 'P2400' code
11-22-2014, 07:18 PM | #45 |
Rep 7
Drives: 2008 335xi
How do you guys GET TO the pump? I have an 08 335xi, and am I missing something, or do I have to drop down my entire exhaust system to peel back the heat shield? Are you going in through the wheel well (and not having to touch the exhaust pipes?)
I'm going to try checking out the wires. Already replaced the pump itself, and the gas cap to the new blue ones (from green). Still getting the error messages. My car has been expired on the inspection since July (Nov now). Once the new year hits, the color changes, and I'm sure I'll finally get pulled over. |
11-23-2014, 06:21 AM | #46 |
Rep 669
You go through the wheel well.
Identify which side has the pump. If you get under the car and peek through a black plastic cover, you can see a big black box with a white thing attached to it. The white thing is the pump, the black box is the carbon container. On my xi, the pump was on drivers side. See picks above. Remove wheel Remove wheel well cover. That black felt like material covering the whole well. Remove black cover. Don't need to touch the exhaust or heat shields. But you do need to remove some screws that are attached to the heatshield. Once the cover is out, remove all cables and hoses from the pump. Careful with the hoses as they are hard plastic and can be brittle. Remove carbon box. You need to remove it all in order to remove the pump. After that it should be easy. |
12-27-2014, 10:06 AM | #47 |
Rep 7
Drives: 2008 335xi
I just wanted to say thank you. This is exactly what my problem was. I replaced the DMTL pump and my gas cap (from green to the blue) and here we are. A severed wire.
View post on imgur.com This has been an issue for like 6+ months. When I spliced it back together and turned the engine on, the RPM's shuddered for a moment, which I've never witnessed before. I'm sure the pump suddenly turning on in several months did that. Code gone, and thanks guys! |
12-31-2014, 07:44 AM | #48 | |
698
Rep 2,011
Drives: '05 M3 6MT
In my eyes, this is the ultimate goal and brings me a huge sense of satisfaction. No matter how minor or major, helping other enthusiasts deal with issues you've already dealt with yourself. Saving them the time and/or hassle. Happy New Year gents!
'05 BMW M3 6MT (Weekend car) Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link! |
terryd5150507.00 |
01-13-2015, 10:06 AM | #49 |
10
Rep 52
I get the P2400 code as well. By any chance, did you guys get a longer crank at morning start-up? After the first start, the next times it starts fine and idles + runs good. Lets hope that it would only be the wire issue as you guys have stated, but could also be the DMTL pump. I will be inspecting it this afternoon.
I have an '07 E90 with original battery so that "may" be the cause of the long cranks. Any thoughts? |
01-13-2015, 10:09 AM | #50 | |
698
Rep 2,011
Drives: '05 M3 6MT
Check out the wiring before you replace pump (wish I had taken my own advice) and let us know how you make out. Good luck!
01-13-2015, 05:27 PM | #51 | |
10
Rep 52
So does the cable rubbing on the plastic only relate to the pump being on the left side? Mine is on the right and I can't see anything wrong with it. |
01-13-2015, 05:32 PM | #52 | ||
698
Rep 2,011
Drives: '05 M3 6MT
01-15-2015, 10:52 AM | #53 | |
10
Rep 52
Thanks for the reply. I should be getting the pump today and will clear the code after I install it. Let's see what happens after that. |
01-15-2015, 05:34 PM | #54 |
Mytrplseven
Rep 22
Drives: '09 BMW 328i
These are great write-ups and sharing is what it's all about. I'd like to throw in a thought to consider. After repairing a lot of brittle wires under a car I was restoring with electric tape or shrink tubing I found that I got rugged and additional protection from the weather and/or rubbing on wire repairs with liquid electric tape, available at the Home Depot. It's a bottle with a brush for applying over tape or shrink tubing. Stuff is great and goes on thick for long lasting protection.
01-20-2015, 08:54 AM | #55 | |
698
Rep 2,011
Drives: '05 M3 6MT
And that liquid electrical tape stuff sounds like a good way to finish off a wiring job like this. Might have to pick some up for future use. Thanks for the heads up!
07-28-2015, 10:02 AM | #56 | |
42
Rep 364
So, we should be removing the entire carbon box as the pump is attached to it. Do you know the tools that are needed for this? How many screws to remove the box/pump? Thanks |
07-28-2015, 10:30 AM | #57 | |
Rep 669
You need torx bits to remove the screws holding the pump to the carbon box. You can see on the pictures how many you need to remove. Once you unscrew those, just pull on the pump. All other screws were philips. |
08-22-2016, 01:00 PM | #58 |
Rep 14
Just wanted to thank the forum and especially sedi for the in depth pictures and write up. My SES light has been on for weeks and my inspection lapsed due to the errors everyone else is also showing for this issue. I am typically not the guy that lucks out with a broken wire fix and has to normally pay hundreds for the replacement parts...but this time it was different!!! Broken wire at the pump harness just as depicted in this thread. Thanks for all the help!!!
08-23-2016, 09:23 AM | #59 | |
698
Rep 2,011
Drives: '05 M3 6MT
Even though the fix itself was relatively easy, this was a pain in the ass issue for me, so this was my attempt at making it less of a pain for anyone else with similar symptoms. So I'm glad my thread was helpful.
04-17-2017, 04:02 PM | #60 |
Rep 1,415
sorry to bring up a old thread but i just started getting these codes. im going to check the wires and just replace the pump while im in there. my question is if these code would keep my cats from showing ready for emissions. thanks
2007 335XI SEDAN // JB4 G5 // BMS METH KIT // VRSF DOWNPIPES // AFE DCI // ER CP W/ TIAL BOV // MMP SILICONE INLETS // XHP STAGE 3 AT FLASH // TREBILA BEF // BMS OCC // VRSF EXHAUST // FUEL-IT STAGE 2 LPFP // VRSF FMIC // PRECISION RACEWORKS IGNITION SYSTEM // CATUNED COILOVERS // CIC AND COMBOX RETROFIT //
04-17-2017, 09:06 PM | #61 |
Rep 772
I just changed the LDP a couple of months back, it is a simple thing to do and the device itself can be found on fleabay for a decent price. Mine was throwing that code and I tried several things to make it go away but in the end just changing out that tiny little pump solved the problem.
Mods: MHD Stg 2, xHP Flashtool Stage 3, VRSF 3" Chargepipe, Megan 4" Downpipes, Pure N55 Inlet, Outlet, VSRF 5" Stepped Intercooler, GFB Diverter, BMS N55 Intake, Michelin Pilot Super Sport Tires, BMS Sport Oil Cooler Valve, CF Spoiler, CF Kidney Grille, CF Mirror Covers, CF Eyelids, CF Wheel Hub Covers, CF Diffuser, M Sport Racing Strip, 20% Tints, and Golf Tee Mod
04-18-2017, 07:13 AM | #62 |
698
Rep 2,011
Drives: '05 M3 6MT
That I'm not sure about. I wouldn't think so, but that's just an assumption on my part. Sorry I couldn't be more help. Good luck!
06-11-2018, 08:06 PM | #63 |
Rep 1
Just wanted to say thanks! Had this exact issue come up on my '08 335xi around 175K, just as depicted. Ate though one wire and was partially through a second. I repaired with a couple solder sleeves and heat gun, and although tight I was able to do it in the driveway without jacking up the car.
06-27-2018, 11:33 AM | #64 |
117
Rep 255
@sed335i I'm guessing no one will reply to this in time but I was going to replace the wiring today. Does anyone know if wire type/gauge matters? Was going to pick up some standard stuff, nothing special.
08-10-2018, 07:29 AM | #65 |
40
Rep 345
Just wondering, are all your cars 335i? I’m getting codes on my 328i from what I understand the pump is located on the passenger side rear of the car. I wonder if its possible to have the same wiring issues with the car or if it really is the pump. Codes I’m getting are.. 2A12, 2A13, 2A18
code, leak, p2400, pump, ses |
