Camber out of spec / or bent strut?
12-12-2012, 01:40 PM | #1 |
16
Rep 253
Hey all,
I just got around installing new rims and winter tires that I purchased from Tire Rack. In the process I got a wheel alignment and they said the front left tire is way out of spec. They said they think the strut is bent but they are not sure unless I replace it. They also said it could be the control arm. The shop drill out the pin and was able to do a small adjustment. Here are the specs I have now. Question is how much will I ruin my tires if I keep this camber? Also, is it true you can't tell if something is bent unless the replace it? I don't want to purchase a new strut and spindle only to find out nothing is wrong but I need a new control arm. Thanks all |
12-12-2012, 02:30 PM | #2 |
Rep 3,004
it looks like you're well within range to me. How does the car drive?
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
12-12-2012, 03:17 PM | #3 |
16
Rep 253
Car drives fine granted I have not taken on highway speeds yet. When I had the all seasons on before, it drove straight and the car didn't pull in either direction.
12-12-2012, 04:08 PM | #4 |
Rep 4,108
Drives: BMW M3
Agreed with joec500. -0.9 degrees of camber isn't going to prematurely wear the tire. You can achieve that much stock with these cars so I doubt anything is bent.
I really wouldn't worry about it.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
12-12-2012, 05:19 PM | #5 | |
Guest
Rep n/a
Drives:
If anything, you should try and get the camber on the passenger side to match. |
12-14-2012, 03:11 PM | #8 |
Rep 3,949
It would be rattling then so probably not.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
alignment, camber, struts |
