BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      08-12-2011, 07:24 AM   #23
NJBMWM3
Drives: e92 //M3 6speed
I put an AA drop in filter in my car. The stock filter was black and loaded with leaves and helicopters. The difference was amazing I really felt it in the pedal so much low end torque was back. I contribute this to the clean filter.
      08-15-2011, 01:47 PM   #24
CarbonAlpine
CarbonAlpine's Avatar
204
Drives: ///M4
I also put AA filter, I might try this one though.
Please pm me price eas
      08-15-2011, 05:08 PM   #25
Leonardo629
Taiwan
168
Drives: 2013 M3 Coupe
I just picked up this kit as well....don't know if I want to install the scoops though....
      08-15-2011, 09:03 PM   #26
Sales@Evolve
92
Drives: Slow
Brilliant review!
Again, another consistent result from the MS guys!
Please note - see how on the stock car the runs vary by 10hp!
A much bigger gain could have been shown if runs 1-2 were shown instead of runs 3-4!
BUT... very transparent review.
I can see these flying off the shelf!
      08-16-2011, 03:00 AM   #27
swamp2
swamp2's Avatar
Drives: E92 M3
Originally Posted by tom @ eas View Post
Rapture's car simply kept making power dyno pull after dyno pull once the S2 was installed.
Call me a skeptic, but that is one of my jobs around here... This sounds like a systematic error rather than power gains...
1. Either the engine adapts immediately to the mods or doesn't.
2. If it does it should not continue to make more power each run. Thus the conclusion is bad dyno results.
3. If it doesn't then you could only see this if it adapted very quickly.
As is typical - there are many ways to spin dyno data. It is often as good as we want it to be when the levels are basically in the noise. We would not be having the discussion (well... unfortunately we probably would be..) if the claimed gains from another modification, say modification "X", were dyno proven to be 2-3 hp.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      08-16-2011, 07:38 AM   #28
Bomis
Bomis's Avatar
Sweden
63
Drives: BMW E92 M3
I can vouch for more power with MS 2
EURO E92 M3 2008 6MT Interlagos ///Fully Loaded! Evolve-R ECU Flash/Gintani Sport Exhaust/MS Stg2 Intake Kit/H&R Springs/MS 18/15 mm spacers/Bmw Perf. Grills/Gloss Black side gills/LCI Tails/LUX V3's/RD license plate leds
      08-16-2011, 10:21 AM   #29
Krozi
Krozi's Avatar
Drives: 2008 E92 ///M3 Alpine White
Originally Posted by Wall$treet View Post
What does this have to do with anything when you have a sealed intake box? You are hung up on open air intake dyno results. An open hood has no benefit on a dyno if the airbox is sealed as the box is pulling air into the same intake paths whether hood is open or not v. open intake where it arguable is sucking in more air and cooler air than with the hood sealing the top.
Anyway useless observation but thanks
You're wrong.
2008 E92 ///M3 Alpine White//Fox Red//6MT//
Florida Bimmer - Join us on FaceBook!
      08-16-2011, 10:26 AM   #30
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
Ehhhh - I think what Tom meant is that the car continued to make consistently more power than without the intake.
      08-16-2011, 10:29 AM   #31
Singletrack
Originally Posted by Krozi View Post
You're wrong.
Why don't you explain it then?
      08-16-2011, 10:42 AM   #32
M3DCTBT
34
Drives: E92 M3
I purchased this, slightly more intake noise, power TBD. I ran BMC and rpi scoops before. AFR's seem to be staying inline.
      08-16-2011, 11:02 AM   #33
Sales@Evolve
92
Drives: Slow
That's because AFR is target driven. This is not an E30 325i.
      08-16-2011, 11:28 AM   #34
Krozi
Krozi's Avatar
I got da juice.
      08-17-2011, 10:42 PM   #35
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
actually, no this isn't true. You'll find that the car won't adapt immediately, especially if there is no closed loop operation between installation. I would expect that if there was a significant change in airflow that it would take a few pulls for the DME to fully adapt... it should continue making power and plateau.
That said, I'm very skeptical, I just can't see the stock intake tube being a restriction. It has what appears to be a very large cross section, with smooth bends and a very small accordion section.
Scoops, as well, I can't believe. Even if they did manage to somehow pressurize the airbox, the fact that it is open no only to the brake duct (which is probably a low pressure area) but also to the hood vent (also a low pressure area!). I actually think that due to the drastically reduced airflow on a dyno, vs out on the highway, Scoops may actually perform in dyno conditions, definitely less low pressure in both the brake duct and the hood vent.
Anyway, I did notice a small amount of power from my AFE intake (which is really poorly designed because it uses a smaller than stock filter!) so maybe I'm on crack and there is power to be had. I pay people to tune my car and make parts because they are a lot smarter than I am. (although weeding through the noise is hard sometimes)
DSC_3369 by Kit W, on Flickr
      08-20-2011, 07:09 PM   #36
swamp2
swamp2's Avatar
Drives: E92 M3
I can't really be wrong because I said EITHER it adapts immediately OR it doesn't. At least we are both skeptical, that is the more important part...
      08-20-2011, 07:51 PM   #37
kitw
kitw's Avatar
471
Sorry, you're right, I didn't read your post right.
Anyway, yeah, I can't imagine it making power... but a back to back swap from the AFE to the stock airbox showed a loss of 6whp. And, the AFE is a poorer design than the Macht Schnell, in that it uses a smaller air filter than stock!
so what do I know? maybe there is power to be had there.
      08-20-2011, 08:12 PM   #38
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
Interesting...I might have to look into this in the future. Exhaust is first, though! Thanks for posting this
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      08-20-2011, 09:41 PM   #39
onnex
onnex's Avatar
Drives: 2015 F80 M3
2011 E92 M3  [9.26]
I feel the scoops do not do anything so I am thinking you could install this without the scoops and get the same benefit. Anyone done this
bought mine used from another user w/out the scoops, then added RPI scoops after. There wasn't really a difference that I could feel after adding them in.
2015 MG F80 M3 | H & R Sport Springs | M Performance Diffuser | 20" DPE SP-SC 5 | IND Matte Black Cosmetic Package | More coming soon
      08-20-2011, 10:50 PM   #40
E90///M3`
Philippines
141
Drives: 2008 E90M3
2008 BMW E90 M3  [7.60]
a little skeptical... don't get me wrong, EAS is awesome but just being honest cause MS is directly sold my EAS.
but good numbers none the less.
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels
:Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights
:Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST
      11-10-2012, 05:11 AM   #41
i3urton
Drives: bmw m3
Hood was open...
yes i dont know too many pplz that drive with the hood up.
but as long as the owner likes it!!! thats all that matters.
      11-10-2012, 12:30 PM   #42
Rapture
I'm suckin gas but I'm haulin ass
Rapture's Avatar
Drives: 2016 M3 ZCP MW/SO
I guess we should ignore all the other dyno runs ever done because they were all done with the hood up
      11-11-2012, 09:33 PM   #43
kaiv
IG: limited.slip
Drives: E46 M3 in a 325i Touring body!
Bumping a year old thread to make such a stupid comment.
When people drive, their car are also moving zomg
      11-12-2012, 11:53 AM   #44
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
eas, filter, intake, macht schnell, power
m3post
