Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tires rubbing on 335is
      01-18-2013, 05:46 AM   #23
CombatNinja
CombatNinja's Avatar
46
Drives: e91 328i, e90 328i, e90 335i
You could take a look at where this rubbing is taking place and maybe solve it with a very small spacer up front. By virtue of how the fender liner is shaped and where the contact is happening, moving outwards just a couple of millimeters might be enough to cure it. The 313s are OEM so they are conservative enough to give you the option.
      01-16-2014, 03:21 PM   #24
SUHleen
Drives: 335is
Sorry to bump up an old thread but I did not want to start a new one since this has some info in it. I'm running Continental DWS's 235/35 in the front and I get the rubbing also. Usually only in reverse though. For those thinking on installing a spacer, I did a 5mm just to flush the wheels a little more with the fender and yea, it looks nice, but it caused more rubbing. It does it in drive now as well just at a certain point for a second depending on conditions (i.e. road, passengers, how much I'm turning, etc...)
Has anyone been running without the vents on there? I do not want to go this route but not sure what else to do short of buying different sized tires.
Anyone else try the zip tie method?
      01-17-2014, 07:34 AM   #25
Fun w/N54
Drives: '11 E92 335is AW/CR/DCT
Originally Posted by Erockdaface234
I run same set up on my IS on 19in 313s and have no rubbing issues whatsoever.
what tires are you running?
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275.
      01-17-2014, 07:37 AM   #26
Fun w/N54
Originally Posted by BuraQ
I am running Nitto NT550 235/35/19 front, 275/30/19 rear, No rubbing. I even have more room for 245/35/19 front, 285/30/19 rear.
Nice set up...so no rubbing, no spacers and OEM suspension?
      01-17-2014, 07:53 AM   #27
Dymag
NC BMW
Dymag's Avatar
Drives: 2013 335is , 6 speed mt
2013 BMW 335is  [8.00]
Front Rub
I have a 335is. I am running Conti DW 235/35/19 upfront, on a 8.5 x 19 wheel et35. I get a rub when entering a drive way, especially at an angle - even when moving very slowly. A 235/35/19 Potenza RE-11 gave even more rub under same circumstances; larger tire - no surprise.
Is this a vent issue, an off-set issue - or do we need a front wheel well roll ?
Cobb AP v3 - Wedge tuned, Cobb FMIC, AR catted DP's, Dinan Stage 2 suspension, Koni Yellows, M3 control arms and strut brace, BMS chargepipe, BMS OCC, BMS Sport Oil Cooler Valve, BMS CDV, RB Turbo PCV, aFe Stage 2 SI intake w/scoops
      01-17-2014, 08:28 AM   #28
flip4335
General Nuisance in a Private Conveyance
flip4335's Avatar
Drives: like it's rented
Originally Posted by Hootsama View Post
Nervous about doing this set up now. Should I go 225 up front and 265 rear on 19" 313s to avoid possible issues? Thx.
Yes. You will notice, when you use the calculator that the rolling diameter is better with the 225/265 setup. Try a little experiment by plugging in those values in the calculator and you will see what I mean...
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS
Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570
      01-17-2014, 09:45 PM   #29
SUHleen
Drives: 335is
As far as I'm aware it is an issue with the vents for the secondary coolers
      01-18-2014, 02:36 PM   #30
Kid Eh
I used to be conceited, now I'm perfect.
Kid Eh's Avatar
570
Drives: 2018 M3 CS
2018 BMW M3 CS  [0.00]
That was the tire and size I was going to get in the spring. Maybe best to stick with the stock 225/255 setup?
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect"
      01-19-2014, 11:04 AM   #31
SUHleen
Drives: 335is
Thats what I would guess. Type in the ratios in the tire calculator and check the differences. I can't tell if it is the overall height or overall width that is causing it to rub.
      01-19-2014, 04:23 PM   #32
Former USMC
Former USMC's Avatar
Drives: 2013 335is Crimson Red
Originally Posted by Newera335is View Post
Hey Guys,
I recently replaced the stock RFTs on my 335is with 313 rims. I put on a set of Michelin PSS 235/35/19 in front and 265/30/19 in the back. Now it seems when I reverse and turn sharply on pavement that is not perfectly flat I hear what sounds like wheel rubbing from the wheel well. It seems to be when the wheel is turned completely to the right when I am backing out of a parking spot usually. I haven't seen any sign of rubbing on the outside of the tire.
Has anyone else experienced this with the Michelin Pilot Super Sports?
Thanks
Greetings Newera335is,
I just replaced my rear tires with 275/30/19's. In my opinion, they don't look much bigger than the original 255 run flats. They ride better and the tread pattern looks menacing, but no rubbing whatsoever.
Are 313 rims BMW wheels? Got a pic. Here's mine below.
Semper Fi
      01-20-2014, 10:21 AM   #33
romanonj
romanonj's Avatar
145
Drives: F80 DCT
I had some rubbing with 19 x 8.5 and 35 offset with same size tire. It only happened in reverse and passenger side when the wheel is turned all the way to the left. It is the oil cooler vent that is causing it. Removing it is not advisable, since it protects the cooler from road debris, rocks will put a hole in it at high speed. You can try zip tie to keep things tighter as mentioned above, or I have better idea - M3 control arms!! They fix the issue by pushing the wheel out a bit. I am running BMW performance suspension with mild drop in the front (about 1/2 inch).
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR
2014 F25 X3 M-Sport Carbon Black
2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles
      01-20-2014, 10:37 AM   #34
Dymag
NC BMW
Dymag's Avatar
I have M3 control arms and Dinan Stage 2 suspension; my front drop is about 1/2 " also. My Rubbing is primarily during left turn, but moving forward going up a drive-way - when hitting that initial "bump"/shaved down curb. is there a vent on the driver's side as well for the additional radiator ?
Thanks, - Ray -
      01-20-2014, 11:05 AM   #35
SUHleen
Drives: 335is
Thanks, - Ray -
Yes, there is a vent on both sides. I'm not sure which is which but one is the oil cooler and one is a secondary radiator.
      01-20-2014, 11:08 AM   #36
Dymag
NC BMW
Dymag's Avatar
Thank you. I will look at both of those vents. What is the "fix" with the zip ties ?
      01-20-2014, 03:40 PM   #37
romanonj
romanonj's Avatar
145
Drives: F80 DCT
Passenger side is the oil cooler, driver is the radiator (I think so please dont blast me if I am incorrect ), since the standard 335 also has rubbing issues with passenger wheel well..
      01-25-2014, 08:06 AM   #38
Kid Eh
Kid Eh's Avatar
570
Drives: 2018 M3 CS
Semper Fi
Yes those are 313's in your picture. What tires are those?
      01-25-2014, 07:00 PM   #39
Former USMC
Bridgestone Potenza RE760 Sport. 275/30/19. Non run-flats. I picked up a Slime Kit from Pep Boys...just in case of a flat.
      02-22-2014, 10:09 PM   #40
mjd223
mjd223's Avatar
Drives: 2015 M5
I am running Nankang 235/35 and 275/30 on 19x9.5 wheels. Front have no issues but the back wheels rub when going over bumps and dips that work the suspension. I am thinking of maxing the negative camber or buying a more aggressive camber kit. What do you guys think? Car has stock suspension and sits low enough for me
      02-24-2014, 01:35 PM   #41
bravehart38
bravehart38's Avatar
40
Drives: 11' M3
i have a 12' 335is and the PSS 235/35 were rubbing up front. just replaced them with 235/30 PSS and problem solved. i dont like the fact that this size is only available in the Michelin PSS. i'm worried that if they stop making this size i'm screwed in the future.
      02-24-2014, 03:59 PM   #42
Dymag
NC BMW
Dymag's Avatar
Front Well Vents
Did the rubbing occur at the front wheel well vents ? Is there are fix for the vents as opposed to smaller tires ?
      03-10-2014, 05:05 PM   #43
AughtOcho335
Drives: AW E92 335i
Just ran into same issue. Thinking about gluing vent to fender liner.
      04-07-2014, 02:17 PM   #44
vwetish
Drives: e90 335i
no rubbing
I have 225 40 19 and 255 40 19 blizzaks on stock style 269.
No rubbing at all.
I run 235 35 19 and 255 35 19 pss on the same rims in the summer without any rubbing either.
Worn out suspension part could cause rubbing issues.
I drive 2008 335i with sport suspension.
335is, michelin pss 235/35/19, tire rubbing
