Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 328i vs 328i xDrive lowering Springs- Is there a difference?
      11-01-2013, 10:12 AM   #1
JPflip509
JPflip509's Avatar
Drives: '11 328xi
I have a 2011 328i xDrive sedan. I am planning on lowering it with H&R Sports+Koni Yellows. My concern:
I saw on the Suspension forum the part # for H&R Sport Springs are 50490.
I see some websites have 50494 or 50492. Is there a difference between xDrive springs, or regular sedan springs and even coupes?
Which is the one I need and if there is a website you have as good as Turners Motorsports, please provide. THANKS A LOT EVERYONE!
      11-04-2013, 08:48 AM   #2
JPflip509
JPflip509's Avatar
Drives: '11 328xi
can anyone answer? i thought this would be a legitimate question
      11-04-2013, 09:50 AM   #3
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
Don't ever expect a reply over a weekend when everyone is doing other stuff.
Sorry I can't help you on the spring question; you should check realoem to see if the strut assembly (the part holding the shock cartridge and spring) is different (in the front). I would expect a difference in that case (and I think the struts are different.)
      11-04-2013, 09:58 AM   #4
JPflip509
JPflip509's Avatar
Drives: '11 328xi
struts i understand will be different between the awd vs rwd. it was just the spring question. but my guess is that it too may be different.
thanks for your input
      11-05-2013, 11:05 AM   #5
Cir14
Drives: 11 328xi M-Sport Sedan
I've always had success looking @ part #'s on Tirerack.com; select the suspension section and it should provide all avaialble options
      11-07-2013, 12:54 PM   #6
JPflip509
JPflip509's Avatar
Drives: '11 328xi
Thanks man!
h&r springs, koni, lowering, suspension
