REST (Residual Heat) feature coded back on a 2011 335i!!!
03-23-2012, 12:01 PM | #67 | |
Rep 4,121
05-22-2012, 04:02 AM | #68 |
I'm The Captain Now
501
Rep 1,810
Drives: X5M/X7
Garage List 2021 BMW X7 MSport ... [0.00]
2018 Raptor [0.00] 2015 X5M (SOLD) [0.00] 2014 BMW M5 (SOLD) [10.00] 2014 BMW M5 Totaled [10.00] 2014 Jeep SRT (SOLD) [0.00] 2012 C63 AMG (SOLD) [0.00] 2015 BMW M4 (SOLD) [0.00] 2011 Porsche Cayenn ... [0.00] 2007 911 Turbo (997 ... [0.00] 2013 335i M Sport ( ... [0.00] 2002 Porsche 911 Tu ... [0.00] 2008 BMW 135i (SOLD) [6.00] 2002 BMW M3 SOLD [10.00] |
Kalud,
Any updates on turning ALL on for the cars with a REST button? I can get you copy of my 08 .TRC file
05-22-2012, 09:44 AM | #69 | |
Rep 582
But if you still want to try out, using the other coding thread as source of information and DIY, read the IHK module and search for a "REST_TASTE_VERBAUT" software switch. If you have it, try setting it to false with "nicht_aktiv". |
05-22-2012, 10:42 AM | #70 |
Rep 642
Drives: 2010 E92 335i
Some 2010's also lack the "REST" button (like mine)..but this is a cool feature if I ever need it -- prob won't since I live in SoCal.
05-22-2012, 11:06 AM | #71 | |
Came to the N55 Darkside
1112
Rep 12,740
05-13-2013, 05:14 PM | #72 |
Rep 4,121
doesn't the vehicle need an aux water pump for this?
I guess 335i have electric pum 335d has engine driven pump. an aux pump was present in 2009 but was deleted. Last edited by taibanl; 05-13-2013 at 05:25 PM.. |
05-13-2013, 11:56 PM | #73 |
135
Rep 2,517
Drives: '11 335xi e92 M-Pak
I prob gonna try this tomorrow
06-02-2013, 04:07 PM | #75 |
Rep 1,079
It only works when the car is warmed up and once the ignition is turned off. It cannot be turned on while the car is still running.
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
06-02-2013, 05:31 PM | #76 |
295
Rep 2,202
06-02-2013, 06:21 PM | #77 |
Rep 1,079
Didn't realize that....I never use the feature unless its below freezing anyways.
02-03-2015, 05:39 AM | #80 |
17
Rep 194
Sorry to drag up an old thread, although I'm sure a lot of people still reference this one when they get into coding! I have a E90 320D M Sport 2011 and have recently successfully coded a few things like digital speedo, instant MPG etc. I came across this thread after reading that the REST feature could be enabled if you have the ALL button (which I have). I performed the coding for this and as far as I can tell it has worked in terms of the fans circulate and the ALL button lights up when I press it after turning the car off, and it continues to run after i lock the car. I don't get any symbols up on the climate panel like i do when using the idrive function for timer air ventilation/circulation, is this normal? The car was fully up to temp and it was very cold outside, however the inside of the car didn't really feel that warm after I cam back around 20 minutes later. Do the climate settings need to be on max temp before turning the car off in order for hot air to circulate, or does that not matter? Where abouts in the engine bay is the aux water pump located so I can check that I definitely have one?
11-18-2016, 12:48 PM | #81 |
Rep 198
Drives: 2011 335xi, Ferrari 308QV
Resurrecting an old thread, but wanted to inform that coding the ALL button to REST is available via BMWCarly.
martinblair30.50 |
11-18-2016, 11:31 PM | #82 |
31
Rep 138
Drives: 2010 328i Touring
03-24-2017, 03:06 PM | #83 | ||
Rep 1,416
I read the entire thread and I need to ask because I must have missed something: If the REST function ONLY WORKS VIA the older style water pump that was discarded on production cars AFTER the REST became ALL then how does any sort of coding make REST work on E90 cars (assuming all the cars without factory REST have the newer water pump) with the ALL button and without the older style pump?!!
10-05-2017, 08:13 PM | #84 |
Fixing stuff is fun.
15
Rep 26
I read this, and verified via realoem:
e90 335* (gas models) have electric water pump up through 2012. LCI e90 335d (diesel) has serpentine belt driven water pump (turned via motor) |
03-08-2018, 09:36 AM | #85 |
Rep 1,416
So the coding is making the ALL button into a PARKED CAR VENTILATION button and not a genuine REST button?!
10-05-2018, 12:38 PM | #86 |
87
Rep 369
YES, if you have 2010-11 335D!
10-05-2018, 01:36 PM | #87 |
Rep 1,416
10-12-2019, 12:49 AM | #88 |
Rep 28
Resurrecting!!!
I have a '07 that had the REST feature. I use it all the time in the winter. But I installed an Eonon stereo head unit. It will run the heated seats, but to get to the on-screen control is clunky. Somebody linked me to the newer controls that have the heated seats buttons on the climate control. But I would lose the REST. Would I be able to code it to work? Or would I even need to? Would it just work as REST? |
2011, coded, coding, feature, rest |
