Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Engine Malfunction with no DME codes? Includes datazap logs from map 2 and 5
      03-30-2014, 03:44 PM   #1
Canadian 335xi
18
Drives: 335xi
Angry Engine Malfunction with no DME codes? Includes datazap logs from map 2 and 5
Car: 2008 335 XI with iDrive
Mods: Catless downpipes, DCI, JB4 ISO5 (running map 2)
Background:
I got my plugs replaced a week or two ago. The car seemed to idle a little rough after the plugs were changed to the point that I went back and asked them to check things over, look for codes, etc (it was on the way to work and I went in on a whim). The found nothing and there were no stored codes.
Last night I was in 4th and was wide open throttle from about 2500 RPM, I was just before 5k RPM and the car went LIMP and the engine malfunction warning came up on the dash as a yellow 1/2 engine and iDrive gave me something similar. The loss of power lasted 2-3 seconds or so and the dash returned to normal, the message went away and the car was fine. I stopped at the gas station filled up and headed home.
I hook up my laptop and check for DME codes using the JB4 software but there is nothing there. The car is running fine and has not had any other symptoms. I went out today with the laptop hooked up and did a bunch of pulls on map2 and map5.... no errors, no power issues, etc. Can I upload logs here or is Berger the only source to read them?
How can I have no DME codes when I got the Engine Malfunction warning message?
I think people will say "bad DME" but if I don't use my 'clear codes' setting on the JB4 and run on map 0 I will get the CEL come on and get the "catless downpipes detected" message. (or at least I did before)
Last edited by Canadian 335xi; 03-30-2014 at 05:28 PM.. Reason: added datazap logs
      03-30-2014, 03:46 PM   #2
Ali Shiralian
Ali Shiralian's Avatar
813
Drives: 2014 335i xdrive, 2014 X5 3.5d
Oooh, makes me wanna rethink my new purchase
      03-30-2014, 03:55 PM   #3
chili36
Drives: 335i
Turn off auto clear!
Is it kicking you into map 4 when it limps?
      03-30-2014, 04:33 PM   #4
Canadian 335xi
18
Drives: 335xi
A little vague ... no?
The setup is AWESOME. I fully recommend it... it's probably something with the plugs. Drive around stock and then do your DCI, catless and JB4 ... then try to tell me you want to re-think it.
Before the plug change the car was bullet proof with NO ISSUES.
Do it all... and do put some money aside in case something breaks.... but get the downpipes, DCI and JB4, you can be sure you won't regret it.
      03-30-2014, 04:36 PM   #5
Canadian 335xi
18
Drives: 335xi
Sadly I didn't even think of clearing off auto clear, but I will.
As for map4 I didn't check that actually... because it went off so quick and I was only 5 minutes on the road to the gas station the only thing I did was say "f*ck" alot in my head. It was map 2 when I went for my drive today.
I just don't understand how I can get engine malfunction with no codes? I was told that the "clear codes" only cleared tuning and downpipes type of codes and that if there was anything serious it would leave them??? Can someone confirm or deny that?
      03-30-2014, 05:25 PM   #6
Canadian 335xi
18
Drives: 335xi
I was reading elsewhere and found out about datazap.me... what a cool site.
I would appreciate some eyes & opinions on my logs. They are also post-warning.
http://www.datazap.me/u/Canadian335xi
      03-30-2014, 05:35 PM   #7
chili36
Drives: 335i
Turn it off it clears everything.
Only way to troubleshoot is to be able to see the codes that are being thrown. As long as you have the code clearing feature on you will not know what is going on.
      03-30-2014, 06:45 PM   #8
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
glad you like it! spread the word! I have a SICK new feature coming very soon
      03-31-2014, 05:54 AM   #9
Canadian 335xi
18
Drives: 335xi
bump for a brother with a mysterious engine malfunction problem with no DME codes?
I still think the clear codes in the JB4 was to leave "important codes" but I can't find that thread....
      03-31-2014, 06:26 AM   #10
Ingeniator
Ingeniator's Avatar
34
Drives: 07 335XI(90) 09 135I(82)
I use the JB4 to clear my misfire all the time. I confim the code via hex 1,1 and clear with 1,2. If you keep 1,3 on all the time the code will throw and it will clear after a couple minutes without intervention. Some scanners can still pick it up but it has to be a quality one that can grab bmw shadow codes and history codes.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
      03-31-2014, 07:57 AM   #11
Canadian 335xi
18
Drives: 335xi
A friend of mine has the 650 dollar cable from Berger ... would that be the one that could read it?
This is the one he has I think:
http://burgertuning.com/scanner.html (at the bottom)
I'll have to read about shadow codes and history codes, I was happily ignorant of such things....
      03-31-2014, 08:59 AM   #12
chili36
Drives: 335i
Again, turn it off and read the codes.
dme, engine malfunction, jb4, no codes
