Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Full Review -- Supreme Power -- Lowering Perches ----------
      05-17-2011, 10:34 AM   #23
psre08
Drives: 330i E90 & 330Ci E46
Mine went on my '06 330i in November. They work perfectly, although I must admit they were a pain to install. Excellent value.
      12-27-2011, 09:16 AM   #24
HifiSyd
HifiSyd's Avatar
Drives: 2007 335i Sedan
Thumbs up
I installed mine this weekend. As stated before, install was a bit of a pain, primarily because of the spring compressor tool. I honestly think I had to crank each one about 500 times per side; arms got a bit tired and the angle was uncomfortable, but not unbearable. Start to finish it took me about 3.75 hours with the first side taking much longer than the second due to the learning curve.
I didn't re-use the rubber spring seat and I've got no squeaks or any other undesirable side affects. I'm on factory ZSP and the perches lowered the front of my car 9/16". I went from being able to get "2.5 fingers" between the tire and fender and now I'm at 1.5 fingers. It's a subtle difference, but I'm happy with the result.
The perches seem to be a very high quality product and tanks to everyone posting their experiences as it made my install much easier!
      06-25-2012, 09:06 PM   #25
supremepower
Supreme Leader
supremepower's Avatar
Drives: G80, 996GT2, 996TT, 991RS 356b
Originally Posted by gaifaun View Post
by the way, has anyone installed these differently? I remember reading one member didn't re-install the rubber rings back onto the spring perch. I assume that would make the car sit even lower but now there is not rubber to dampen the vibration and shock from bumps.
Supremepower, what do you usually do when you help your clients install the perches?
We dont reinstall the rubber and there is no noise at all.
Takes us about 45 minutes to do the install here at the shop.
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831
Contact: sales@supremepower.com :: Shop# (714)632-1951
Sales & service of BBS Street & Motorsport products.
BBS Highest Volume Dealer 2015 thru 2022
All the top brands at the prices and service you can count on. Professional installation.
      07-01-2012, 10:25 AM   #26
lakefront
Drives: 2017 Macan GTS
had my perches installed about 2 weeks ago along with a set of Koni FSDs. The shop has checked the alignment 3 times and swears its at factory settings, but the steering has become very quick, to the point that it darts across every bump in the road. Shop wonders if even the small amount of lowering from the new perches has changed the alignment specs. They are a reputable shop that works on plenty of other BMWs.
      07-02-2012, 03:14 PM   #27
supremepower
Supreme Leader
Something is not installed correctly. Any chance you can email me some photos of the installation? eric@supremepower.com
Be happy to take a look for you.
The lowering spring perches if installed correctly have nothing to do with the issue you are having.
SupremePOWER
      07-10-2012, 11:04 PM   #28
neilvosko
neilvosko's Avatar
Drives: 335i e92 FBO
can these be installed with BMW performance suspension on E92? vs the ZSP
and what is the expected lowering?
alignment is not required?
      07-11-2012, 08:26 PM   #29
supremepower
Supreme Leader
Yes you can use these as well.
Your car will lower 0.4" - 0.6"
Alignment is not required
SupremePOWER
      07-11-2012, 09:29 PM   #30
neilvosko
neilvosko's Avatar
Puuuurfect, thx. order placed.
every non-coilover owner should buy these.
      07-12-2012, 04:39 PM   #31
supremepower
Supreme Leader
It also fits coilovers that use the factory top hat. So customers who have the need to go lower now can.
Some of you guys have gone as low as you can on your Bilstein Coilovers and the perch will give you an extra 1/2" should you need it
SupremePOWER
      07-12-2012, 10:39 PM   #32
GOTMH8N
Stay Classy
GOTMH8N's Avatar
Drives: 335i Sport
I'm probably going to have to purchase these!
      07-13-2012, 08:25 AM   #33
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Great write-up...these might be in my future.
'05 BMW M3 6MT (Weekend car)
Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link!
      07-13-2012, 02:50 PM   #34
supremepower
Supreme Leader
In stock ready to ship! Let us know
Sounds good! Let us know
Installation available for So Cal residents!
SupremePOWER
      07-24-2012, 12:38 PM   #35
Frsh-N-Klean
47
Drives: 2016 f80 M3 non-zcp
Had my E90 LCI done yesterday and it looks great!! The drop isn't crazy but definately looks much better. I was surprised what 1/2 inch does to the look our your car.
      07-24-2012, 02:37 PM   #36
Tam@SupremePower
Tam@SupremePower's Avatar
Drives: BMW
2007 e92 335i  [7.00]
a little goes along way!
      07-25-2012, 12:51 AM   #37
osukf09
64
Drives: 2011 e92 M3 ZCP
These are intended to be installed w/o the rubber spacer/gasket, correct?
Have there been other reports of people experiencing binding noises when turning the wheel, and more of a harshness over rough road, after installing the perches? I've had these symptoms since I had them installed with bmw perf. suspension almost a year ago, and while I don't always get the binding from the front, it still occurs occasionally while turning the wheel at slow speeds (ie: parking).
Any help?
      07-25-2012, 06:41 PM   #38
supremepower
Supreme Leader
No we have had no reports of binding noises at all. Only a faulty installation woudl cause this. It is more than likely one of the following:
1. Washer between bearing and perch is not installed right side up
2. Washer between bearing and perch not installed at all
3. Rubber gasket installed when it shouldnt be
4. Top nut not tightened all the way
5. Bearing needs to be replaced.
There should be no harshness or binding with this spring perch. It operates exactly like the OEM part in terms of function.
If you need help dont hesitate to PM or call me directly at 714 632 1951 x225
Thank you
SupremePOWER
      07-26-2012, 12:48 AM   #39
osukf09
64
Thanks, I really appreciate the help Eric.
I've had feelings it was either #1 or #4. Might take it over to LTBMW again and see what they say. I'll definitely be in touch Eric to go over the specific issues I'm having and to hear your thoughts.
      07-26-2012, 12:51 AM   #40
BennyJones
BennyJones's Avatar
24
Drives: 2018 Alpine White M Sport F30
Are these the same for all E90's?
IG: f30_yyz
      07-26-2012, 02:56 PM   #41
supremepower
Supreme Leader
Oh you are local to us. You are welcome to stop by
Yes basically.
Except not for:
Xi
M3
SupremePOWER
      07-26-2012, 10:00 PM   #42
BennyJones
BennyJones's Avatar
24
Yes basically.
Except not for:
Xi
M3
Great thanks, I'll be ordering a set tomorrow!
IG: f30_yyz
      07-27-2012, 01:39 AM   #43
supremepower
Supreme Leader
In stock. Same day shipping.
SupremePOWER
      07-28-2012, 12:46 AM   #44
neilvosko
neilvosko's Avatar
Thank you
I am having same issues as APj with BMW perf suspension with steering wheel binding to one side only in parking lots and then self correcting. I had the install shop look at installation twice. Is there any pics I can send you to verify?
drop, lower, lowering perches, springs, supreme power
