Alignment Specs; MY2009+ E90/E91 335i; Sport and non-Sport Package Cars; 18" wheels
04-17-2012, 02:20 PM | #1 |
9
Rep 24
For the sake of those looking for factory alignment specs, I thought I'd share what I've got from the BMW computers. All measurements are in degrees/minutes unless otherwise indicated, showing target followed by max difference.
Sedan/Touring build date 9/2008+: without AFS; with Sport Suspension; 18" wheel: Rear Camber: -1.50 L/R; +/-0.25 Toe: +0.09; +/-0.06 Ride Height: 577mm; +40mm/-20mm Front Camber: -0.33; +/-0.30 Toe: +0.07; +/-0.06 Ride Height: 596mm; +40mm/-20mm Sedan/Touring build date 9/2008+: without AFS; without Sport Suspension; 18" wheel: Rear Camber: -1.33 L/R; +/-0.25 Toe: +0.09; +/-0.06 Ride Height: 592mm; +40mm/-20mm Front Camber: -0.40 L, -.23 R; +/-0.30 Toe: +0.06; +/-0.06 Ride Height: 612mm; +40mm/-20mm Note that if your ride height varies dramatically from target, your camber angles will change due to suspension compression, etc. I've posted this for informational purposes only. No warranty express or implied, etc, etc. |
alignment, alignment specifications, e90, factory, ride height |
