Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Just installed Lux 5.1. Now have some questions.
      03-24-2011, 08:39 AM   #23
rubdom
Drives: 08 E90 AW
Originally Posted by bmerxix View Post
did you have any problem installing? e.i error codes? or was its a straight pnp?
The install sucked. You have to get to the ECU box and that sucks but once I installed I had no problems. Once in a while I would get a parking lamp error when the headlights would go from off to on automatically but it would go away after a few seconds. I found out what this likely was when I removed the harness and saw that I had pinched the wire and it had stripped away a little of the wire and was probably causing the error.
Coding is much much easier and there are so many other things you can do but if you have an older car it may not work.
daeos, lux, lux 5.1
