ODB Thefts
08-19-2012, 04:59 AM | #1 |
Rep 3
ODB Thefts
I have recently got a 320d M company car (about 4 weeks ago) and had an attempted theft the night before last. I've read up on the alarm blind spot, opening the car through the door lock (essentially it looks like the inner lock is just ground down until it opens) and then hooking up to the ODB to program a new key. There's lots of info and discussions out there about how thieves are stealing cars using these methods, but nothing about how to fix these design flaws BMW have kindly bestowed upon us... How can I disable the ODB in a way that will cause a sufficient delay to a potential car thief? I am simply looking for a deterrent that will (rightly or wrongly) mean that it's not MY BMW that they nick. As this is a company car, it needs to be a reversible modification (I.e. remove a part of the ODB and keep it on me and just reconnect when required). What systems will disconnecting the ODB cause? Will it mess up the cars history and/or cause issues with servicing/troubleshooting? Also, re the alarm blind spot, where is it and can it be fixed by adding a sensor? I've already had one car nicked - an R32 I'd had for just 3 weeks, which was stolen by a creeper whilst I slept upstairs. Scary, inconvenient, expensive, upsetting and quite frankly something I'd rather not go through again. Any advice is appreciated. Any sarcastic or nasty responses are not, so don't bother. Cheers ;-) |
08-19-2012, 06:15 AM | #2 |
Rep 1,058
Drives: G01 BMW X3 30d M Sport Plus
This is such a serious issue that you won't get any sarcastic answers on this forum. The way BMW are treating this whole situation is unbelievable, they are just burying their head in the sand.
I hope people don't mind me posting a link to another forum, but if you've got the time it's definitely worth a read, some useful info on how to protect your car against theft. http://www.pistonheads.com/gassing/t...t=1121571&nmt= |
08-19-2012, 06:20 AM | #3 |
Rep 5,050
Have a search for OBD, there are loads of posts on this but unfortunately no universal solution - the port can't be disabled but can be relocated, even if it's just shoved back behind the dashboard. Anything that will slow down a thief is good, try using a disclok on the steering wheel too
PS. Welcome to e90 |
08-19-2012, 07:30 AM | #4 |
Rep 3
post replies
Thanks both. I've read through that thread this morning, thanks.
I've tried to unscrew the OBD housing, but the position it's in, I can't get the bottom screw out to move the unit anywhere. Is there a cheeky manufacturers shortcut to being able to get into this any easier? My car is the 2010 320 d m sport. |
08-19-2012, 10:55 AM | #5 |
Rep 1,021
Drives: F11 530d M-Sport
I did the obd relocate this morning. Was simple enough.
Remove sill trim - pulls off. Remove under (pedal area) dash trim - 3x torx screws. Unscrew bonnet release handle - 1x screw. Remove kick panel trim - one more screw. Remove obd port - 2x screws. Relocate somewhere hidden, either hard wired or use an extension lead. If the latter, make sure you secure the join and hide it up in the dash somewhere. The obd plug can be now put anywhere that your cable length allows. Just make sure your dealer or mechanic knows where it is if he needs to! My local dealer is going to hate me when they realise what you have to do to get to it!!
MY14 Space Grey F11 530d M-Sport
08-19-2012, 11:05 AM | #6 |
Rep 5,050
08-19-2012, 11:36 AM | #7 |
Rep 1,021
08-19-2012, 11:48 AM | #9 |
Rep 1,021
I guess that's subjective. If I worked at a dealer and saw someone getting zapped, I'd probably laugh my tits off!
Initially...
08-19-2012, 11:51 AM | #10 |
Rep 4,021
How many confirmed thefts have taken place?
Although I agree there is an issue I've only actually read about a few thefts using the OBD and each has been given far more exposure than even a theft where force was used against a person. As posted by a few members including myself, we are seeing a huge reduction in our insurance premiums which suggests the insurance companies don't have any real concern. If they were paying out for loads of claims on BMW cars being stolen our insurance would rocket. |
08-19-2012, 01:23 PM | #11 | |
Rep 735
Granted, I have seen a few cases of this type of theft happening, but I certainly would class it as an epidemic yet. IMO I can't help thinking its a bit like the E90 swirl flap issue. A lot of cautionary tales, but try to get somebody to post an actual failure and they are few and far between. I'm happy to be proven wrong on this, but this is my current perception on the matter (right or wrong). |
08-19-2012, 01:33 PM | #12 |
Capt Slow
37
Rep 1,076
I can totally understand why you both feel that way and that's cool.
I will clarify at work if I can share the figures (for London) before saying anything else. It's an eye opener and I'm sure Birmingham and other places of that size are being hit hard too. |
08-19-2012, 02:46 PM | #13 |
Rep 1,021
For the sake of £10 for some bits, I'd rather be safe than sorry!
08-19-2012, 02:52 PM | #14 | |
Rep 11,291
edit, forget that, just read this... Last edited by dopper99; 08-19-2012 at 04:29 PM.. |
08-19-2012, 03:34 PM | #15 | |
Rep 913
. ..sweet torquin' diesel! |
08-20-2012, 06:28 AM | #16 |
Rep 3
OBD
Thanks so much for the walk through of getting to my OBD. I'll finish the job later today Thanks also for the taser idea...that's so good I would be willing to never sleep again just to try and catch a would-be thief getting shocked to s**t! I agree, I think these OBD thefts are getting a lot of coverage because they expose some serious faults in the BM security system and yes, we need to remember that there are all sorts of other thefts being carried out far more often. I saw a comment from someone on another thread asking about why the ODB's aren't encrypted or have better technology based security. As an IT geek myself, there are thousands of options BM could implement, the only reasons I can think of that they haven't are a)cost and b)industry compliance. However likely this is though, after having my old house broken into and my R32 nicked in under 5 minutes (watched them do it on the house CCTV the next morning) and then not having the insurance pay out (long story) just to know that my car was targeted on Friday night is enough to make me want to cover all the bases. I don't know how true any of this OBD stuff is, but hey, if by taking a few steps my car isn't nicked, then I'm happy. I'm in a suburb of Birmingham (near Sutton Coldfield) and your right this is a big issue for the police around here. I was told by my friendly local bobby that there have been 60-odd thefts since the start of the year on BM's in this way. Apparently it was in the local paper a couple of weeks ago too. It remains to be seen if my car was targeted because it is a BM or if the thieving little scumbags were just after a nice motor. I spread the word about what had happened to a few neighbours who have nice cars on Saturday and at about 9pm that night a young lad from across the road came over to say that his sporty little hot hatch had just had just been done (they'd popped the lock barrel right into the door) Luckily he has a large and slightly mad dog who heard something and went berserk at the front window. The guy came out to see a car speed off up the road. In the end he went and locked up his car in his works' yard... Thanks again for the help and advice, I'll get my OBD sorted later and keep you posted on anything else I hear/see..... Mrs (wannabe) Button |
08-20-2012, 06:37 AM | #17 |
Rep 5,050
08-20-2012, 06:42 AM | #18 |
105
Rep 2,692
where exactly is this blind spot on the alarm then? Anybody considered an aftermarket alarm? That would be the first port of call for a deterrent not so...one of those alarms with the proximity sensors? (MOVE AWAY FROM THE CAR!!) hehe
figures from admiral / elephant car insurance...600 bmws stolen in december 11 and then 1000 -1200 in the following months!..this is kinda here say but from a fairly reliable source. |
08-20-2012, 07:08 AM | #19 |
Rep 3,815
Blind spot is down the side of the door as you slide your arm toward the OBD port.
Easiest safest method is to buy extention lead remove hte trim round the port hide the port under deap in the dash and using extention relocate it to another place in the car. Then ductape the join so no chance of it coming apart. Easy enough done. Anyone around J4 M3 want a hand or see how its done give me a shout
F30 335i M Sport - now departed
08-20-2012, 09:00 AM | #20 |
105
Rep 2,692
so how are they getting into the car??...breaking the glass?
I've had the cookes ferry mod done but what I'm getting at is I want a deterrent that prevents them from trying (via the obd method) so as to prevent the damage to the car - so I just want to understand what they do. |
08-20-2012, 09:57 AM | #21 |
Rep 3,815
Number of options just search YouTUbe. Wax Keys, Stick film on glass break it and pull it out slowly. Cloned Keys
alarm, odb, stolen, theft |
