The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Full Review -- Supreme Power -- Lowering Perches ----------
      07-28-2012, 03:17 AM   #45
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
I hear for it to fit on Xi we just need the "I" top hats. Can you confirm? If so you should sell as a package for Xi applications
      07-29-2012, 12:44 PM   #46
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
This is correct as I have done the I tophats on my 09 Lci xdrive and it works perfect. IT HAS BEEN CONFIRMED
      07-29-2012, 07:21 PM   #47
neilvosko
neilvosko's Avatar
Drives: 335i e92 FBO
wow, i am still having issues. poping and clunking and then car pulls to the side i turned AFTER i straighten the wheel. everything looks tight and intact. WTF? please help.
      07-30-2012, 03:49 PM   #48
platnumdesi01
Drives: 2009 335i Coupe
I had mine installed by a professional and we re-used the rubber part as he was worried about noise etc. Regardless the car is lower and I love it.
      07-31-2012, 12:59 PM   #49
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
check the washer at bottom of bearing if thats installed wrong way it will cause these issues you speak of . good luck
      07-31-2012, 09:10 PM   #50
neilvosko
neilvosko's Avatar
Can you please expand?
      07-31-2012, 10:50 PM   #51
neilvosko
neilvosko's Avatar
I don't get the washer notes. Is it any different from stock? Does it have to be flipped?
      08-01-2012, 06:31 PM   #52
Ph0zenstone
325
Do you have pics?
      08-01-2012, 07:06 PM   #53
supremepower
Supreme Leader
supremepower's Avatar
Drives: G80, 996GT2, 996TT, 991RS 356b
Originally Posted by neilvosko View Post
I am having same issues as APj with BMW perf suspension with steering wheel binding to one side only in parking lots and then self correcting. I had the install shop look at installation twice. Is there any pics I can send you to verify?
Yes send me pics to eric@supremepower.com
Im wondering now if the bottom of the shock is all the way into the spindle. I have seen a customer who came in with the shock not all the way into the spindle and it caused the car to do some crazy things.
Yes this is now confirmed. XI models can order the lowering hats and the upper hats from us.
Yes finally! Thank you 08msportx3!!
Need pics to help you out.
The rubber is not needed. Only effect is it would not lower it all the way.
#8 in the photo below needs the flat part of the washer to be lower than the domed portion which the bearing from the top hat sits on.
See above
Do you have pics?
Need pics of the install.....
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831
Contact: sales@supremepower.com :: Shop# (714)632-1951
Sales & service of BBS Street & Motorsport products.
BBS Highest Volume Dealer 2015 thru 2022
All the top brands at the prices and service you can count on. Professional installation.
      08-03-2012, 07:34 PM   #54
flinchy
Drives: E82 135i
uhhh... compresssed springs and OEM ride quality? impossible.
ED: i should also note, compressing springs, much like adding lowered springs, will reduce the life of the strut, not only compromise ride quality and safety... do this at your own risk .
      08-07-2012, 11:50 AM   #55
SpeedCC
Drives: 335xi
These perches actually lengthen the static distance from Bottom Spring Perch (fixed on strut) to Top Spring Perch (Supreme Power) so the spring is not as compressed upon top hat assembly as it was with stock top hat.
Thus, the car now sees an initially lighter spring (same spring but not as compressed as stock assembly) with the strut sitting further into its stroke (hence the approximate 0.5 inch lowering), and in my case has further increases bump stop activity. Outcome will vary based on existing strut/spring that is used and their related baseline performance.
      11-21-2012, 12:09 PM   #56
Nonecure
Nonecure's Avatar
Drives: 2013 M3
You have provided a lot of good feedback and I plan on buying from you.
I disagree with your statement that the rubber is not needed. The thickness of the rubber will have minimum effect on the ride height, but it provides movement without squeaks and pops. I'm not a mechanic, but as an engineer I understand the function.
Every car I have worked on has rubber between the spring and the perch. Car makers do not add unnecessary parts on their cars unless it is needed.
      11-21-2012, 12:12 PM   #57
supremepower
Supreme Leader
The rubber is not needed. The perches have a spring built into them and once there is load on the perch from the weight of the car being applied on the entire suspension there is no movement.
This never was about the thickness of the rubber having an effect on ride height. It was more how the rubber fit on the new perch and the fact that its not needed.
If properly installed there are no squeeks or pops at all.
If you would like to install the rubber perch you can. We just dont recommend it.
SupremePOWER
      03-21-2013, 12:07 AM   #58
itrocks4u
Drives: F80, F36, E90
Nice review! Very interested.
      03-21-2013, 01:50 PM   #59
El Cheapo Loco
douchebaggo
186
Drives: stick
I've heard that before. You should see my child support payment...
      03-21-2013, 02:55 PM   #60
mlifxs
Diamond Geezer
mlifxs's Avatar
212
Drives: Jet Black 2007 328i Saloon
if 'the strut is sitting further into its stroke', does that mean I'll wear out my struts faster with the perches then without?
      05-21-2013, 12:43 PM   #61
The Ghost
Reborn
The Ghost's Avatar
Drives: 335i
It isn't needed. Mine has zero squeaks or rattles and I left the rubber out.
you and me both!
      10-28-2013, 10:47 AM   #62
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
I plan on using these with my stock non-sport springs and bilstein hd dampers. Idea is that the perches will make up for the increase in ride height that the bilsteins can cause. I would think this minor lowering will be no problem for a robust damper like the bilstein hd.
Also thinking about plasti-dipping the top coil to prevent noise from metal-metal contact but retain good fit of spring on perch.
Does anyone think this is a bad idea and why? Thanks.
      10-28-2013, 10:08 PM   #63
avocet
Drives: 2007 328i 2011 X5d
My sp perches have zero noise.
And no rise with bilstein hd's on sport springs.
      10-29-2013, 11:05 AM   #64
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
That's helpful Avocet, thanks. I assume you also left out the rubber piece from the perch?
What springs are your running D4 and D3? How did the ride quality and handling change?
      10-29-2013, 10:37 PM   #65
ibd12nv
Chief Warrant Officer 4
ibd12nv's Avatar
53
Drives: 335I, E46 M3, X5M
2007 E90 335i  [10.00]
Looks good.
http://rapidshare.com/files/36182957/335i_sig2.jpg
      10-30-2013, 12:15 AM   #66
avocet
I never checked what spring rates I had... Std 328i e90 sport springs fwiw.
And no rubber pads on perches.
I have found the ride to be a fair bit firmer, but with less crashing and it is much more controlled. There is alot more road feedback and 'noise', but I did m3 front arms and rear sub bushings and sways at the same time.
drop, lower, lowering perches, springs, supreme power
