TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Full Review -- Supreme Power -- Lowering Perches ----------
      10-30-2013, 08:08 AM   #67
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Originally Posted by avocet View Post
I never checked what spring rates I had... Std 328i e90 sport springs fwiw.
And no rubber pads on perches.
I have found the ride to be a fair bit firmer, but with less crashing and it is much more controlled. There is alot more road feedback and 'noise', but I did m3 front arms and rear sub bushings and sways at the same time.
Do you think that some of that noise could be from the metal to metal contact of the spring to perch?
      10-30-2013, 10:54 PM   #68
avocet
Drives: 2007 328i 2011 X5d
No.
      02-02-2014, 08:39 AM   #69
jan31
jan31's Avatar
Drives: 2014 F32 428I Xdrive (N26)
This works for e92 also?
      02-02-2014, 01:39 PM   #70
Chocolate Apocalypse
Drives: 2011 335i
Yep, have them on mine
2011 335i - New toy
2010 Chevy Equinox - Beater
1972 Cutlass - turbo LS project underway
      02-05-2014, 05:16 PM   #71
jan31
jan31's Avatar
Great! I'm getting a set.
      07-25-2014, 06:40 AM   #72
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Wanted to resurrect this thread because I am now getting a single clunk when hitting a one sided bump in the front like turning into a driveway when one front wheel compresses first. I have the SP perch, no top seat rubber installed (per SP rec), bilstein HD, new meyle hd endlink, oem C4 non-sport springs. About 2.5K miles since the install and it just started making this noise.
      07-25-2014, 07:40 AM   #73
FCobra94
Guest
n/a
Drives:
I have your same exact setup. I was worried about clunks/popping noises/etc. like I had with a set of coilovers on a previous vehicle. For that reason, before installing the lowering perches I cut/ground off the "spring" they include on the perch itself, painted those bare areas, and then used a brand new OEM rubber spring pad on top of the spring itself. Not having a rubber isolator there just didn't sit well with me as that is exactly what lead to clunking/popping noises I had in the past (different platform, same principle). Zero issues so far.
      07-25-2014, 10:21 AM   #74
supremepower
Supreme Leader
supremepower's Avatar
Drives: G80, 996GT2, 996TT, 991RS 356b
If its clunking then 100% something is loose. Check the top nut of the strut and also check the meyle endlinks. With both these make sure when you tighten the nut the shaft is not spinning and since you are not truly tightening the entire set up. If you have any questions don't hesitate to contact me directly at sales@supremepower.com or calling 714-632-1951 x225
The rubber not being used is a direct instruction from Supersport Germany. No noise can be made by the removal of the rubber. The spring is under tension at all times and cannot move up and down therefore no noise can be created by the absence of the rubber.
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831
Contact: sales@supremepower.com :: Shop# (714)632-1951
Sales & service of BBS Street & Motorsport products.
BBS Highest Volume Dealer 2015 thru 2022
All the top brands at the prices and service you can count on. Professional installation.
      07-25-2014, 01:10 PM   #75
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Thanks for the response. Got it up on stands today and everything with the springs and perches is fine, they are still seated as they were originally and with all weight hanging the springs are still tight between the lower and upper perches. Don't think that is it. Banging around down there with a rubber mallet nothing seems wrong everything is tight. There may be the slighted bit of ability to wiggle the upper control arms, both sides the same, but since they have rubber bushings that has to be normal. None of the bushings show any signs of leaking. Shocks still look brand new. I am at a loss. I may just have to wait till it gets alot worse to be able to tell something is loose or worn out. Not easy for us BMW OCD types!
      07-25-2014, 01:15 PM   #76
supremepower
Supreme Leader
Does the 16mm nut on the sway bar link turn when you try to tighten it? If it does then its loose and you need to hold the back of it while you tighten the nut.....call me if you like anytime! Helped many others find their noise
SupremePOWER
      07-27-2014, 06:30 PM   #77
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
FIXED! I figured out my issue, it was exactly how supreme power said it was! The passenger side fsb end link where it attaches to the strut was loose. It was snug but when I tried to tighten it, it would just turn, I ended up taking an impact gun to it which tightened it enough to where I could then take a ratchet/socket to it and tighten it without it turning. Clunk is gone and car handles better now that I am getting the full value out of the front sway bar!
Thanks Eric!
      07-28-2014, 05:56 PM   #78
supremepower
Supreme Leader
Thanks Eric!
Awesome!! Glad I could help!!
SupremePOWER
      03-11-2015, 09:14 PM   #79
supremepower
Supreme Leader
Sold out for a minute but back in stock guys!
Please call us at 714 632 1951 to order or feel free to order online here:
http://www.supremepower.com/suft015-...perch-bmw.html
      03-12-2015, 07:49 AM   #80
fravel
fravel's Avatar
Drives: Monaco Blue '06 330i
Just got mine installed yesterday, we did not use the rubber isolators - from my short drive home I have no problems to report, and these gave the perfect finishing touch to my front end drop. Happy customer :tup:
      03-16-2015, 03:32 PM   #81
Nguyenhu0106
Nguyenhu0106's Avatar
27
Drives: 2007 335i
hey, just a thought but have you guys checked your end links... i was having clunking noises in the back before and even after changing out my suspension and the bushings. i then suspected the endlinks and changed them out since they were old.. my noise was gone.. maybe check your front endlinks.
      03-16-2015, 06:40 PM   #82
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
who are you talking to??? I just explained how it was my endlinks????
OEM Black grill and Blackline tails - LCI halogens with Lux V2 coded as DRL - 3M Crystalline - BMS PBX - OEM Euro Airbox with K&N - Hardwired CTEK - Bilstein B6 w/OEM springs and SP perches - Conti DWS06 - HiFi-Helix DSP - JLAudio HD/XD-Morel - CD changer trim - AE optical out
      03-16-2015, 06:52 PM   #83
ferocity02
Drives: 2013 135is
I installed mine last weekend and the passenger side clunks every now and then. Has to be a good size bump for it to happen. Everything is tight. I reused the rubber isolators. Was I not supposed to? The upper isolator doesn't fit too well on these new perches.
I didn't reuse that thin paper gasket because they were ripped.
2013 135is DCT Carbon Black Metallic
      03-16-2015, 08:08 PM   #84
vwetish
Drives: e90 335i
Mine clunks as well, both sides. Everything is new, springs, struts, strut mounts and swaybar links. I suspect that the design is faulty.
      03-16-2015, 09:00 PM   #85
avocet
Zero clunks still. After reinstalling my endlinks I found I needed to retorque them a few weeks later after they began to cluck. No issues since.
I am a happy lowering perch customer!
      03-16-2015, 09:37 PM   #86
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
I've used these for over 3000 miles and no clunks what so ever
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
      03-16-2015, 09:44 PM   #87
235Dude
Drives: 2016 M235i
Do you need an alignment afterwards?
      03-21-2015, 10:54 PM   #88
vwetish
Drives: e90 335i
I have new yellow koni, new performance yellow stings, new strut mounts and new hd mayle links, no rubber insulator and clunks when turning the steering wheel left of right, both sides, when car is stationary. Very load clunk Sounds line the spring snaps in and out the perch.
The spring is snugged in between the perch wall and the welded arch, not ever it like in the photos bellow. Just for reference, not my car.
drop, lower, lowering perches, springs, supreme power
