Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > SEVERE WEAR, any ideas? (PICS)
      09-15-2011, 10:16 PM   #23
Priority 1
Priority 1's Avatar
Drives: e92 335xi
Originally Posted by edirtaynine View Post
get the 265/30 instead of the 255/35.... im running 255/35 rears and its a tiny bit too tall. oh well, ill change it out after i wear these out first.
That's exactly the input I was looking for on that tire setup. Thanks!
      09-17-2011, 10:15 PM   #24
asus389
asus389's Avatar
Drives: 11 E90 328i
2011 BMW 328i  [0.00]
My 06 325i with sports package did the same thing. Inside front wear on the potenza RE050a RFTs. Also outside cupping. This was at ~15k miles.
I'm probably going to have someone go over my front suspension when I put my winters on. Are there any typical worn components that would cause this kind of wear?
      09-29-2011, 06:12 PM   #25
Priority 1
Priority 1's Avatar
Drives: e92 335xi
Four Wheel Alignment Complete
Thanks for all of the help! Went ahead with the alignment and the toe was definitely off. Brought the front toe and rear toe and camber back into spec. I've posted the report so people can compare the wear to the alignment.
Thanks again all!
      09-30-2011, 12:41 AM   #26
edirtaynine
Drives: e92
ohhh nice
      12-02-2011, 12:26 PM   #27
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
Priority 1, thx for posting the results. Why did they not put the rear toe on both sides the same? 0.09" vs. 0.06".
Also, for the most part, they went with a setting that was in the middle of the BMW specifications, but for the rear toe they didn't. Do you know why?
      12-03-2011, 03:49 PM   #28
Priority 1
Priority 1's Avatar
Drives: e92 335xi
I saw that when I looked it over before paying, and I have no idea why they weren't individually centered within the spec range. The total is centered within the range though, and that's probably what they shot for. Individually within the range with the total centered???
alignment, camber, rft, tire wear
