TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      10-29-2013, 01:48 PM   #1
Singh97
Singh97's Avatar
Drives: Jattizm
2004 BMW e46 M3  [10.00]
Question Front bumper side grills on 35i vs 50i !!
Hi, I know that on a 35i side grills under the fog lights are not vented/meshed like 50i but are only designed to like a perforated one. So my question is has anybody swapped them and also is there a reason other than looks to weather this should be done or not. Please share all pros and cons you can think of. Pictures are welcomed if you have done this mod.
Another forum member @Neon01 asked me this question.
Singh
      10-30-2013, 07:50 AM   #2
Chio
Chio's Avatar
Drives: G80 M3 Comp Xdrive
2018 S6  [10.00]
I have the m sport and I changed the solid ones to mess! The only reason the 50 has them open is because of the intercoolers !
      10-30-2013, 11:15 AM   #3
edennelson
edennelson's Avatar
Drives: '14 E71 X6M, '14 I01 i3
I believe mpg will suffer.
      10-30-2013, 11:24 AM   #4
Singh97
Singh97's Avatar
Drives: Jattizm
Did u noticed some extra dirt accumulating inside the bumper or any other difference?
Singh
      10-30-2013, 11:25 AM   #5
Singh97
Singh97's Avatar
Drives: Jattizm
can u please expand on that ?
QUOTE=edennelson;14896554]I believe mpg will suffer.[/QUOTE]
Singh
      10-30-2013, 11:49 AM   #6
edennelson
edennelson's Avatar
By drawing air into the front of the vehicle you increase the drag coefficient.
      10-30-2013, 11:56 AM   #7
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
Nah no dirt theres a slot under the intercoolers that goes out under the car so basically its just a vent but no dirt stays behind. Only problem i have is the leafs going into the center mesh of the bumper And have to stick a vacum hose thur the hood where the kidneys go to vac.
      10-30-2013, 12:47 PM   #8
Singh97
Singh97's Avatar
Drives: Jattizm
Thanks. But I was more concerned about the after affects of changing the grills to open meshed once on a 35i. As you said 50i have inter-coolers so there is no much open space there.
Singh
      10-30-2013, 12:49 PM   #9
Singh97
Singh97's Avatar
Drives: Jattizm
Will it add even more air from the side grills even after having that big center grill and big kidneys?
Singh
      10-30-2013, 12:53 PM   #10
///SAL
///SAL's Avatar
Since we have the intercoolers, whats behind yours have u checked. Take a look before buying them to see whats gonna be exposed. Sometimes you might see something that dont look good being exposed
      10-30-2013, 02:54 PM   #11
edennelson
edennelson's Avatar
Yes it will reduce mpg. I can't say by how much, it's defiantly not huge.
It's probably similar to having a dirty air filter, or a couple PSI low in your tires.
      10-31-2013, 02:31 PM   #12
Chio
Chio's Avatar
2018 S6  [10.00]
It will not do anything to mpg! When they were blocked it was like hitting a wall! Now they are open and the air can flow threw !
      10-31-2013, 02:36 PM   #13
Chio
Chio's Avatar
2018 S6  [10.00]
The air will just go in then down and out! I have been getting same mpg since I have done this both city and hwy
      10-31-2013, 03:25 PM   #14
edennelson
edennelson's Avatar
People think removing the tail gate from their pickup allows air to flow threw...
It in fact creates a low pressure area behind the cab and causes mpg to suffer.
The OP asked for downside. The downside is a small decrease in mpg.
      11-01-2013, 08:10 AM   #15
MonacoJoe
28
Drives: X5M - Carbon Blk
agree the sealed mesh looks terrible. though adding vents with no intercoolers seems korny to me. no way that would impact MPG...thats retarded.
      11-01-2013, 11:22 AM   #16
Singh97
Singh97's Avatar
Drives: Jattizm
Thank you for the pictures Chio.
Singh
      11-01-2013, 11:34 AM   #17
Neon01
BMW Nut
Neon01's Avatar
Drives: 12 X5 35i
As an aerospace engineer I understand what you're trying to post, however, what's uncertain in this case is whether or not the volume of space behind those grilles is sealed or vented. If it _does_ vent to somewhere, it's unlikely that this will significantly impact the overall drag of the vehicle.
I think you would have a stronger case if the closed grilles were a part of some laminar or turbulent low pressure region (such as in your pickup truck analogy) that would be disturbed if they were gone. As it is, they are completely within the free stream airflow, and probably creating a high pressure region (due to being almost completely oblique to the vehicle velocity vector) anyway, so I'm not sure if creating a hole there will really change the flow over the vehicle much. It will divert less flow over the rest of the front of the vehicle. If that is beneficial or not is unknown.
One thing is certain - unless the x50i has these regions ducted somehow and the x35i does not, it will certainly create a situation no worse than the one on the x50i. Though there are heat exchangers in those locations on the x50i, the air still flows over those and has to go somewhere.
When I asked Singh, part of what I was inquiring if anyone had actually done it before since I simply don't know what's behind there. If there are large chunks of white styrofoam supporting that region of the bumper, for example, I certainly wouldn't want that visible. Also, whether those areas on the x35i or x50i are actually ducted or vented somehow.
12 X5 xDrive35i | Platinum Gray | Oyster | Burl Walnut | Premium | Convenience | 3rd Row | Apps
13 Audi S4 | Misano Red | Black
04 S2000 | Berlina Black | Black
      11-09-2013, 08:50 PM   #18
BIG CRAIG 203
Drives: 2011 X5 50i
I believe that on my 50i it vents the breaks
      05-07-2015, 09:16 PM   #19
wyatth
3547
Drives: E90 ZCP
Sorry to bump this but I couldn't find any more info on this after extensive searching. Have any others swapped these grills? Is there anything to cool on a 35i? Not worried about mileage, more curious if there is anything ugly exposed on a 35i or if there are any mechanics that could be cooled by the vented 50i grills.
Cheers -
      05-07-2015, 09:57 PM   #20
lanbrown
Drives: BMW X5
The 50i vents the hot intercooler air out through the wheel well. There are slots there so the air has a place to escape. See part number 14:
http://www.realoem.com/bmw/enUS/show...diagId=51_7518
      05-07-2015, 10:09 PM   #21
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
I put the 50i vents on my 35ii and they look better in my opinion. When the stock vents are removed there is nothing but black plastic behind them. Just pull the vent out and take a look, they just snap in.
      05-08-2015, 01:31 PM   #22
Singh97
Singh97's Avatar
Drives: Jattizm
Double that
I have swapped them on my 35i and it looks much better.
Singh
bumper, grills, side
Search this Thread:
xbimmers
