BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Mid-Atlantic > LCI Taillight Conversion Coding
      03-31-2014, 09:28 AM   #1
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
Done some research on the regional forums and have emailed Than at BCR CR to inquire about some things I would like done to my 2007 E90 335i. He does not have a definitive answer on successfully coding LCI tailights to a pre-LCI ECU. Has anyone in this area done this conversion and had it coded before?
Thanks guys.
My delivery experience and beach photoshoot here.
      03-31-2014, 10:51 AM   #2
lito
lito's Avatar
Philippines
167
Drives: E92, F30
sup man! Where u been? RRT coded mine a while back for like $80. Give them call.
http://www.rrtracing.com
      03-31-2014, 11:19 AM   #3
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Lito the man!! I've been okay, out the game for a while but hopefully I'll stick around a bit this time. I miss seeing that clean E92 rolling around.
I will definitely contact them, I know that you have also had this conversion done.
      04-01-2014, 07:59 AM   #4
tmaung
CCA Member#: 439255
tmaung's Avatar
Drives: E36 M3, F80 M3
Definitely try rrt or even John at *************. I just haven't done the LCI conversion yet but if you want to at least give it a try, I'll only charge $20 if it works. Let me know.
      04-01-2014, 11:39 AM   #5
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
I will be meeting up tonight with someone to test it out. I'll keep everyone posted here.
      04-09-2014, 09:31 AM   #6
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Bump.
Worked with Than over at Bc RCR, he did an amazing job and worked with me even on re-wiring my reverse lights to cut off the rear fogs and correctly engage the reverse lights when the car was put into that gear, also got a lot of other features done.
Extremely pleasant guy, would reccommend him to anyone. And now my LCI Rear conversion is complete. Oh, and Euro rear fogs as well after some modifications to the switch.
I'll update with pics later. Maybe.
coding, conversion, dmv, e90, lci
