BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Lowering my e92 with H&R springs
      12-18-2013, 09:54 AM   #1
kayfaz
kayfaz's Avatar
30
Drives: F10
Smile Lowering my e92 with H&R springs
Hi All,
I'm thinking of lowering my car with H&R springs and leave my current MSport suspension. I've had a look at essex_lad's thread:
http://www.e90post.com/forums/showthread.php?t=887059
I think that's a perfect drop, although I'm not sure if the drop on my car will be the same as he has a 325i and mine is a 320d (much difference in the weight of the engine?)
Can anyone recommend a good garage to put these on for me around Reading, West London, Farnborough area?
Will be buying the springs from:
http://www.ebay.co.uk/itm/BMW-320d-E...-/330723270618
      12-18-2013, 10:16 AM   #2
richk84
England
130
Drives: e93 330i
I would guess that the 320d engine is lighter being only 4 cylinder so you may find your car sits a bit higher.
      12-18-2013, 10:19 AM   #3
kayfaz
kayfaz's Avatar
30
Drives: F10
Yeah that's what I guessed...
But are diesel engines heavier than petrol in general?
Tbh even if it is higher than his I would still be happy enough as long as the front doesn't look like a 4x4 anymore
      12-18-2013, 10:46 AM   #4
richk84
England
130
Drives: e93 330i
I think there the best option out there for the 320d coupe. I plan on buying the same springs just haven't got round to it yet.
      12-18-2013, 05:48 PM   #5
kayfaz
kayfaz's Avatar
30
Drives: F10
Will you get it done yourself or use a garage?
      12-19-2013, 01:45 AM   #6
Phil325i
Phil325i's Avatar
615
Drives: E92 325i MSport Coupe
They're a bit further than you may want to to travel, but I can thoroughly recommend these guys:
http://www.bromspecuk.com/
Fully BMW trained, great attitude and good labour rates.
      12-20-2013, 04:22 AM   #7
richk84
England
130
Drives: e93 330i
Was just going to take it to a garage, got quoted 3 hours work to swap the springs over.
      12-20-2013, 05:51 PM   #8
Mikey B
Mikey B's Avatar
Drives: E92 325 Coupe
These okay on standard dampers?
      12-21-2013, 11:29 AM   #9
acerboo
England
179
Drives: e92 335d lci
why do you want to lower it?
      12-21-2013, 09:59 PM   #10
mob17
mob17's Avatar
400
Drives: E92 335D
Because of the ridiculous front arch gap i guess? Aesthetically its better in most people's eyes, including mine
      12-22-2013, 02:56 AM   #11
Alex.J
Alex.J's Avatar
56
Drives: BMW E92 335i MSport
I would be pretty certain in saying the 320d lump is heavier than a 325i!
However , there will be a different kit listed for the 320d?! Which will have the correct spring rates to compensate for the weight!
Swapping springs is easy, just remember, once swapped, make sure you get full 4 wheel alignment carried out !!
      12-22-2013, 10:01 AM   #12
kayfaz
kayfaz's Avatar
30
Drives: F10
As above, because of the stupid space between the wheel and arch
Excuse the dirt on the car...almost impossible to keep the car clean these days
      12-22-2013, 10:07 AM   #13
kayfaz
kayfaz's Avatar
30
Drives: F10
So I've spoken to Performance 3000 in Somerset. They can supply the H&R springs at £167 and fit for £125 including tracking etc, which I think is a good deal.
Just need to figure out when I could schedule a day trip to Somerset in between the xmas holidays
      12-22-2013, 10:56 AM   #14
mob17
mob17's Avatar
400
Drives: E92 335D
Great price on the fitting.
But i doubt they do a full 4 wheel alignment, which you should do. It normally costs around £100 for the alignment.
      12-22-2013, 11:00 AM   #15
kayfaz
kayfaz's Avatar
30
Drives: F10
"This also includes 4 - wheel Laser alignment after the kit is fitted!"
That's what they said, but I will do a full 4 wheel alignment a couple of weeks after installing them once it has settled.
      12-23-2013, 12:48 AM   #16
Dsport
Dsport's Avatar
24
Drives: E91 320d Lci
This is correct the springs need a while to settle and drop, also if done correctly the cast and camber settings shouldn't change, the £125 quoted is a not a bad price, there is a specialist near us that does 4 wheel alignment £38,
When I do springs I charge around £60
Unless it's an audi they are a pig to lower
      12-23-2013, 09:29 AM   #17
kayfaz
kayfaz's Avatar
30
Drives: F10
I'm guessing that's £38/60 per corner, right?
      12-23-2013, 09:52 AM   #18
Dsport
Dsport's Avatar
24
Sorry meant to say he charges £38 for 4 wheel alignment
I charge around £60 to fit x4 springs depending on what car it is
      01-01-2014, 04:00 PM   #19
breathe3asy
breathe3asy's Avatar
South Africa
112
Drives: 340i F30
E92 325i  [10.00]
What was the outcome of this? I'd like to know how they feel vs. M Sport & if the drop was as expected.
      01-01-2014, 05:36 PM   #20
kayfaz
kayfaz's Avatar
30
Drives: F10
I went and had this installed yesterday at Performance3000 in Yeovil, top guys there!
Took them around 3 hours to fit, while I waited in their nice waiting room watching TopGear , they also offered to fit my Gloss Black grill for free as I travelled a long distance to them. Would definitely recommend them.
Not very happy with the drop at the front yet, but I'm sure it will be go much lower once settled.
I will post some pics and more feedback in a couple of days time once they have settled.
      01-26-2014, 11:16 AM   #21
90MSP
14
Drives: 330D M Sport
I have lost faith in my local mech.. live in Andover Hampshire. Phil325i... have you had good experience with these guys then ?, what did you have done ?.
      01-27-2014, 03:25 AM   #22
Phil325i
Phil325i's Avatar
615
You have a PM.
h&r, lowering, springs
