How to import from Garmin Nuvi to iDrive
04-07-2009, 06:59 PM | #1 |
Rep 10
As a prospective 335i owner awaiting ED, I am spending my idle time researching how to migrate to the 335i.
I currently have a Garmin Nuvi GPS with a number of stored addresses. How do I migrate these to the BMW's idrive navigation system? I am aware about the Gmail import but that doesn't suit a mass import. The USB key seems the appropriate method but I haven't found anything specific on the internet about this. Has anyone already done this migration and, if so, how? |
04-08-2009, 09:29 AM | #2 |
195
Rep 2,485
I can't think of any easy way to do it other than send each one via Google Maps to the iDrive.
I'd also be interested in a solution.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
04-10-2009, 07:18 PM | #3 |
Rep 10
Importing GPX files into iDrive
Just pondering this further... you can "export" from the Garmin Nuvi by copying the current.gpx file from your unit to your PC/Mac. You can also use Garmin's Roadtrip to read and export a cleaned up version of this file.
So, the real question should be, how does one import GPX files into iDrive? |
04-10-2009, 08:14 PM | #4 |
Chicks dig wagons!
43
Rep 1,375
Drives: 2009 E91
Location: Where you can see through the people, but not the air (i.e., Los Angeles!)
Can you somehow import those files into a blackberry or other smartphone? If so, then you could bluetooth those addresses into your car.
E91 Montego Blue gray leather burl walnut , Idrive, PDC, Logic7, CA, Sirius, xenons, 6FL, ZPP, heated seats, 17" tires.
4, 8, 15, 16, 23, 42 |
04-11-2009, 12:11 PM | #5 |
Rep 10
Export from Google Earth to iDrive
Another possible direction...
You can directly import the GPX files into Google Earth (File > Open File). I haven't figured out how to tie that into the iDrive but, given the Google/BMW relationship, I thought that might be a step closer... |
10-28-2009, 05:01 AM | #6 |
Rep 64
interesting topic, though challenging..this may be very helpful if resolved..im planning to import some bmw floor mats,,and hope I can learn it here..
09-08-2010, 03:49 PM | #8 |
Rep 10
I never solved the problem. The best workarounds were either:
* send a waypoint from GMap to the car wirelessly or * reenter the waypoint as an address, sync via BlueTooth, and then select from the mobile phone's addressbook. It's a shame because I would like to keep my destinations in sync between my 335ixc's iDrive and my K1200S's Zumo. I go back to my earlier observation--there should be an import facility for the iDrive nav... if not gpx, then another published format that someone could write a waypoint conversion utility. Mike |
garmin, idrive, navigation, nuvi |
